We ask gearbest if they know of this 05 version for device?
S905X wifi issues
Hmmmm that wierd 05.... But heres note same firmware. Update state..... Once update finish do FULL factory reset. I wonder if those no or slow wifi from that.
Originally posted by scooter2014 View PostHmmmm that wierd 05.... But heres note same firmware. Update state..... Once update finish do FULL factory reset. I wonder if those no or slow wifi from that.
Originally posted by damod11 View Post
Gearbest said they never sold the 2gb 8/16gb t95x. So they wont know of .....05 update.
oh i have the build date info..... ive searched google for like a half an hour and nothing..... is there not a way to just extract the firmware from a fresh unpackaged box. I swear the box has been running great even with live streams while on wifi ABSOLUTELY NO PROBLEM... however we have the play store problem back... but only somewhat. if you would like to see the p212 build let me know
I know.. In stuck there... I wish I knew how to extract the firmware I would post it...
I can't update either. So I have 3 on ...04 ansandboxes on ...05. If anyone knows how to extract it in all ears.
Originally posted by QuestE View PostThe T95X unfortunately for you is just a really bad box. For me I found that physically flipping the box bottoms up gets you better wifi signal which upon looking closer I found it was a design issue, the internals of the box are most likely flipped upside down. (even though the ports are technically made the right way) Give it a try and let me know the results just so I can confirm it wasn't just with me, good luck!
If your 905x chipset has the ap6330 wifi, then try this custom rom. I have a nexbox a5 with that chipset and this new rom fixed many issues and I get 43 mbps download speed consistantley on my asus ac 1200 router. also check your channels for the best one to use on wifi. I use the 5g band and it always around 42-43 mbps download, at least 30 feet from router.
There are currently 2388 users online. 0 members and 2388 guests.
