Kevin's V88-pro S905X Port
Hello Kevin,
First thank you for your work.
I need help
I downloaded the rom and flash the box in USB_Burning_Tool_v.2.0.8
in the configuration options i try without any options and with the option "erase flash > normal erase"
but in the 2 trys
after restarting the box, it does not start normally, it shows the amlogic logo and restart after this it enters recovery mode, and dont boot android
sorry my englishYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by kevin1341 View PostHi all, Here is my new firmware mod for the V88-Pro.
https://www.dropbox.com/s/hhauuzgjtr...61016.img?dl=0
Flash box with USB burn Tool.
Boot up box and root with ezroot.zip ( Thanks Finless) through update and backup app.
https://www.dropbox.com/s/wiswhh769c...zroot.zip?dl=0
Reboot box
Log into Google Play Store and install Youtube.
Open Youtube and when asked update Google Play Services.
This will update both play services and play store.
Install your apps as required.
I have flashed two boxes and they work well.
Cheers
Kevin
There are currently 1468 users online. 0 members and 1468 guests.
