S905X wifi issues
Originally posted by QuestE View PostThe T95X unfortunately for you is just a really bad box. For me I found that physically flipping the box bottoms up gets you better wifi signal which upon looking closer I found it was a design issue, the internals of the box are most likely flipped upside down. (even though the ports are technically made the right way) Give it a try and let me know the results just so I can confirm it wasn't just with me, good luck!
Originally posted by scooter2014 View PostOk now i find same thing. Can you copy your build prop and post? See if same as box i find issue on.
@dutchmaster18 - While looking for a firrmware update saw this post and have same issue.
I have 2 boxes, a tanix tx5 pro and a sunvell T95X - both have S905X chip.
I have a Cisco 1131AG access point.
Sunvill - no issues - connects 54Mbps and never changes - signal strength always excellent after hrs of use.
Tanix TX5 Pro - boots up and connects at 54Mbps signal strength excellent, not long after using, start getting audio/buffering issues. check wifi and its drops down to 11Mbps but signal strength always excellent. Even just watching a youtube video it drops and fails on HD videos.
Tested with my old netgear ADSL router, Tanix TX5 Pro doesn't have this issue, connects at 54Mbps and stays there, never drops.
I've change my config on my Cisco access point to only offer 48 & 54Mbps and the Tanix TX5 pro always starts off at 54Mbps but always finds it way back to 48Mbps but can never go any lower.
I even thought maybe interference on the 2.4G freq, the Cisco AP can scan to see what is in use around you but it wasn't. Tried 5G freq, tanix tx5 pro keep dropping until it failed, no one near me using the 5G freq range.
Suspect more firmware issue, hence why looking for an update.
Originally posted by dutchmaster18 View PostT5X10005 Update has finally ally fixed all WiFi issues... I noticed this when I ordered more boxes. So the problem has been addressed I just wish I knew what it was.
Im on version T5X10004.
Originally posted by damod11 View Post
I cant download this OTA. My t95x saying no update or already up to date. Where did you get this update dutchmaster ? Is it available for download somewhere ?
I can't update either. So I have 3 on ...04 ansandboxes on ...05. If anyone knows how to extract it in all ears.
There are currently 2408 users online. 0 members and 2408 guests.
