[ROM] MXQ M12N Superceleron v1.0 Rom
    Hi there guys and girls, one more rom... This is not the original stock rom... the only thing from the original is the kernel and the recovery.
    My many thks to trebor for the beta test!
    Changelog v1.0:
    • Netflix playstore...etc... fully working
    • Quick Boot!
    • Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
    • DRM widevine!
    • Bottom and upper bar fixed and added power button to it.
    • Proper rooted.
    • Custom Kodi 16.1 Build. (Normal Kodi with my librtmp)
    • initd.d support.
    • Fully deodexed.
    • Network tweaks. (On N networks bw around 30 to 42mbits, and on AC networks from 150 to 200mbits)
    • Permissions fixed.
    • Sleep working, full poweroff also working.
    • Kodi Brightness fix (videos...)
    • Passthrough fix apk ( thks prahjister for the apk)
    • Removed the default launcher it have a lot of stability problems, you will loose the net led...
    • Added a nice launcher!
    • Other small fixes and optimizations!
    Want to buy me a beer?Download:Install instructions:
    • Download the zip (DON'T UNPACK IT)
    • Put the zip in a USB Stick or a sdcard ( Better a USB Stick)
    • Boot to recovey and choose "Apply update from EXT" then "Update from sdcard"(if you use the sdcard..) or "Update from udisk" (if you use USB Stick) and flash...
    • Reboot and wait...
    Where to buy:
    1º BOOT TAKES AROUND 6 MINUTES!
    AFTER THAT DO GIVE THE 1º BOOT 3 or 4 min TO INSTALL ALL APKS!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Here is a Video...
    Enjoy it!
    qui vend this boite de tv box? ACEMAX M12N
    who sells this box tv box? ACEMAX M12N
      english plz!
        Hello,
        He want to know if it's the same box as the Acemax M12N and who sell it.
        Bye
          Ha ok thks
          yes its same thing... who sell it? a lot of stores just choose the one you feel good!
            I have flashed it onto my Acemax M12N and it works.
            I used a different method of installation though by using the Update app, selecting the zip file and letting it do it's stuff.
              Ye that also works
                Me to, a nice rom.
                  I wonder if this will work on the Beelink gt1?
                  If not, superceleron are you considering the idea?
                  Sent from my MX4 using Tapatalk
                    Dunno if it works and if i dunno better not try it!
                    And no, i only work on devices that i have physically.
                      Hello i have install on my BB2, the Rom works but not the WiFi and the bluetooth. I do not arrive has to go back.
                      " This package is for " BB2 " devices; this is has " m12n ".
                      (Satuts 7)
                      I edited the file updater-script and signed the update zip but without result
                      " signature check failed "
                      with what tool signs you the update zip?
                      link of rom BB2 http://www.mediafire.com/download/ax...SD_Upgrade.rar
                        will check it...
                          I succeeded has to turn back with Amlogic BootcardMaker. it's a pity that the WiFi and bluetooth don't work Can be the kernel bad for my device . it is a beautiful Rom you made
                              Thank for the rom. Issues listed below.
                              1. Go to Settings. More settings. Home. 'Unfortunately, Settings has stopped'
                              2. Wifi is degraded. Internet Speed test normal (22-25MBps) with stock rom. This rom, max speed is 5-6MBps
