HPH NT-N8 RK3229 Marshmallow ROM by mo123
Hi, mo123.
I'm trying to adapt your firmware for another RK3229 device. Now I'm working on wifi module, it's not working on your ROM. Could you help me to insert drivers for RTL8723BS to this ROM?
Also, it's a little strange AFR works. On my mini M8S when device changes framerate, my TV changes framerate to (I see it at OSD of my TV). But when my RK3229 device changes framerate, I see the display mode was changed, but my TV did not. Is it normal for Rockchip based devices AFR?
And last, I confirm the language issue. When I change the language, settings menu is still on English.
Thank you for your ROM.
Rockchip RK3328 devices like MVR9 I now use fully support auto frame-rate and HDR.
Iconbit will have to fix their stock firmware to work better, I don't have time to fix their problems or port their drivers to my ROM's even if I knew how since they still run outdated Lollipop.
RKMC supports auto-frame rate on supported RK3229 devices with good firmware, other players do not at this stage.
I'm not asking to fix any problems. I just ask you to add support RTL8723BS wifi chip to your ROM. I'm not so good at this for doing it by myself.
Anyway, your ROM is better for Iconbit than stock ROM. Thank you.
Nougat Test ROM
- Fixed wifi
- Fixed IR Remote
- Fixed Home button
- Fixed Canal+, Molotov TV, DSTV Now, other streaming apps
https://mega.nz/#!lQd2kISL!3nEnEz3bp...tFXao-ZmOcY-q8
Flashing Instructions
- Load the firmware in the second tab of AndroidTool then
- EraseFlash
-Upgrade
- Wait around 5-8 minutes for the firmware to be installed for the first time and to boot to the Android Homescreen.
After booting, upgrade all the apps through Google Play Store, including Google Play Services.
There is a lot of bloatware and launcher I can't remove then it doesn't boot anymore.
There are several other bugs I noticed in this firmware that is fixable but only if you have source code.
I hope I will be able to make my own fully optimised firmware in future.Last edited by mo123; 18 January 2018, 10:44.
Hello i have a M8S TV Box coming original with Android 7.1.2 but is performing very poor lagging - not working Kodi, can i use this firmware for my box ??? the specs of my Box is:
rockhip v88
720x1280
rk30boad
wifi:ssv6051
sound:rkrk322x
ram: 1gb
cpu: rk3229
android 7.1.2
thank you
I Have problem android tool says failed loader and now is not power up the device :/ anyone can help me???
No led is Lighting
i open the device and says mx4vb-v02 ww17090029
A170909
nand chip ?? 7MG22 NW814Last edited by natsisan; 13 February 2018, 21:05.
There are currently 3967 users online. 0 members and 3967 guests.
