CX-919 "Blank Internal Flash" Error after Running for Some Time
    Originally posted by phozac View Post
    Yes you are right, Strauzo kernel fix the problem with blank internal flash on cx-919 finless rom 4.2.2 1.4 :P
    So everyone.. if u have the problem, flash the test 2 kernel. it solves the problem
    please post download link!
        thanks!!!!!
          i could not wait for my china ethernet adapter.. so i went to a electronics store here in sweden bought a 10/100 ethernet adapter, it worked directly, but i only got 30 mbit, then i connected my usb hub to otg and then boom over 100 mbit. now i can stream 1080 p via smb trough network and have a decent internet connection the usb ethernet adapter is this one: http://www.konigelectronic.com/sv_se/1006645
          i use mx player with dts custom codec.. works fine
          mine doesnt came with otg cable or adapter, how do you connect the usbrj45 adapter?
            acctualy i bought a micro usb otg cable on **** a while back.. they are very cheap like 1 dollar.. and then i connect the ethernet to micro usb otg port.. could not get the right speed when i connected to the standard usb port on the cx-919..
              you can explain how to flahs the kernel? need to erase nand step or not?
              thanks
              im into Finles 4.2.2 and need to repair the nand blank error woth strauzo kernel!
              regards!
                thanks
                regards!
                and first, there are absolutly no reason to erase nand..
                1: download finless rom http://www.freak-tab.de/finless/cx919_422_finless14.zip
                2: unpack to desktop
                3: download kernel http://www.2shared.com/file/6kFXisAH...nel-test2.html
                4: unpack kernel into Desktop\CX919_4.2.2_Finless_14\FinlessROM\ and rename kernel-test2.img to kernel.img delete or rename the finless kernel.img who already is in that folder
                5: hold down fn button on cx and at the same time plugin in the usb cable to computer
                6: install drivers Desktop\CX919_4.2.2_Finless_14\drivers if u dont already have done that
                7: reboot
                8: hold down fn button on cx and at the same time plugin in the usb cable to computer
                9: open up C:\Users\phozac\Desktop\CX919_4.2.2_Finless_14\ and open ROM_Flash_Tool_137.exe
                10: untick everything besides RK3188Loader(L)_V1.20.bin and kernel.img
                11: hit flash rom
                  7: reboot
                  11: hit flash rom
                  wooa
                  i need to make a backup for my apps ( XBMC tunning mx player)
                  seems to reflash bobs rom and lose my settings :S
                  thanks!!!
                    wooa
                    thanks!!!
                    ok but.. you dont have to flash the whole rom???
                      IM now in finless 4.2.2...that the thing friend
                      if to flash the kernel need to reflash whole rom, i need to mede a backup jejeje
                      OTG port is working now with strauzo kernel?
                        do whatever u want man.. u dont seem to understand me..
                        "noo.. if u want to flash the kernel only u flash the kernel only.. no need for flashing the whole rom buddy.."
                        otg is now working yes.
                          AHH ok
                          i missunderstand you!
                          and to flash the kernel, what are the steps?
                          sorry for missunderstand you!
                            AHH ok
                            1:download kernel-test2.img from http://www.2shared.com/file/6kFXisAH...nel-test2.html
                            2:unpack it to a folder
                            3:rename it to kernel.img
                            go to your folder, \CX919_4.2.2_Finless_14\FinlessROM\
                            folder and replace the kernel.img in that folder with the one u have unpacked.
                            4: hold down fn button on cx and at the same time plugin in the usb cable to computer
                            5: install drivers Desktop\CX919_4.2.2_Finless_14\drivers if u dont already have done that
                            6: reboot
                            7: hold down fn button on cx and at the same time plugin in the usb cable to computer
                            8: open up \CX919_4.2.2_Finless_14\ and open ROM_Flash_Tool_137.exe
                            9: untick everything besides RK3188Loader(L)_V1.20.bin and kernel.img
                            10: hit flash rom
                              6: reboot
                              10: hit flash rom
                              doing that now!
                              thanks!!!!
                                doing that now!
                                thanks!!!!
                                np man good luck.. it's not rocket sience :P
