HPH NT-N8 RK3229 Marshmallow ROM by mo123
Originally posted by gefattern View PostHi Mo123 ,
if you need help with DE translations or you are not sure if they are correct , i can help , if needed .
greetings / gefattern
I'll make some screen-shots, then you can check it.
Originally posted by 1stTiger View PostCould you explain how the .img file was generated? What steps were taken to create this ROM?
The Firefly link given fails to tell how the the source code at https://gitlab.com/TeeFirefly/FireNo...firefly-rk3399 was generated. Also, the .git folder in the beginning. How is that generated and where is it pulled from?
@mo123
You have to ask the manufacturer of your device for the source code for their specific device, each device is different and to convert the git/repo to normal files.
Or buy a development board then you can get it easier.
@mo123
I'm trying to make an ATV rom for the rk3229. So far, so good. But I have a problem and would like to know if you can help me. Every video stream (Youtube, Twitch) keeps freezing and only the audio continues. I don't know if is some codec problem, kernel problem, MALI drivers... Can you give me some light?
There are currently 3835 users online. 2 members and 3833 guests.
