HPH NT-N8 RK3229 Marshmallow ROM by mo123
Originally posted by m1pnk View Postlove it... top work Mo.
I think Android TV works well with a remote, much faster to navigate and looks modern.
NTMC Media Center with it's Android TV interface also blends in well with the launcher.
For normal apps there is the Sdeload Launcher that can run normal apps.
If you know of any interesting normal Android apps that I can convert into Leanback launcher tiles, I can make a few apps so it show on the main launcher screen instead of Sideload Launcher.
Android TV Play Store don't have that many apps I could find but it is probably still expanding.
Good rom, thanks.
So my "green screen" issue..... just had to reset the box
What I've found thus far...
The Home and Recent buttons - does nothing.
If I try to add a new google account the settings app crashes.
When trying the reboot app under the sideload launcher, said something about root required.
You can go to leanback launcher and open the normal Settings app.
Under Accessibility Options there is a 'root system' setting.
To install normal apps you can do it manually or from Nagrace Market, they will appear under leanback launcher.
You can also try to hold in the power button on the ir remote, it should show a menu shutdown or reboot.
On v1.3 firmware which is the same as Android TV but just with normal Google apps, the bottom home, recent buttons work and also on the ir remote.
Â
Originally posted by minixfreak View Postcan we get the tv release to do 4k resolution for everything ... i know it can play 4k videos but we need 4k resolution
The framebuffer also only runs at 720p or 1080p if you change it.
It runs too slow at 4K resolution(if UI resolution changed, framebuffer still run at lower resolution) and also cause problems for 1GB RAM devices.
The CPU and GPU is just not powerful enough.
The only device that can run everything at 4K is the Nvidia Shield, I don't know of any other Android device that can.
I think only RK3399 will be able to run everything at 4K(framebuffer and UI).
Video playback is a different matter as the 4K video playback is handled by the VPU that has it's own processing power just for video.
Originally posted by minixfreak View PostI installed a custom ROM on my dolamee d5 everything works fine except DTS audio in ftmc ... Would ur ntmc correct that issue ? DTS sound would cut out every 4 secs
You also need MM since Lollipop doesn't support DTS out of the box except if the LP firmware was patched by the manufacturer(which is missing in your case).
Don't think so, you need a proper supported device with new firmware to get perfect audio in sync in combination with RKMC/NTMC/FTMC.
It seems you are doing a great work with this box... I have checked the specs and it seems that the NT-N8 box uses an AP6210 or AP6255 as wifi chipset... I have a MX4 box with an RTL8723 wifi chipset... Is it possible to add this wifi driver to the ROM? Will it boot on my box?
Thanks and keep the great work!
There are currently 2022 users online. 0 members and 2022 guests.
