Tronsmart S96 Android 6.0 Amlogic S912 4K TV Box 2G/16G AC WIFI Bluetooth 1000M LAN KODI
Good point, and right you are. So to whomever the intended recipient was, I hope the retailer gets it to them on the second try. :-)
Still, sending balbes150 one will be a plus for owners of the s96 and S912 owners in general.
I'm thinking it was probably intentional and they just wanted it to be a surprise.
Wow, so many people willing to take "someone else's"
By the way, checked the latest image Armbian (20170201) on S96. Sound and wired network working out of the box, the picture quality is in my opinion better than S905\S905X and smoother (possibly affected best performance chip). The next step I want to upgrade the case and cooling system (for extreme use with maximum load).
Corrected test image (which is able to automatically adjust the CPU frequency). If anyone is interested, you can see a video of the S96 auto-adjust the CPU frequency.
IMHO the case you need to finalise for ventilation (hot exhaust air). Although this "disease" all TV consoles. If you want the most from TV box to finalise. And the potential S912 - good.
Originally posted by balbes150 View PostPS Maybe the parcel was sent to me by mistake and was intended for another user, but while I have it - will test and bring Linux to S912.
-And if it was my TV-box, I certainly wouldn't mind the mistake! =)
Furthermore, you couldn't do anything better than sharing it with everyone by making Linux run on it.
In Hoth tests Armbian on S96, discovered an interesting nuance. If you select the menu "off" - the system shuts down, the indicator for 1 second lights up red and immediately starts the system startup (the lamp again to light blue). If you choose to impute to "Suspend", the system immediately turns off the screen, and as it shuts down, the indicator turns red, but after a second the screen turns on and the screen returns to the desktop in the same form as was at the time you select this mode, and the system continues to run (led is red). After that, choose "off" , the system exits gracefully and console off (the led continues to glow red). When you press on the remote control the power button starts the run and the system start (led turns blue).
Perhaps it is known to all, but ... found (for me) one more thing, which explains the peculiar behavior of S96 at shutdown. When you long hold the "On\off" on the remote control unit is forced to power off (not shutdown, namely cutting off the power like on a PC if you hold the PC power button over 4 seconds). Similarly behaves Tronsmart Vega S95 Telos. Just for the Telos console off with a long hold any button on the remote control that often causes problems in normal operation, i.e. scroll through the list with the remote to telos (keep the cursor button) and then the console completely powers off spontaneously.
Alteration of the cooling system. Disassembled the case. I drilled the hole. Tape on top of the fan. Cut the front wall of the housing (I need it for my other tests). Alternatively, make slits or holes on the right side wall (you can even put a nice sign). Plugged the USB into the rear port. When you turn on the console fan is turned on when turning off automatically shuts down. Pay attention - use standard regular radiators. Especially while she was left to check in this condition. When testing under full load, the temperature does not rise above 60-68 degrees. Normal mode and idle to be in the range of 35-55 degrees.
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
There are currently 1545 users online. 2 members and 1543 guests.
