MXIII - G II TV Box Amlogic S912 Octa-core
Originally posted by KingNothing View PostIs anyone else having this behaviour on this box ?
It's pretty disturbing, and I don't know if it depends by some settings or something else.
Do you have HDMI CEC enabled on both the box and TV?
Originally posted by bluesmanuk
Does it shutdown or just go to sleep?
I have to press the power button to use it again.
It happens when I change HDMI, for example to view "normal Tv".
Then, when I come back to the box HDMI, it appears "system is shutting down" (or something similar) and the box is turned off.
I don't have HDMI CEC turned on on box (and in my tv i didn't find how to activate/deactivate it).
Originally posted by bluesmanukI would imagine that the TV user manual may give some idea of whether there is a setting.
But if you turn it on in the box anyway, does the same thing happen?
I have to turn it off on the box with air mouse to use the box.
I add that HDMI CEC of my tv is fully working with raspberry, with no need to turn it on/off on my TV.
But, why you think HDMI CEC is responsible for the fault I described ?
Originally posted by KingNothing View PostIf i turn HDMI CEC on on the box, system hang up whenever i try to use my tv remote to control the box.
What happens when you switch HDMI sources now, even when only using the mouse?
Does it still switch off?
I'm not sure why the TV remote would hang the box but perhaps the IR functionality is getting stuck between the control of the TV and box.
And it does on 2 different TV.
Hello everyone.
I need help please. I recently purchased an MXIII-G II S912. It doesnt work, just shows blue light, never turns red. I've tried everything, updating the software by SD card, tried by USB burning tool...no luck. It doesn't show anything on the screen, with HDMI or AV cable. I looked up some youtube videos where they short circuit the pins on the flash memory, but on the standard flash where the pins are exposed. I'm not an expert but I don't see that type of flash on this motherboard, only a emmc type one, the slim one. Is it possible to short circuit that one? Or any other ideas if someone have...please guys help...thank You all
Turn off the TV.
Switch the box on.
Wait for a couple of minutes and see if the box automatically turns your TV on.
Even if it doesn't, then turn on the TV and see if there is any activity.
Needless to say that you have done the basics such as making sure that you have selected the correct HDMI output on the TV and have ensured that the HDMI cable is connected full at both ends.
Originally posted by mislav View PostThanks, just tried it...no luck. I've tried before on several TV's and with several HDMI cables. TV doesnt even recognize the device, so I cant choose the HDMI input that I'm using.
There are currently 1935 users online. 3 members and 1932 guests.
