[ROM] MXQ M12N Superceleron v1.0 Rom
    hmm lets see, thks for the info!
      Could anyone tell me where I might be able to find the "stock" firmware for the MXQ Plus? I can't seem to find it any where. I have even googled for it and can't find it.
      Edit: Never mind, seems the ACEMAX one is the only updated one. Thanks.
        Hello
        I just installed this beautiful rom.
        ACEMAX M12N
        I see it is written
        Bottom and upper bar fixed and added power to it.
        But I do not see the power button
        Thank you for your help
          The power button is there as you can see in the video!
            thank you very much
              Changing Home launcher works if replace with newest setting.apk.
              Any plans of updating your custom firmware?
                sorry but no i dont have the box anymore!
                  Edit: Please delete
                    Hi there guys and girls, one more rom... This is not the original stock rom... the only thing from the original is the kernel and the recovery.
                    My many thks to trebor for the beta test!
                    Changelog v1.0:
                    • Netflix playstore...etc... fully working
                    • Quick Boot!
                    • Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
                    • DRM widevine!
                    • Bottom and upper bar fixed and added power button to it.
                    • Proper rooted.
                    • Custom Kodi 16.1 Build. (Normal Kodi with my librtmp)
                    • initd.d support.
                    • Fully deodexed.
                    • Network tweaks. (On N networks bw around 30 to 42mbits, and on AC networks from 150 to 200mbits)
                    • Permissions fixed.
                    • Sleep working, full poweroff also working.
                    • Kodi Brightness fix (videos...)
                    • Passthrough fix apk ( thks prahjister for the apk)
                    • Removed the default launcher it have a lot of stability problems, you will loose the net led...
                    • Added a nice launcher!
                    • Other small fixes and optimizations!
                    Want to buy me a beer?Download:Install instructions:
                    • Download the zip (DON'T UNPACK IT)
                    • Put the zip in a USB Stick or a sdcard ( Better a USB Stick)
                    • Boot to recovey and choose "Apply update from EXT" then "Update from sdcard"(if you use the sdcard..) or "Update from udisk" (if you use USB Stick) and flash...
                    • Reboot and wait...
                    Where to buy:
                    1º BOOT TAKES AROUND 6 MINUTES!
                    AFTER THAT DO GIVE THE 1º BOOT 3 or 4 min TO INSTALL ALL APKS!
                    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
                    USE AT YOUR OWN RISK!
                    Here is a Video...
                    Enjoy it!
                    any chance we can get an ATV version of this rom or can you give me some direction as to what is required to do this? Maybe I can try to keep this rom up to date with your ATV versions?
                      sorry m8 but no if i ever get another i will do it but for now... maybe gearbest can send one who knows... but im now more inclined to one already with Droid 7...
                        Are you sure? It is not a new product and fewer and fewer people are buying it.
                        #1
                        Gearbest TV Box & Mini PC Page
                        #2 Flash Deals Flash Deals
                        #3Coupons Coupons, Coupons and More Coupons
                          Na forget it gearbest i was just thinking out loud...
                            we can save more time and energy for other devices!
                            #1
                              Gt1/alfawise SC ATV 6255wifi works with m12n. About remote, change the sc_remote.cfg to work with m12n remote. Power On is number 2 button.
                              Magendaz Atv also works with m12n just flash his 6255 zip then wifi will work also change the remote.cfg
                              Thanks to Devs our m12n is not dead LoL. MXQ abandoned this model, their last update was on dec. with no fix!
                                thanks!
