as you mentioned something will come from Khadas, or other units, hack an old usb cable
Khadas Vim TV Box Amlogic S905X Quad-core (One for the Geeks) Now with Android 9
Khadas team is very helpful, they reply very fast, but most of the time they don't understand what i'm talking about.
I am not from US-UK, and English is not my native language, but i think i speak it well, but when i read posts written by khadas mods, it's like they are using google translate when reading or answering.
It is easier to ask here, at least for me.
No trouble following your drift, Tommy, you come across just fine. And yes, there are some very capable and helpful Freaks on the forum. Gouwa and the Khadas team are making great efforts to keep up with our early user experiences with the Vim. IMHO, only the Zidoo crowd and the Ugoos folk can compare in terms of know-how and interest - most box-makers have forgotten what their products look like or do by the time they reach us...
Originally posted by Tommy21st View PostKhadas team is very helpful, they reply very fast, but most of the time they don't understand what i'm talking about.
And our team will try to improve our English level.
If, like me, you're not satisfied with only 1080p in YouTube, there's a fix. Edit build.prop (system folder) by adding this line (without quotes) at the end under Additional_Build_Properties:
"sys.display-size=3480x2160". Save the file and reboot. You should now find you can select 1440 and 2160 as a quality option when playing 4k videos on YouTube.
One question, bought a micro sd card class10, uhs3, 32gb, inserted it with some no name sd reader, usb 2.0 on win10, no response from windows.
I tried to go to disk management, it shows only letter , no memory info, nothing about partition.
Card is inserted directly on the usb, it means it has no sd adapter, reader worked on my older 8gb uhs1 sd card with no problem 5 minutes before.
I bought this card for khadas, and ordered some usb 3.0 card reader which i'm still waiting, it was ordered month and a half ago from gb, same day i preordered khadas.
Card was tested on Vim, it worked, so could it be that the usb reader is limited to something, memory capacity or maybe the uhs3 isn't compatible with slow usb 2.0 readers.
I am scared now that it won't work when i get the new reader, i bought it to boot OS images from it, and if i can't flash anything on it, then the card will be useless.
Originally posted by Tommy21st View PostOne question, bought a micro sd card class10, uhs3, 32gb, inserted it with some no name sd reader, usb 2.0 on win10, no response from windows.
a. Type cmd in start search box then right click on cmd and click on run as administrator.
b. when cmd opens, type diskpart
c. After that type "list disk".
d. Select the disk of your SD card.
"select disk 5"
e. Type clean.
f. Type "create partition primary".
Then go into your disk manager and format it.
Edit: Under step "d", use your own disk number, it probably be anther Disk number, i have a total of 4 physical hard disk in my computer, so that is why my sd card is listed as disk 5.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12
Give this a try. Partition using the command prompt.
"select disk 5"
e. Type clean.
Does your no-name reader get warm? Does it show up at all (with or without a yellow exclamation mark in Device Manager?) If it gets warm, the reader may be faulty or incompatible with the card. If there is any entry for it in Device Manager, uninstall it and let Windows try to detect it again after reinserting it. Try cleaning the contacts in the reader too.
There are currently 2864 users online. 3 members and 2861 guests.
