Khadas Vim TV Box Amlogic S905X Quad-core (One for the Geeks) Now with Android 9
Originally posted by KAA View Post
#1 Gearbest TV Box & Mini PC Page
#2 Flash Deals Flash Deals
#3Coupons Coupons, Coupons and More Coupons
Your assumption of Chinese New year is cutting it fine I feel, and will stand corrected if that is the case
But as the deal is not active I think it has been answered.
Can we now keep this thread on topic, and keep Individual customer matters in the resellers thread
Thank You.
A review of the Vim here http://mediaplayers.gr/khadas-vim/
Looks like a worthy alternative to pi3
Got my Khadas so far so good expect the color is fair bit dimmer than my other devices when connected to tv doesn't seem to be any options under display settings like you would usually find with Android have tried latest Android firmware aswell but problem still persists. I'm guessing no-one else has experienced this problem since I haven't seen it mentioned before?
Also Khadas has released dual-boot..
Is there any screen recorder that works on arm?
I have tried to install simple screen recorder, added ppa, but when i try to install using apt-get, i get a message that it's unable to locate package directory.
I am not even sure is the hw even capable enough to run it, but i want to be sure, so if anyone can help?
Originally posted by Tommy21st View PostIs there any screen recorder that works on arm?
1. run synaptic
2. update\reload
3. search and install "kazam"
Originally posted by balbes150 View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yesterday I got the VIM model (2/16). Thank you members of Khadas for the sample. First impressions - very positive. I note the original design of the body, very useful for me, as it will make it easy to change for different tasks. I hope now I will be able to fully optimize my design for this platform.
Now checked the latest image (desktop MATE 20170205) on VIM. Activated-boot console UART (full firmware with Android remains unchanged, and disconnect the external drive continues to work as before). Launched system to the USB flash drive. The Sound Is OK. Wired network is OK. WiFi - is Ok. By the way, both band 2.4 and 5 GHz (router enabled 5 GHz band for China) without manual settings. At many TV consoles 5 GHz from the box not working. While playing a test video (without scaling) the temperature was about 60 Degrees. I believe that for normal operation is necessary the cooling system. Ideal - a radiator + fan. I think after a complex modernization of the cooling system, this device can operate at full capacity, fully justifying its price and having the significant potential to perform different tasks. I think the presence on the one hand opportunities for development, on the other a single platform with a massive TV consoles make this device very interesting for a wide range of users (not necessarily developers).
There are currently 1984 users online. 2 members and 1982 guests.
