TRWP. 3229 Devices Followmsi.
    Failed to mount '/system' (Operation not supported on transport endpoint)
    I:Actual block device: '/dev/block/mmcblk0p14', current file system: 'ext3'
    Your device has ext3 system partition .. not very common .. changed this now.
    TWRP_RK3229_v161122-3.img
    Removed the linuxroot partition as well ..
    Now should be able to install Xposed Framework or SuperSU.zip via TWRP.
    Do backups and restore of data partition .. system as well, if needed at all.
    Pls test and send a new log recovery.log ..
      Tested and still the same issue with mounting all the partitions I'm afraid.
      Recovery log attached.
      https://www.dropbox.com/s/k2q56thbxu34rfa/recovery.log?dl=0
        Thanks for the logs. ..
        It seems you have a problem with your system partition .. maybe some strange image flash.
        I:Unable to mount '/system'
        I:Check_Lifetime_Writes failed to mount '/system'
        I remember a similar issue on other android hardware ...
        Can you go into TWRP again, advanced wipe and format your system partition.
        Afterwards .. change to loader ( adb reboot loader ) and flash your current system.img only.
        Maybe you use latest v4 version were ext4 is configured again.
        And here the external sdcard ..
        I:Can't probe device /dev/block/mmcblk1p1
        I:Unable to mount '/external_sd'
        I:Actual block device: '/dev/block/mmcblk1p1', current file system: 'vfat'
        Your external sdcard partition layout seems to be strange .. for Android .. you may have formatted it on PC.
        Here is your layout ..
        179 64 62367744 mmcblk1
        179 65 1 mmcblk1p1
        179 69 62362624 mmcblk1p5
        My one is looking like ..formatted via Android system.
        179 69 62362624 mmcblk1p1
        I can mount my external sdcard inside TWRP ..
        Pls format your external sdcard via Android system and TWRP will recognize it.
        Pls ignore the internal_sd card - old stuff
        Did you test usb-otg ?
        Does it recognize usb storage ?
        Pls have a look below .. from so many partitions you have only a few are supposed to be mounted ..
        Partition Logs:
        /uboot | /dev/block/mmcblk0p2 | Size: 4MB
        Flags: Can_Be_Backed_Up IsPresent Can_Flash_Img
        Primary_Block_Device: /dev/block/mmcblk0p2
        Display_Name: Uboot
        Storage_Name: Uboot
        Backup_Path: /uboot
        Backup_Name: uboot
        Backup_Display_Name: Uboot
        Storage_Path: /uboot
        Current_File_System: emmc
        Fstab_File_System: emmc
        Backup_Method: dd
        /trust | /dev/block/mmcblk0p3 | Size: 8MB
        Primary_Block_Device: /dev/block/mmcblk0p3
        Display_Name: Trust
        Storage_Name: Trust
        Backup_Path: /trust
        Backup_Name: trust
        Backup_Display_Name: Trust
        Storage_Path: /trust
        Backup_Method: dd
        /parameter | /dev/block/mmcblk0p1 | Size: 4MB
        Flags: IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p1
        Display_Name: parameter
        Storage_Name: parameter
        Backup_Path: /parameter
        Backup_Name: parameter
        Backup_Display_Name: parameter
        Storage_Path: /parameter
        Backup_Method: dd
        /baseparamer | /dev/block/mmcblk0p5 | Size: 1MB
        Flags: IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p5
        Display_Name: baseparamer
        Storage_Name: baseparamer
        Backup_Path: /baseparamer
        Backup_Name: baseparamer
        Backup_Display_Name: baseparamer
        Storage_Path: /baseparamer
        Backup_Method: dd
        /misc | /dev/block/mmcblk0p4 | Size: 4MB
        Flags: IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p4
        Display_Name: misc
        Storage_Name: misc
        Backup_Path: /misc
        Backup_Name: misc
        Backup_Display_Name: misc
        Storage_Path: /misc
        Backup_Method: dd
        /resource | /dev/block/mmcblk0p6 | Size: 15MB
        Primary_Block_Device: /dev/block/mmcblk0p6
        Display_Name: Resource
        Storage_Name: Resource
        Backup_Path: /resource
        Backup_Name: resource
        Backup_Display_Name: Resource
        Storage_Path: /resource
        Backup_Method: dd
        /kernel | /dev/block/mmcblk0p7 | Size: 12MB
        Primary_Block_Device: /dev/block/mmcblk0p7
        Display_Name: Kernel
        Storage_Name: Kernel
        Backup_Path: /kernel
        Backup_Name: kernel
        Backup_Display_Name: Kernel
        Storage_Path: /kernel
        Backup_Method: dd
        /boot | /dev/block/mmcblk0p8 | Size: 12MB
        Primary_Block_Device: /dev/block/mmcblk0p8
        Display_Name: Boot
        Storage_Name: Boot
        Backup_Path: /boot
        Backup_Name: boot
        Backup_Display_Name: Boot
        Storage_Path: /boot
        Backup_Method: dd
        /recovery | /dev/block/mmcblk0p9 | Size: 32MB
        Primary_Block_Device: /dev/block/mmcblk0p9
        Display_Name: Recovery
        Storage_Name: Recovery
        Backup_Path: /recovery
        Backup_Name: recovery
        Backup_Display_Name: Recovery
        Storage_Path: /recovery
        Backup_Method: dd
        /backup | /dev/block/mmcblk0p10 | Size: 64MB
        Flags: IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p10
        Display_Name: backup
        Storage_Name: backup
        Backup_Path: /backup
        Backup_Name: backup
        Backup_Display_Name: backup
        Storage_Path: /backup
        Backup_Method: dd
        /cache | /dev/block/mmcblk0p11 | Size: 121MB Used: 0MB Free: 121MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p11
        Display_Name: Cache
        Storage_Name: Cache
        Backup_Path: /cache
        Backup_Name: cache
        Backup_Display_Name: Cache
        Storage_Path: /cache
        Current_File_System: ext4
        Fstab_File_System: ext4
        Backup_Method: files
        /data | /dev/block/mmcblk0p15 | Size: 5932MB Used: 773MB Free: 5113MB Backup Size: 773MB
        Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent Can_Be_Encrypted Has_Data_Media Can_Encrypt_Backup Use_Userdata_Encryption Is_Storage Is_Settings_Storage
        Symlink_Path: /data/media/0
        Symlink_Mount_Point: /sdcard
        Primary_Block_Device: /dev/block/mmcblk0p15
        Crypto_Key_Location: /metadata/key_file
        Display_Name: Data
        Storage_Name: Data
        Backup_Path: /data
        Backup_Name: data
        Backup_Display_Name: Data
        Storage_Path: /data/media/0
        MTP_Storage_ID: 65537
        /metadata | /dev/block/mmcblk0p12 | Size: 11MB Used: 0MB Free: 11MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p12
        Display_Name: metadata
        Storage_Name: metadata
        Backup_Path: /metadata
        Backup_Name: metadata
        Backup_Display_Name: metadata
        Storage_Path: /metadata
        /system | /dev/block/mmcblk0p14 | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI IsPresent
        Primary_Block_Device: /dev/block/mmcblk0p14
        Display_Name: System
        Storage_Name: System
        Backup_Path: /system
        Backup_Name: system
        Backup_Display_Name: System
        Storage_Path: /system
        Current_File_System: ext3
        Fstab_File_System: ext3
        /internal_sd | | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI Is_Storage
        Primary_Block_Device: /dev/block/platform/30020000.rksdmmc/by-name/user
        Display_Name: Internal SD
        Storage_Name: Internal SD
        Backup_Path: /internal_sd
        Backup_Name: internal_sd
        Backup_Display_Name: Internal SD
        Storage_Path: /internal_sd
        Current_File_System: vfat
        Fstab_File_System: vfat
        MTP_Storage_ID: 65538
        /external_sd | /dev/block/mmcblk1p1 | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped Wipe_Available_in_GUI Removable IsPresent Is_Storage
        Primary_Block_Device: /dev/block/mmcblk1p1
        Display_Name: External SD
        Storage_Name: External SD
        Backup_Path: /external_sd
        Backup_Name: external_sd
        Backup_Display_Name: External SD
        Storage_Path: /external_sd
        MTP_Storage_ID: 65539
        /usb-otg | | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
        Flags: Can_Be_Mounted Can_Be_Wiped Wipe_Available_in_GUI Removable Is_Storage
        Primary_Block_Device: /dev/block/sda1
        Display_Name: USB Storage
        Storage_Name: USB Storage
        Backup_Path: /usb-otg
        Backup_Name: usb-otg
        Backup_Display_Name: USB Storage
        Storage_Path: /usb-otg
        MTP_Storage_ID: 65540
        Sorry for the long message ... very hard for me to troubleshoot "remotely".
        If anybody else can test as well on RK3229 hardware ?
        The last version for today .. to change back to ext4 for system partition - as it should be.
        TWRP_RK3229_v161122-4.img
        Cheers
          OK, I've wiped system and reflashed system.img, then flashed v4 of recovery.
          Unfortunately everything is the same as before.
          The external SD card was formatted in a PC to FAT32 nut will reformat in Android to see what happens after I have backed the data up.
          Thanks for the hard work in trying to get it working.
            You should have flashed v4 before the format of system partition .. to use the changed fstab with ext4 instead of ext3.
            As the rockchip tools are "block based" your will overwrite the complete filesystem anyway.
            Pls post me the link for your complete ROM .. I wll have a look into your system.img.
            This system image problem is not normal.
            Do you have another ROM for your device ?
            Are you able to test on your second hardware too ?
            Nexsmart D32 ?
            EDIT:
            This ROM has normal ext4 partition ...
            http://freaktab.com/forum/advertiser...ee-d5-firmware
            Your new ROM has ext3 partition .. why ?
            Dolamee_D5_bluesmanuk_19102016 V2
            https://mega.nz/#!O5Ykwbaa!8v0JAzx0W...cDnUkCQDU8Q6W0
            Are you able to change to ext4 ?
            EDIT 2:
            Have made a new system.img for you ...
            Dolamee_D5_bluesmanuk_19102016_newsys.img
            Pls flash as system.img and test TWRP.
              If the ROM has ext3 then it it down to the tool that was used to pack it.
              I'll flash the ext4 version and test TWRP.
                Tested with the newsys firmware and v4 of TWRP and still the same problem mounting the partitions.
                  You have 2 partitons which are currently not possible to be mounted !
                  Your sdcard and your non ext4 system partition.
                  "Dolamee_D5_bluesmanuk_19102016_newsys.img" is a system.img only .. not a complete firmware !
                  mmcblk0p13 should be your system partition .. Check it with .. adb shell ls -al /dev/block/platform/*/by-name
                  Don´t know your tools .. we need to have an ext4 partition for TWRP.
                  Pls run the following command ..
                  adb root
                  adb shell blkid /dev/block/mmcblk0p13
                  Pls install this firmware or only the system.img for testing. ... with proper ext4 partition.
                  If possible, pls test on your other RK3229 device as well ..
                  EDIT:
                  Had some time to check this issue .. very strange indeed.
                  If we can mount the ext4 partition /data on your emmc inside your box there is no general problem.
                  One ext4 partition is like the other .. we are on the same emmc/disk.
                  Normally TWRP should be able to mount ext3 as well ... normally
                  Your ext3 system.img and the ext4 system.img from the other firmware above are missing the value "Lifetime writes:"
                  ( dumpe2fs system.img )
                  Inside the recovery.log ... it seems to block the mounting process.
                  I: operation_start: 'Check Partition Lifetime Writes'
                  it seems to block the mounting process .. you can still test the other ext4 system.img too.
                  When you flash with Windows tool, take care of the correct "address" (offset).
                  For testing .. I have packed a complete new firmware for RK3229 .. -> Your ROM with "another" system.img inside.
                  (did forget to label=system the previous system.img-only file)
                  Pls install the complete firmware (update.img) below .. hopefully it's booting
                  Dolamee_D5_bluesmanuk_19102016_newsys_update.7z
                    When I said that I tested with the firmware, I was aware that it was just the system image, so just a wording thing there.
                    Yes, after flashing it mmcblk0p13 is my system partition.
                    The tool I tend to use is RK3xxx_firmware_tools_5.99.07.00 from Sergio Poverony.
                    Despite flashing the revised ext4 system image though, the partition is still reported as TYPE="ext3.
                    I'll flash stock though and get back to you.
                      It works with stock firmware and I was also able to take a full backup to the external sd card.
                      Great work :-)
                      I'll test on the D32 that only has the latest stock next.
                        Great work :-)
                        Perfect .. you saved my day
                        Maybe my repacked version of your ROM is working too ?
                        If it boots and if the partiton is still ext4 your are done.
                        If it again ext3 we need to check your boot.img .. e.g. ramdisk.
                        Maybe some strange actions while booting
                        But as you can see it's mostly Rom related .. not TWRP related.
                        Cheers
                          Yes it's good to have that useful information for future reference and I'll research why the tool is creating ext3 instead of ext4.
                            For confirmation, twrp working on DolameeD5?
                            Which file specifically was working recovery?
                            How to flash?(can be done via fastboot flash recovery.img?)
                            Very exciting... Thank you guys for building/testing and debugging
                              None thats why we are testing 😃
                                The TWRP_RK3229_v161122-4.img is the one that I flashed and confirmed as working on stock ROM only right now.
                                I use the Androidtool 2.3 or 2.5 to flash it.
