Tronsmart S96 Android 6.0 Amlogic S912 4K TV Box 2G/16G AC WIFI Bluetooth 1000M LAN KODI
    Update images Armbian (Ubuntu \ Debian) kernel 3.14.29. (20170701)
    Changes - added driver for qca9377. Its use is similar to the module "dhd" and "wifi_dummy". To check loaded, with the command "modprobe qca9377" if a WiFi network will work with it, write its startup in /etc/modules.
    I checked on the model Tronsmart S96 (s912) - with this module the WiFi and BT working. By the way, I didn't even need to manually copy the dtb file, the system could earn with regular dtb from the internal memory.
