2º well in here works very good, in N i get 35-43MBps and on AC 150-235MBps (i have 1Gbps/100MBps internet connection) maybe to many wifi noise where you live? change in the router from 20Mhz to 40Mhz it helps a lot... other than that i cant help you wifi is one of those things...
[ROM] MXQ M12N Superceleron v1.0 Rom
1º i know still trying to find a fix for it... for now use the pop up to change the default "Home"
Originally posted by prahjisterhttps://download.cnx-software.com/in...i1Qcn0fvGd1VS3
Follow these instructions for enabling in first post
Only with root it will do the needed changes correct?
I think the gt 1 was not rooted yet
How do you unpack the original firmware and modify it, are there any guides on how to get started?
Update:
I found the following which explains how to unpack the boot.img and recovery.img with the OTA files.
http://www.cnx-software.com/2014/05/...irmware-files/
This appears to work for system.new.dat in OTA files, the sdat2img.py in the git repo works fine on linux.
http://forum.xda-developers.com/andr...asily-t3334117
However, there is also an image for the Nexbox A1 that is just one large file and its unclear how to unpack it, I think it might be a full emmc image?
973261572 Aug 18 14:50 NEXBOX-A1_S912_AP6330_16GB2GB_20160818.img
Several other firmwares appear to be the same way, eg the V88 Pro:
939301852 Aug 30 09:35 aml_upgrade_package.img
Looks like its this?
http://freaktab.com/forum/developmen...ge-img-img-rom
I have v2.0.8 and taking a look at it now, but I don't see how to actually fully unpack the image itself.
I suppose you could make all the changes inside that app itself instead of modifying the OTA image?Last edited by calc; 27 September 2016, 08:52.
Thank you for your efforts! Great Job!
It works on this one (OTT MXQ Plus):
http://freaktab.com/forum/tv-player-...wifi-bt4/page3
Only 2 issues remain, WLAN stops working occasionally (I have to check my AP could be a problem there) and DTS Audio (Passthrough SPDIF) makes less problems but it's still there.Last edited by mboka; 02 October 2016, 08:08.
Originally posted by azerty85 View PostHello,
He want to know if it's the same box as the Acemax M12N and who sell it.
Bye
Hi thanks for your work in producing this ROM.
I was having problems with the stock ROM, it was kicking me out of Kodi after I had finished watching a Program or Movie, but I could not find out the reason why.
I was hoping that your new ROM would fix this but unfortunately I am having the same problem.
I was wondering if you could help me with this problem, I know its not of your causing.
Thank you..
There are currently 2585 users online. 2 members and 2583 guests.
