CX-919 "Blank Internal Flash" Error after Running for Some Time
Heat problem?
Originally posted by pee_bee View Post
instructions
Originally posted by kbuster View PostWell, I just purchased one of these earlier today and am a bit concerned by these comments about nand problems and possible heat issues. I hope I get a good unit. Where would one purchase heat sinks for these and how much would they be? Are you talking internal or possibly just an external "metal box" to pull heat away? Also if anyone is successful with formatting via cwm, could you give some detailed instructions on what to do for that? Just preparing myself to deal with it when it arrives.
I did'nt mean to create a panic about overheating - I would wait until the Engineer(s) have had more time to investigate the problem. Also it should be noted that although the error message is 'Blank Internal Flash...' after a reboot all is OK again - implying to me that the Flash is not blank but the operating system thinks it is.
Thanks phozac and the rest of the guys
Thanks phozac and the rest of the guys for testing different work-aroundsIf the formatting sd card seem to be working, i would think its more of a software problem than a problem with the stick.
@ kbuster - I am sailing in the same boat as you. Ordered mine a couple of weeks back and waiting for it to arrive. Hope there are no major issues by the time i receive mine
format question
Firstly, thanks for the quick responses to my concerns. Also, I had read this thread http://www.freaktab.com/showthread.p...ll-of-a-sudden where finless suggests a "reflash" to someone having BT issues. I'm wondering if this might work in lieu of a format which I assume wipes nand. Maybe, if finless develops a new rom, some of the current issues will be addressed. I'm hoping they are not hardware based as we'll be stuck with those.
Originally posted by phozac View Posthello.. first u need to flash finless rom.. http://www.freak-tab.de/finless/cx919_422_finless14.zip if u download finless rom u will have detailed instructions in the zip.. and after that u can flash cwm recovery if u want .. instructions are here: http://www.freaktab.com/showthread.p...-ROM-1-4/page4 and after that if u get the problem with blank internal flash, go in to recovery and format sdcard.. apperently that seems to be working for my mini pc..
Thanks phozac for sharing the cwm recovery method. I already formatted the sdcard as per instruction above. Will let it run and see whether the problem is gone. Thanks again for all those member who sharing their thought too!!
Saw a new post from geekbuying saying that there is a new stock firmware released. Not sure will it fix this problem too. http://www.FreakTab.com/showthread.php?p=78954
Sent from my Galaxy Nexus using Tapatalk 4 Beta
another thingie
another thing.. i have so bad speed on wifi now with my router and all.. so have bought a Ethernet adapter.. this one: http://www.****.com/itm/Plugable-USB...item2a2df6a4ec
do any of u guys know anything about it? if it works etc on cx-919?
i have seen on their site that they have linux drivers..
I have no problem with the wifi connection on CX 919. Saw this Ethernet adapter is actually listed as additional item for bundle purchase with the CX 919. Maybe this one for sure will work with CX 919? Just check it out.. http://www.geekbuying.com/item/High-...et-314264.html
There are currently 2631 users online. 0 members and 2631 guests.
