TRWP. 3229 Devices Followmsi.
Originally posted by bluesmanuk View PostFlashed it to the Dolamee D5 and Nexsmart D32 and whilst it will boot into recovery, you can only mount cache, data and metadata.
It also only takes up about a 10th of the screen in the top left corner.
The TWRP version is based on RK3368 sources and it´s compiled for 1920x1200 resolution.
Normally you should be able to mount all your partitions.
Of course, the fstab has to match your hardware.
Never tested TWRP on 4K .. on my QHD / WQHD (2560×1440) Monitor and my FullHD TV it´s working fine.
On top it´s configured to prevent HMDI overscan on certain older TV´s -> scale 95% only.
Pls post stock recovery of one of your RK3229 devices .. would like to check the fstab.
Thx
Originally posted by followmsi View Post
Thanks for testing and feedback.
Thx
This is the stock recovery for the D5.
https://www.dropbox.com/s/evqwabv3dhu3pkg/recovery.img?dl=0R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thanks for the updated version.
When attempting to boot into recovery the boot logo comes up and stays active for about 9 seconds.
Then the screen goes black for around 3 seconds, followed by a brief reappearance by the boot logo before the normal boot process to system starts.
Originally posted by scooter2014 View PostWas fstab the issue? Ill test tonight too.
The fstab file was correct .. some minor issues.
Should be possible to mount system and data as well.
Try to make a backup of data or system partition.
The linuxroot partition is still part of fstab.
As well the "user" partition from Android 5.1 for non-unified-storage systems.
There will be an error message if you don´t have dual OS system or running on Android 6 - can be ignored.
If you are able, pls post recovery.log for better troubleshooting. ( adb pull /tmp/recovery.log )
Originally posted by bluesmanuk View PostTried the latest version and this time I was able to boot into recovery.
Same position as with the original though in that only the 2 partitions will mount.
They are on the same disk.
Pls post recovery.log while you have booted into TWRP .. adb connection is required.
Code:adb pull /tmp/recovery.log
Code:adb shell ls -la /dev/block/platform/*/by-name
Code:adb shell cat /proc/partitions
See if these are useful.
https://www.dropbox.com/s/h7dlnd6bo6dy88z/RK3229%20TWRP%20data%20logs.zip?dl=0R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 1912 users online. 1 members and 1911 guests.
