Khadas Vim TV Box Amlogic S905X Quad-core (One for the Geeks) Now with Android 9
In a new thread with full changelog etc.. i still finishing the rom when its done i will post it.. RISCy Dude and trebor already tried it
Yes tapatalk is broken!Last edited by superceleron; 04 March 2017, 22:37.
Just testing the t10 release of this Rom, Excellent
Doing all that it should, more testing wont be long
Another super rom you could say superceleronaROMLast edited by trebor; 05 March 2017, 06:59.
I'm not good at Android, and almost never use live TV. But checked out the launch of the t9 option on VIM. In my opinion it works well enough. I wanted to clarify. Because it was originally planned that there were no service updates ? I wanted to activate the multi-boot, but when I try to open the service "Update" I get this message on unavailability of the service. On VIM I decided through the console UART.
By the way, if you have a multi-boot you can easily install any system on the internal memory as a full firmware (you can also add some adjustment) without using the USB cable and USB BTool.
Originally posted by balbes150 View PostI'm not good at Android, and almost never use live TV. But checked out the launch of the t9 option on VIM. In my opinion it works well enough. I wanted to clarify. Because it was originally planned that there were no service updates ? I wanted to activate the multi-boot, but when I try to open the service "Update" I get this message on unavailability of the service. On VIM I decided through the console UART.
By the way, if you have a multi-boot you can easily install any system on the internal memory as a full firmware (you can also add some adjustment) without using the USB cable and USB BTool.to many devices to maintain!
hmm you mean flash the firmware by sd?
yes the plan is not to have service updates, because im not going to be doing lots of work on itto many devices to maintain!
I mean the ability to launch the application "Update&Backup" or a similar service, that it was possible to log into recovery mode to run arbitrary script aml_autoscript. For example , to activate multiboot
There are currently 2349 users online. 0 members and 2349 guests.
