TRWP. 3229 Devices Followmsi.
    followmsi
    I am taking this step by step. as slow as possible make sure I dont miss anything. (Ive been having a few issues backup appears to work normal, but restore causes system to hang on logo image (before bootanimation)
    I have started fresh and worked through step by step
    I am to the point of
    install Update.ZIP_TWRP_RK3229_3.1.0-0_170318.zip
    and saw a error come up while flashing.
    I continued on
    install SuperSu-forced-system-mode.zip
    I created the new-system.img
    and copied the recovery.log file
    after a reboot I pulled the recovery.log file and checked through and found the following
    Code:
    I:operation_start: 'Flashing'
    Installing zip file '/usb-otg/TWRP/Update.ZIP_TWRP_RK3229_3.1.0-0_170318.zip'
    Checking for MD5 file...
    Skipping MD5 check: no MD5 file found
    I:Update binary zip
    I:Zip does not contain SELinux file_contexts file in its root.
    I:Legacy property environment initialized.
    Install TWRP ..
    about to run program [/sbin/e2fsck] with 3 args
    e2fsck 1.42.9 (28-Dec-2013)
    Pass 1: Checking inodes, blocks, and sizes
    Pass 2: Checking directory structure
    Pass 3: Checking directory connectivity
    Pass 4: Checking reference counts
    Pass 5: Checking group summary information
    system: 1977/3072 files (3.2% non-contiguous), 622178/1048576 blocks
    about to run program [/sbin/resize2fs] with 2 args
    resize2fs 1.42.9 (28-Dec-2013)
    The filesystem is already 1048576 blocks long.  Nothing to do!
    bootmode = emmc
    bootmode = emmc
    recovery filesystem table
      0 /mnt/internal_sd vfat /dev/block/platform/ff0f0000.rksdmmc/by-name/user 0
      1 /mnt/external_sd vfat /dev/block/mmcblk1p1 0
      2 /system ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/system 0
      3 /cache ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cache 0
      4 /metadata ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata 0
      5 /data ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata 0
      6 /cust ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cust 0
      7 /custom ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/custom 0
      8 /radical_update ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/radical_update 0
      9 /misc emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/misc 0
      10 /uboot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/uboot 0
      11 /charge emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/charge 0
      12 /resource emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/resource 0
      13 /parameter emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/parameter 0
      14 /boot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/boot 0
      15 /recovery emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/recovery 0
      16 /backup emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/backup 0
      17 /trust emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/trust 0
      18 /baseparamer emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/baseparamer 0
      19 /tmp ramdisk ramdisk 0
    minzip: Extracted 2 file(s)
    ApplyParsedPerms: lsetfilecon of /system/etc/install-recovery-2.sh to u:object_r:system_file:s0 failed: Operation not supported on transport endpoint
    script aborted: set_metadata_recursive: some changes failed
    Updater process ended with ERROR: 7
    I:Legacy property environment disabled.
    I:Install took 4 second(s).
    Error installing zip file '/usb-otg/TWRP/Update.ZIP_TWRP_RK3229_3.1.0-0_170318.zip'
    Updating partition details...
    I:Data backup size is 647MB, free: 5252MB.
    I:Unable to mount '/external_sd'
    I:Actual block device: '', current file system: 'vfat'
    ...done
    I:Set page: 'flash_done'
    I:operation_end - status=1
    I dont know (not educated enough yet to know if that is a issue or non issue.
    I also pulled the new-system.img down and I will be repacking a new firmware image with that new-system.img.
    Ill keep you posted.
      Originally posted by tacotime82
      followmsi
      I am to the point of and saw a error come up while flashing.
      I continued on
      Code:
      I:Update binary zip
      Install TWRP ..
      bootmode = emmc
      bootmode = emmc
      ...done
      minzip: Extracted 2 file(s) ApplyParsedPerms: lsetfilecon of /system/etc/install-recovery-2.sh to ubject_r:system_file:s0 failed: Operation not supported on transport endpoint script aborted: set_metadata_recursive: some changes failed set_metadata_recursive: some changes failed Updater process ended with ERROR: 7 I:Legacy property environment disabled.
      This is an issue with update script ..To set the correct the correct permissions to execute the file.
      Will check this ..
      But more important is the supersu installation ..
      Once done do the DD of the system.Img.
      On your PC you can loop mount the system.img and copy the TWRP files into the system.img .. and check the permissions of the etc/install-recovery-2.sh script.
      You need to get the files into the system.Img.
      Good luck.
        Just wondering if the error might be related to the recovery filesystem table reffering to "ff0f0000.rksdmmc" not "30020000.rksdmmc"
        Any way
        Here is the log of the supersu installation
        Code:
        Installing zip file '/usb-otg/TWRP/SuperSU-v2.79-201612051815-forced-system-mode.zip'
        I:Update binary zip
        SuperSU installer
        - Mounting /system, /data and rootfs
        mount: mounting /dev/block/mmcblk0p15 on /data failed: Device or resource busy
        2+0 records in
        2+0 records out
        3+0 records in
        3+0 records out
        12+0 records in
        12+0 records out
        3+0 records in
        3+0 records out
        /tmp/updater: line 940: /system/toolbox: not found
        - Extracting files
        Archive:  /usb-otg/TWRP/SuperSU-v2.79-201612051815-forced-system-mode.zip
           creating: arm/
           creating: arm64/
           creating: arm64/chromeos/
          inflating: arm64/chromeos/futility
          inflating: arm64/libsupol.so
          inflating: arm64/su
          inflating: arm64/suinit
          inflating: arm64/sukernel
          inflating: arm64/supolicy
           creating: armv7/
          inflating: armv7/chattr.pie
          inflating: armv7/libsupol.so
          inflating: armv7/su
          inflating: armv7/suinit
          inflating: armv7/sukernel
          inflating: armv7/supolicy
          inflating: arm/chattr
          inflating: arm/chattr.pie
          inflating: arm/libsupol.so
          inflating: arm/su
          inflating: arm/suinit
          inflating: arm/sukernel
          inflating: arm/supolicy
           creating: common/
          inflating: common/000000deepsleep
          inflating: common/99SuperSUDaemon
           creating: common/chromeos/
          inflating: common/chromeos/kernel.bootloader
          inflating: common/chromeos/kernel.config
          inflating: common/chromeos/kernel.keyblock
          inflating: common/chromeos/kernel_data_key.vbprivk
          inflating: common/file_contexts_image
          inflating: common/frp_install
          inflating: common/hexpatch
          inflating: common/init.supersu.rc
          inflating: common/install-recovery.sh
          inflating: common/launch_daemonsu.sh
          inflating: common/Superuser.apk
           creating: META-INF/
          inflating: META-INF/CERT.RSA
          inflating: META-INF/CERT.SF
           creating: META-INF/com/
           creating: META-INF/com/google/
           creating: META-INF/com/google/android/
          inflating: META-INF/com/google/android/update-binary
          inflating: META-INF/com/google/android/updater-script
          inflating: META-INF/MANIFEST.MF
           creating: mips/
           creating: mips64/
          inflating: mips64/libsupol.so
          inflating: mips64/su
          inflating: mips64/suinit
          inflating: mips64/sukernel
          inflating: mips64/supolicy
          inflating: mips/chattr.pie
          inflating: mips/libsupol.so
          inflating: mips/su
          inflating: mips/suinit
          inflating: mips/sukernel
          inflating: mips/supolicy
           creating: x64/
          inflating: x64/libsupol.so
          inflating: x64/su
          inflating: x64/suinit
          inflating: x64/sukernel
          inflating: x64/supolicy
           creating: x86/
          inflating: x86/chattr
          inflating: x86/chattr.pie
          inflating: x86/libsupol.so
          inflating: x86/su
          inflating: x86/su.pie
          inflating: x86/suinit
          inflating: x86/sukernel
          inflating: x86/supolicy
        supolicy v2.79 (ndk:armeabi-v7a) - Copyright (C) 2014-2016 - Chainfire
        File [/sys/fs/selinux/policy] does not exist!
        - Rockchip Android M workaround to force SuperSU System mode installation -> Pls check for System mode 2 lines below !!!
        - Detecting system compatibility
        sukernel v2.79 (ndk:armeabi-v7a) - Copyright (C) 2014-2016 - Chainfire
        Loading from [/dev/block/mmcblk0p7] ...
        Could not find header
        - System mode
        - Disabling OTA survival
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/bin/su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/sbin/su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /vendor/sbin/su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /vendor/bin/su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /vendor/xbin/su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/xbin/sugote
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/xbin/sugote_mksh
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/xbin/ku.sud
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/xbin/.ku
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/xbin/.su
        /tmp/supersu/armv7/chattr.pie: No such file or directory while trying to stat /system/lib64/libsupol.so
        /tmp/supersu/armv7/chattr.pie: Operation not supported on transport endpoint while reading flags on /system/bin/install-recovery.sh
        - Removing old files
        rm: cannot remove '/data/su.img': No such file or directory
        rm: cannot remove '/cache/su.img': No such file or directory
        - Creating space
        - Placing files
        mkdir: cannot create directory '/system/bin/.ext': File exists
        rm: cannot remove '/system/bin/.ext/.su': No such file or directory
        rm: cannot remove '/system/xbin/su': No such file or directory
        rm: cannot remove '/system/xbin/daemonsu': No such file or directory
        rm: cannot remove '/system/xbin/supolicy': No such file or directory
        rm: cannot remove '/system/lib/libsupol.so': No such file or directory
        rm: cannot remove '/system/app/SuperSU/SuperSU.apk': No such file or directory
        rm: cannot remove '/system/etc/install-recovery.sh': No such file or directory
        rm: cannot remove '/system/etc/init.d/99SuperSUDaemon': No such file or directory
        /tmp/updater: line 1571: cannot create /system/etc/init.d/99SuperSUDaemon: nonexistent directory
        chown: /system/etc/init.d/99SuperSUDaemon: No such file or directory
        chmod: /system/etc/init.d/99SuperSUDaemon: No such file or directory
        - Restoring files
        - Post-installation script
        rm: cannot remove '/system/toybox': No such file or directory
        rm: cannot remove '/system/toolbox': No such file or directory
        - Unmounting /system
        - Done !
        I:Updater process ended with RC=0
        I:Data backup size is 646MB, free: 5254MB.
        ...done
        I:operation_end - status=0
        To my untrained eye it looks normal.
        I will (once the new-system.img file is transferred) mount the img and look into the files.
        Any help on what I should be looking for, what permissions should be, would be greatly appreciated. Ill try to read through the log file and confirm what I should do.
          Havent had a chance to look into the new-system.img yet. But I wanted to test the operation of the TWRP for backing up and restoring partitions. So I selected a backup of a system and data partition
          and saved log file.
          Rebooted, made a few changes to the system to check if restore worked.
          Back to recovery,
          Directly to restore. Selected the backup I had just made and hit restore.
          Everything appeared normal durring
          I again pulled the log file
          And rebooted.
          The device hangs right at the logo img display. Waited a long time (20 min or so)
          Unplug and retry again nothing, just boot img...
          Not looking good.
          Could this be caused by something I have done wrong, I have no idea. Verry frustrated. I should have tested this earlier before...
          Anyway I have posted the logs
          recovery-TWRPupdate-SUupdate-Zips-installed.log is taken directly after the first fresh install of the TWRPupdate.zip and SUupdate.zip
          Then I rebooted, Made sure everything worked.
          recovery-first-backup.log was taken directly after the backup of the system
          Again rebooted confirmed operations. Changed a few items and rebooted to recovery.
          recovery-first-restore.log taken directly after the restore...
          After words, it failed to boot.
          Also located in that folder is partition info recovery.log was just for my referance just the partition table extracted out from a recovery log.
          I am going to take a break. Stop working for a while. maybe have a drink. Anyway thanks for all of your help with everything.
            and saved log file.
            Back to recovery,
            And rebooted.
            Not looking good.
            https://drive.google.com/open?id=0Bw...VI1ZHZZMGRjVjQ
            Made a new TWRP version ..
            Update.ZIP_TWRP_RK3229_3.1.0-0_170319.zip
            TWRP_RK3229_3.1.0-0_170319.img
            Changed the Update-zip code to ..
            Code:
            set_metadata("/system/etc/install-recovery-2.sh", "uid", 0, "gid", 0, "mode", 0755, "capabilities", 0x0);
            Tested it on geekbox .. no error 7 anymore.
            Anyway .. the file is located in /system/etc/ and has rights to be executed ...
            Pls verify via adb shell ..
            Here I made fresh install - over my existing supersu installation.
            Code:
            :# adb shell ls -l /system/etc/install*
            -rwxr-xr-x    1 root     root           188 Aug  1  2008 /system/etc/install-recovery-2.sh
            -rwxr-xr-x    1 root     root           629 Mar 19 11:41 /system/etc/install-recovery.sh
            -rwxr-xr-x    1 root     root           629 Jan 17 20:24 /system/etc/install-recovery_original.sh
            But .. What I can see from your logs.. all seems to be fine .. except one issue !
            Patching sepolicy ...
            You dont have one ..
            Your log ...
            Code:
            [B]File [/sys/fs/selinux/policy] does not exist![/B]
            My log ...
            Code:
            supolicy v2.79 (ndk:arm64-v8a) - Copyright (C) 2014-2016 - Chainfire
            Patching policy ...
            -permissive:adbd_socket=ok
            -permissive:functionfs=ok
            -permissive:wifip2p_service=ok
            -permissive:hci_attach_exec=ok
            -permissive:system_server=ok
            -permissive:proc_uid_cputime_showstat=ok
            -permissive:nfc=ok
            -permissive:rild_debug_socket=ok
            Also when you backup/restore ..
            backup:
            Code:
              ==> set selinux context: unlabeled
            I:addFile '/data/misc/bluedroid/bt_config.conf.new' including root: 0
            I:addFile '/data/misc/bluedroid/bt_config.conf' including root: 0
            restore:
            Code:
            tar_extract_file(): failed to restore SELinux context unlabeled to file /data//misc/bluedroid/ !!!
              ==> extracting: /data//misc/bluedroid/bt_config.conf.new (file size 0 bytes)
            tar_extract_file(): failed to restore SELinux context unlabeled to file /data//misc/bluedroid/bt_config.conf.new !!!
              ==> extracting: /data//misc/bluedroid/bt_config.conf (file size 0 bytes)
            tar_extract_file(): failed to restore SELinux context unlabeled to file /data//misc/bluedroid/bt_config.conf !!!
            The system does not know how to label it ...
            You have the files restored but the system may not able to read them correctly ..
            Do you have s stock recovery.img of your current ROM ?
            I have only one old recovery.img from Lollipop ...
            We may can change this ..
            EDIT:
            Pls run the following commands .. in recovery and in system ...
            Code:
            adb shell dmesg | grep 'avc: '
            Code:
            adb shell ls -l /sys/fs/selinux/class/file/perms/
            Code:
             adb shell ls -l /sys/fs/selinux/policy
              Have you made a new new version with the same name??
              When I started fresh I made sure I downloaded the TWRPUpdate.ZIP from your link.
              Just want to make sure I am on the right page.
              # install Update.ZIP_TWRP_RK3229_3.1.0-0_170318.zip #
              I checked over ADB
              Code:
              shell@Dolamee_D5:/ $ ls -l /system/etc/install*
              -rwxr-xr-x root     root          188 2008-08-01 07:00 install-recovery-2.sh
              -rwxr-xr-x root     root          629 1969-12-31 18:01 install-recovery.sh
              -rwxr-xr-x root     root          629 1969-12-31 18:01 install-recovery_original.sh
              Every thiing seems normal. (and after signing off last night and taking my break had a few, I have made some progress on a firmwareupdate.img file that incorporates TWRP and SuperSU boots fine starts normal, and reboots into TWRP recovery) All thanks to your ideas!! Once I mounted the new-system.img file and compared it to the system.img file before TWRPUpdate.zip and SuperSU.zip I made the following observations / modifications.
              Code:
              Things found durring overview of new-system.img vs original system.img
              Orriginal System.img had none of the below files but they are in new-system
              /etc/install-recovery.sh        #contains new code from SU install
              /etc/install-recovery-2.sh        #contains new code to dd twrprecovery.img
              /etc/install-recovery_original.sh    #also contains new code from SU install
              /etc/.installed_su_daemon        #contains "1"
              New-system.img has different from old System.img
              /bin/install-recovery.sh        #file is empty
              /bin/install-recovery_original.sh    #File has the original code
              /bin/: app_process32_original        #is new
              /bin/: app_process_init            #is new
              /bin/: .ext                #is new
              Process I completed
              chmod all above files to 755
              /bin/install-recovery.sh is now the same as the /ets/install-recovery.sh with the new code from the SU install.
              confirmed /twrp/twrprecovery.img is available.
              unmounted new-system.img
              replaced system.img in custom firmware and repackaged firmware.
              I will attempt to flash and see if it works.
              !! It did !! (less the backup and restor functions)
              So that I'm sure is progress, small steps forward.
              I do have the stock recovery .img and anything else you may need should be in here aswell...
              https://drive.google.com/open?id=0Bw...zNfMmpHVnhFeTQ GDrive Folder holding the unpacked entire stock firmware.
              https://drive.google.com/open?id=0Bw...lBRUTd3WWJfd2s Direct link to stock 6.0.1 recovery.img
              If there is anything else you need, just ask away and I will do my best to get it.
              EDIT:
              I donot know how to connect adb to this box while it is in recovery? Any help would be appreciated on that.
              Otherwise I will try and find a alternate method to do the requested.
              Thinking about useing the terminal in TWRP and seeing if those commands will show in the log file.
              I will do some trail and come back and edit this post.
              Code:
              Code:
              dmesg during recovery returned no matches to 'avc: '
              dmesg during normal system returned no matches either
              Code:
              Code:
              (during recovery) ls: /sys/fs/selinux/class/file/perms: No Such file or directory
              (normal system) /sys/fs/selinux/class/file/perms/: No such file or directory
              Code:
              Code:
              (during recovery)ls: /sys/fs/selinux/policy: No Such file or directory
              (normal system) /sys/fs/selinux/policy: No such file or directory
              Thanks Aaron
              Last edited by tacotime82; 19 March 2017, 16:28. Reason: Edited to add results of commands requested from recovery shell and from adb in system
                I checked over ADB
                Code:
                Code:
                /bin/: .ext                #is new
                Process I completed
                Code:
                dmesg returned no matches to 'avc: '
                Code:
                Code:
                Thanks Aaron
                V170318 from yesterday
                V170319 from today
                If you go into system now .. are fully rooted ?
                Everything works as expected ?
                Can you check the recover installation mechanism now ?
                Pls delete the /data/twrp-install check file manually.
                You may install your stock recovery and do normal reboot into system.
                Now the /data/twrp check file should be back .. and TWRP installed again.
                The selinux is missing for you ..
                Pls do the same ADB commands when you have booted into system.
                Will have a look into your recovery​.img ...
                EDIT:
                Made another version of the TWRP ... your version . included all the stuff from your recovery.img.
                Pls have check ...
                Update.ZIP_TWRP_RK3229_3.1.0-0_170319-2.zip
                TWRP_RK3229_3.1.0-0_170319-2.img
                What about the selinux part now ?
                  I have been poking around and the /sys/selinux folder on my firmware is completely empty.
                  So I decided to see if that was something I had done incorrectly,
                  I flashed the Dolamee_D5_rtl8189es_RK3229_6.0.1_20170224.img the original android 6.0.1 firmware released for the Dolamee and will be redoing the tests below
                  I keep trying to jump forward and make everything work all at once. I am going to restart from ground 0 just to make sure my modifications are not the ones causing the issue.
                  After all of that I should have a Stock-Dolamee_D5_rtl8189es_RK3229_6.0.1_20170224withSupe rSUandTWRP.img
                  That anyone can use...
                  EDIT:
                  Code:
                  Code:
                  Code:
                  After Firmware install of stock 6.0.1.img
                  Directory is still empty.
                  dmesg no referance to avc in normal system.
                  Moving forward
                  Manually pushed the twrprecovery.img and manual dd to recovery partition, then reboot to recovery. Ok new recovery up.
                  Next installed TWRP Install update 170319-2 .zip (freshly downloaded) thank you much
                  Pulled Log File
                  Next Installed SuperSU update .zip
                  Pulled Log File
                  Next in TWRP terminal preformed
                  Code:
                   dd if=/dev/block/mmcblk0p14 of=/usb-otg/stock6.0.1.TWRPSuperSU.system.img
                  Reboot to system.
                  SU appears normal.
                  Prompting for grant permisions.
                  Everything operational
                  Install root checker
                  Root is properly installed
                  Now for the tests requested above.
                  Code:
                  (In system)     no responce
                  (In recovery)   no responce
                  (in system)     /sys/fs/selinux/class/file/perms/: No such file or directory
                  (in recovery)   ls: /sys/fs/selinux/class/file/perms/: No such file or directory
                  (in system)     /sys/fs/selinux/policy: No such file or directory
                  (in recovery)   ls: /sys/fs/selinux/policy: No such file or directory
                  /sys/fs/selinux directory is empty
                  Preformed backup and inspected recovery log per your note from earlier
                  Note from earlier
                  backup:
                  Set selinux context: unlabeled is still there...
                    Moving forward
                    Pulled Log File
                    Pulled Log File
                    Code:
                    reboot to system. SU appears normal. Prompting for grant. Everything operational Install root checker Root is properly installed Now for the tests requested above.
                    Code:
                     adb shell dmesg | grep 'avc: ' (in system)     no responce (in recovery)   no responce  adb shell ls -l /sys/fs/selinux/class/file/perms/ (in system)     /sys/fs/selinux/class/file/perms/: No such file or directory (in recovery)   ls: /sys/fs/selinux/class/file/perms/: No such file or directory  adb shell ls -l /sys/fs/selinux/policy (in system)     /sys/fs/selinux/policy: No such file or directory (in recovery)   ls: /sys/fs/selinux/policy: No such file or directory
                    Maybe your kernel is not configured for selinux ?
                    If selinux is missing in system too .. the twrp backup/restore should work too.
                    Test backup and restore again .. only data .. system you can always DD your last version, there are no changes. Normally mounted read-only.
                    If supersu and automatic TWRP installation are working fine you have done one big step.
                      I did a test backup and restore of the Data partition, and it worked... SuperSU and auto TWRP install worked.
                      I will work on packing this into a Stock firmware .img for others to use.
                      What instructions would you reccomend posting with this to help others use it.
                      Should I have them not backup or restore the System / Boot / Recovery / Uboot / Trust / Resource / Kernel / Cache partitions. Only to use the Data backup and restore functionality?
                        Cool .. sounds good now.
                        You may install Xposed via TWRP and have it also fix included in your ROM
                        But you understood the principles ...
                        Yes, I strongly recommend to backup data only.
                        This is your data and your apps and your settings - the rest is coming from the ROM you are using.
                        I do the same .. even more in AOSP world.
                        But you can still try to backup and restore system too .. have a try.
                        Should work too .. ext4 permissions should be still saved inside the tar backup of TWRP.
                        Same principle as data .. independent of the selinux stuff.
                        Cheers
                          Thank you for all of your help. For sure greatly appreciated. I will do a writeup and put it in the Firmware Folder under the rk3229 forum to share the update.
                          I donot understand the 2 comments I quoted above. What is Xposed?
                          All the best
                            All the best
                            Have a look for Xposed framework .. check it out, plenty of possibilities.
                            It's working fine on mmallow rockchip ROMs.
                            At least on rk3368 mmallow ROMs.
                            Cheers
                              Hi followmsi im needing twrp for my mk809iv rk3229 5.1.1 is this recovery working I need to install xposed
                              My Works @XDA:
                              AVD Rom Xperia J The Way Stock Should Be
                              Pre Root Xperia J 4.12
                              Deodex Xperia L
                              Deodex Xperia Z kitkat
                              Stock Xperia Icon's For CM11
                                Does the version from here not work on your rk3229 device ?
                                But as I know there are still issues with xposed on (rockchip) android 5.1.1 .. make a backup first
