MK908 Insides + Cooling Mod (WARNING: Pic intensive)
Re: MK908 Insides + Cooling Mod (WARNING: Pic intensive)
Originally posted by TheDogg View PostI did not mean to offend anyone. I apologize if I offended anyone.
Typical Russian, sustainable means to us.
Typical Spanish .... I do not know mean something to us. You put two huge coolers on the case of the stick ..... so what can I say?
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Is it essential that you remove the reflector adhesive? I figure might as well leave it...
Also, I've got a small 20mm fan lying around, in your opinion do you think it would make much difference using it, and going through the trouble to hooking it up/tying the wires to a usb cord, etc?
Thanks,
A
Originally posted by TheDogg View PostTypical Russian, sustainable means to us.
(I once had a Russian-made 110V-220V step-up voltage converter. It was built of cast iron and weighed more than 5kg).Last edited by Molle; 11-06-2013, 10:01.
My cooling mod
This is my cooling mod (MK908 version II).
When I got my first MK908II, it crashed usually after 5-10 minutes of use, especially when watching videos. I opened the case and detact the cooler. There was small "burn" spot there on the CPU, I think the thermal paste was not applied to whole surface of the CPU (at the factory), so therefore part of CPU overheated for good... I tried to re-apply paste, but damage was already done.
I returned that and I got a brand new replacement from the Geekbuying. In this new device the original thermal paste was applied "a bit" better than in previous one, but there was still one corner (~7 mm area) without paste... I applied new paste carefully to whole CPU surface and made the following mod before the first boot of the new device - now it had worked perfectly stable
I got a computer fan with own PSU and bigger cooler. I put all in to some old plastic box, made holes to walls, so air can pass thru.
BTW: Does anyone know how to get CPU temperature data? Does this even have a CPU temperature sensor? I already tried "cpu temperature app by mooncakes" from Play store, its not working
Glued On Heatsink
Originally posted by thesawolf View PostI used a blow dryer on the heatsink for a couple minutes and twisted the heatsink right off without much trouble
From what I can see it seems to be only touching the chip in the center, but it has to be some kind of glue.
Guess I'll just try to give it some forced air cooling.
Heatsing was tightly connected on my MK908II also. Their thermal paste has very good glueing properties
I got it detached this way: first cool down or heat up the heatsink, you choice - I cooled it down. Grab on the edges of the heatsink with pliers, then rotate the heatsink gently - rotate on same level that heatsink is (CW/CCW), not up/down. Be careful not to bend circuit board or hit the parts of board with pliers. You may need to do slight rotations maybe over 5 minutes, then the paste-glue connetion becomes stressed and it detach very easily
There are currently 1300 users online. 3 members and 1297 guests.
