Mecool BB2 launcher
Hi drdedus & Matchless ,
if you two have "Root" and want to uninstall System Apps like Kodi or other Stuff , use a Rootexplorer go to System / App or preinstall / priv.Apps and delete what you want . As possible make a Dalvik
cache and Cache wipe after that and reboot . App from Store shall handle that or Recovery . Remember not all Apps can be uninstalled without problems , dont touch System relevant Apps .
Ask if you need more info .
nice Day to all
gefattern
I'm using the MECOOL HM8 box, so not sure if they are similar enough - BUT
I used ES File explorer, gave it permissions for SuperSu, and uninstalled the Kodi updater app easily. The super loud boot screen is annoying, but I try and remember to Mute audio on TV first - did get me a few nasty looks from the wife... I found that large "Builds" would cause an occasional kodi drop out, but KISS works. That 1 GB ram is limiting, imo.
I'm using HALauncher, but would prefer LeanBack launcher if I can find a version that will work. Have it on my similar Mi Media box, no problems.
What I really want is Bluetooth capability. Anyone have a good dongle idea for that, or other approach?
nice Day to all
gefattern
Originally posted by markedman View Post...... The super loud boot screen is annoying, but I try and remember to Mute audio on TV first - did get me a few nasty looks from the wife...
Originally posted by Matchless View Post
Have a look at post #29 on how to disable the startup animation and sound in the Settings for the BB2, maybe it works for you as well.
There are currently 1855 users online. 0 members and 1855 guests.
