Could it help if I put some solder to fully cover them? Or could this cause more damage?
MXIII - G II TV Box Amlogic S912 Octa-core
It's difficult to see from comparing the images but if there is something that is shown on my box pics that isn't the case with yours I don't think that it will hurt the general box operation as long as you know how to solder correctly and of course you will be voiding any warranty by doing so.
Originally posted by bluesmanuk View PostThe only other option would seem to be shorting pins but on this box I don't now which ones they are.
It may be worth mailing your supplier to see if they know, pending anybody else chipping in here with the information.
Hi there...
A friend here mentioned that an update for mxiii g ii is out, stock rom version 112. I was just wondering, since it's not visible through the update and back up application of my box (at least not yet), if I am supposed to full unroot through SuperSU to gain access to available online updates (OTA)?
Thanks you guys.
I have a friend of mine who has this box.
I wrote in the past for the problems he had (no wifi network, and so on...).
I tried a factory reset but things got worse, the box does not start anymore.
He finally gave the box to me, to try to sort it out.
Now, the box starts but after the initial logo it starts doing some flashes on the screen and then the screen goes blank.
I tried to reinstall the firmware.
I tried with sd card with no luck.
I tried with AMLogic Burning Tool : the box is correctly recognized, but when it starts with "erase bootloader", it comes an error :
[18:47:05 944][HUB3-2][Err]--Identify status failed
[18:47:05 944][HUB3-2][Inf]--Failure : 1, FailureMax : 3
[18:47:06 444][HUB3-2][Err]--[18:47:06 444][HUB3-2][Inf]--Failure : 2, FailureMax : 3
[18:47:06 944][HUB3-2][Err]--[18:47:06 944][HUB3-2][Inf]--Failure : 3, FailureMax : 3
[18:47:06 970][HUB3-2][Err]--[0x00101004]Erase bootloader/Lowper/Identify/Error result
I tried with two different PC and with USB2 port and USB3 port.
The box is completely gone ?
UPDATE :
I have managed to burn the firmware successfully (both stock and SCV8).
The problem was the AC adapter that was connected and it must not be.
But.... even having restored the firmware, the box does not start correctly.
I think it's probable the box has some hardware fault.Last edited by KingNothing; 05-21-2017, 18:36.
Hi,I recived yesterday the tv box mx3 g2 ,out of the box I haw rv112,now i read on this forum that the supercelerno rom the best for this box.I wont the flash with this rom.Now, if something go wrong with the flash or I do noth love this celeron rom,can I back to the stock rv112 rom and how,with sd burning tool,can check the earse bootloader or uncheck wen stock rom flash,I read the custums rom must bee checked, earse bootloader,buth stock rom went I flash if I check or uncheck the earse bootloader?And if I flash superceleron rom,haw my stock remote contrl.,working on this rom? Thanks for the answer!
Poslano sa mog Mi-4c koristeći Tapatalk
There are currently 2051 users online. 4 members and 2047 guests.
