P.S. Just to be clear... The numbers representing the voltages have to go up right?
Tutorial: Enable RK3368 True Octa-Core Processor - Part 1 of 2
Originally posted by l33tlinuxh4x0r View Post
Could you please post your clock speeds and the working voltages for them? Preferably in decimal not in hex. Makes it easier to read that way.
Originally posted by Shomari View Post696000, 975000
816000, 1000000
1008000, 1100000
1200000, 1175000
1416000, 1300000
1488000, 1325000
1512000, 1350000
1608000, 1390000
Code:echo "1200000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
That is what I have too. However at any clock above 1008000 the device will not boot.
You might think you set one frequency and voltage, but a linkage will default it to something else at times. Welcome to the world of roxkchip, where documentation is almost nonexistent, it's a pain, I know.
... what cluster? B or L? Also, always check your logs, either in recovery or once booted in /proc 'laat_kmesg'
EDIT: dmesg gives me the followingCode:[ 423.713796] [0: cfinteractive: 79] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error
How do I read /proc/last_kmsg? It appears to be a binary :/
I don't think that it is disabled. So the rate must be bad. any hints?
Originally posted by Shomari View Post... also, cat > /sys/dvfs/dvfs_tree and look at the output as well
Code:-------------DVFS TREE----------- [ 193.992120] [2: sh: 1409] [ 193.992120] [2: sh: 1409] [ 193.992220] [2: sh: 1409] DVFS TREE: [ 193.992251] [2: sh: 1409] | [ 193.992251] [2: sh: 1409] |- voltage domain:vd_logic [ 193.992298] [2: sh: 1409] |- current voltage:0 [ 193.992322] [2: sh: 1409] |- current regu_mode:UNKNOWN [ 193.992351] [2: sh: 1409] | | [ 193.992351] [2: sh: 1409] | |- power domain:pd_gpu, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 193.992401] [2: sh: 1409] | | | [ 193.992401] [2: sh: 1409] | | |- clock: clk_gpu current: rate 0, volt = 0, enable_dvfs = DISABLE [ 193.992452] [2: sh: 1409] | | |- clk limit(disable):[0, 0]; last set rate = 300000 [ 193.992481] [2: sh: 1409] | | | |- freq = 300000, volt = 1200000 [ 193.992508] [2: sh: 1409] | | | |- freq = 400000, volt = 1200000 [ 193.992535] [2: sh: 1409] | | | |- freq = 600000, volt = 1200000 [ 193.992564] [2: sh: 1409] | | |- clock: clk_gpu current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 193.992596] [2: sh: 1409] | | [ 193.992596] [2: sh: 1409] | |- power domain:pd_ddr, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 193.992647] [2: sh: 1409] | | | [ 193.992647] [2: sh: 1409] | | |- clock: clk_ddr current: rate 0, volt = 0, enable_dvfs = DISABLE [ 193.992698] [2: sh: 1409] | | |- clk limit(disable):[0, 0]; last set rate = 792000 [ 193.992726] [2: sh: 1409] | | | |- freq = 200000, volt = 1050000 [ 193.992753] [2: sh: 1409] | | | |- freq = 300000, volt = 1050000 [ 193.992780] [2: sh: 1409] | | | |- freq = 400000, volt = 1100000 [ 193.992808] [2: sh: 1409] | | | |- freq = 533000, volt = 1150000 [ 193.992835] [2: sh: 1409] | | | |- freq = 800000, volt = 1200000 [ 193.992863] [2: sh: 1409] | | |- clock: clk_ddr current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 193.992891] [2: sh: 1409] | [ 193.992891] [2: sh: 1409] |- voltage domain:vd_arm [ 193.992935] [2: sh: 1409] |- current voltage:0 [ 193.992960] [2: sh: 1409] |- current regu_mode:UNKNOWN [ 193.992988] [2: sh: 1409] | | [ 193.992988] [2: sh: 1409] | |- power domain:pd_core, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 193.993040] [2: sh: 1409] | | | [ 193.993040] [2: sh: 1409] | | |- clock: clk_core_b current: rate 0, volt = 0, enable_dvfs = DISABLE [ 193.993090] [2: sh: 1409] | | |- clk limit(enable):[312000000, 1608000000]; last set rate = 1200000 [ 193.993120] [2: sh: 1409] | | | |- freq = 312000, volt = 950000 [ 193.993147] [2: sh: 1409] | | | |- freq = 408000, volt = 950000 [ 193.993174] [2: sh: 1409] | | | |- freq = 600000, volt = 975000 [ 193.993201] [2: sh: 1409] | | | |- freq = 696000, volt = 975000 [ 193.993227] [2: sh: 1409] | | | |- freq = 816000, volt = 1000000 [ 193.993254] [2: sh: 1409] | | | |- freq = 1008000, volt = 1100000 [ 193.993281] [2: sh: 1409] | | | |- freq = 1200000, volt = 1175000 [ 193.993308] [2: sh: 1409] | | | |- freq = 1416000, volt = 1300000 [ 193.993335] [2: sh: 1409] | | | |- freq = 1488000, volt = 1325000 [ 193.993362] [2: sh: 1409] | | | |- freq = 1512000, volt = 1350000 [ 193.993389] [2: sh: 1409] | | | |- freq = 1608000, volt = 1390000 [ 193.993417] [2: sh: 1409] | | |- clock: clk_core_b current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 193.993445] [2: sh: 1409] -------------DVFS TREE END------------
Originally posted by Shomari View Post... that's why you get that error - you've disabled dvfs for your cpu cluster. You want it on, at least that's my approach so far
Here is the file that I'm working with.
Code:#include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/suspend/rockchip-rk3368.h> #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/sensor-dev.h> #include <dt-bindings/clock/rk_system_status.h> #include "rk3368-clocks.dtsi" #include <rk3368_dram_default_timing.dtsi> / { compatible = "rockchip,rk3368"; rockchip,sram = <&sram>; interrupt-parent = <&gic>; #address-cells = <2>; #size-cells = <2>; aliases { serial0 = &uart_bt; serial1 = &uart_bb; serial2 = &uart_dbg; serial3 = &uart_gps; serial4 = &uart_exp; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c3 = &i2c3; i2c4 = &i2c4; i2c5 = &i2c5; spi0 = &spi0; spi1 = &spi1; spi2 = &spi2; lcdc = &lcdc; }; cpus { #address-cells = <2>; #size-cells = <0>; idle-states { entry-method = "arm,psci"; CPU_SLEEP_0: cpu-sleep-0 { compatible = "arm,idle-state"; arm,psci-suspend-param = <0x1010000>; entry-latency-us = <0x3fffffff>; exit-latency-us = <0x40000000>; min-residency-us = <0xffffffff>; }; }; little0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x0>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; little1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x1>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; little2: cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x2>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; little3: cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x3>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; big0: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x100>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; big1: cpu@101 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x101>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; big2: cpu@102 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x102>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; big3: cpu@103 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x103>; enable-method = "psci"; cpu-idle-states = <&CPU_SLEEP_0>; }; cpu-map { cluster0 { core0 { cpu = <&little0>; }; core1 { cpu = <&little1>; }; core2 { cpu = <&little2>; }; core3 { cpu = <&little3>; }; core4 { cpu = <&big0>; }; core5 { cpu = <&big1>; }; core6 { cpu = <&big2>; }; core7 { cpu = <&big3>; }; }; }; }; psci { compatible = "arm,psci-0.2"; method = "smc"; }; gic: interrupt-controller@ffb70000 { compatible = "arm,cortex-a15-gic"; #interrupt-cells = <3>; #address-cells = <0>; interrupt-controller; reg = <0x0 0xffb71000 0 0x1000>, <0x0 0xffb72000 0 0x1000>; }; ddrpctl: syscon@ff610000 { compatible = "rockchip,rk3368-ddrpctl", "syscon"; reg = <0x0 0xff610000 0x0 0x400>; }; pmu: syscon@ff730000 { compatible = "rockchip,rk3368-pmu", "rockchip,pmu", "syscon"; reg = <0x0 0xff730000 0x0 0x1000>; }; pmugrf: syscon@ff738000 { compatible = "rockchip,rk3368-pmugrf", "rockchip,pmugrf", "syscon"; reg = <0x0 0xff738000 0x0 0x1000>; }; sgrf: syscon@ff740000 { compatible = "rockchip,rk3368-sgrf", "rockchip,sgrf", "syscon"; reg = <0x0 0xff740000 0x0 0x1000>; }; cru: syscon@ff760000 { compatible = "rockchip,rk3368-cru", "rockchip,cru", "syscon"; reg = <0x0 0xff760000 0x0 0x1000>; }; grf: syscon@ff770000 { compatible = "rockchip,rk3368-grf", "rockchip,grf", "syscon"; reg = <0x0 0xff770000 0x0 0x1000>; }; msch: syscon@ffac0000 { compatible = "rockchip,rk3368-msch", "rockchip,msch", "syscon"; reg = <0x0 0xffac0000 0x0 0x3000>; }; arm-pmu { compatible = "arm,armv8-pmuv3"; interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; }; cpu_axi_bus: cpu_axi_bus { compatible = "rockchip,cpu_axi_bus"; #address-cells = <2>; #size-cells = <2>; ranges; qos { #address-cells = <2>; #size-cells = <2>; ranges; dmac { reg = <0x0 0xffa80000 0x0 0x20>; }; crypto { reg = <0x0 0xffa80080 0x0 0x20>; }; tsp { reg = <0x0 0xffa80280 0x0 0x20>; }; bus_cpup { reg = <0x0 0xffa90000 0x0 0x20>; }; cci_r { reg = <0x0 0xffaa0000 0x0 0x20>; }; cci_w { reg = <0x0 0xffaa0080 0x0 0x20>; }; peri { reg = <0x0 0xffab0000 0x0 0x20>; rockchip,priority = <2 2>; }; iep { reg = <0x0 0xffad0000 0x0 0x20>; }; isp_r0 { reg = <0x0 0xffad0080 0x0 0x20>; }; isp_r1 { reg = <0x0 0xffad0100 0x0 0x20>; }; isp_w0 { reg = <0x0 0xffad0180 0x0 0x20>; rockchip,priority = <2 2>; }; isp_w1 { reg = <0x0 0xffad0200 0x0 0x20>; rockchip,priority = <2 2>; }; vip { reg = <0x0 0xffad0280 0x0 0x20>; }; vop { reg = <0x0 0xffad0300 0x0 0x20>; rockchip,priority = <2 2>; }; rga_r { reg = <0x0 0xffad0380 0x0 0x20>; }; rga_w { reg = <0x0 0xffad0400 0x0 0x20>; }; hevc_r { reg = <0x0 0xffae0000 0x0 0x20>; }; vpu_r { reg = <0x0 0xffae0100 0x0 0x20>; }; vpu_w { reg = <0x0 0xffae0180 0x0 0x20>; }; gpu { reg = <0x0 0xffaf0000 0x0 0x20>; }; }; msch { #address-cells = <2>; #size-cells = <2>; ranges; msch { reg = <0x0 0xffac0000 0x0 0x3c>; rockchip,read-latency = <0x34>; }; }; }; efuse_256@ffb00000 { compatible = "rockchip,rk3368-efuse-256"; reg = <0x0 0xffb00000 0x0 0x8>; }; timer { compatible = "arm,armv8-timer"; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>; }; timer@ff810000 { compatible = "rockchip,timer"; reg = <0x0 0xff810000 0x0 0x20>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; rockchip,broadcast = <1>; }; timer@ff810020 { compatible = "rockchip,timer"; reg = <0x0 0xff810020 0x0 0x20>; interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; rockchip,percpu = <0>; }; sram: sram@ff8c0000 { compatible = "mmio-sram"; reg = <0x0 0xff8c0000 0x0 0xf000>; /* 60K (reserved 4K for mailbox)*/ map-exec; }; watchdog: wdt@ff800000 { compatible = "rockchip,watch dog"; reg = <0x0 0xff800000 0x0 0x100>; clocks = <&pclk_alive_pre>; clock-names = "pclk_wdt"; interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; rockchip,irq = <1>; rockchip,timeout = <60>; rockchip,atboot = <1>; rockchip,debug = <0>; status = "disabled"; }; amba { #address-cells = <2>; #size-cells = <2>; compatible = "arm,amba-bus"; interrupt-parent = <&gic>; ranges; pdma0: pdma@ff600000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff600000 0x0 0x4000>; clocks = <&clk_gates12 11>; clock-names = "apb_pclk"; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; }; pdma1: pdma@ff250000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xff250000 0x0 0x4000>; clocks = <&clk_gates19 3>; clock-names = "apb_pclk"; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; }; }; reset: reset@ff760300{ compatible = "rockchip,reset"; reg = <0x0 0xff760300 0x0 0x38>; rockchip,reset-flag = <ROCKCHIP_RESET_HIWORD_MASK>; #reset-cells = <1>; }; nandc0: nandc@ff400000 { compatible = "rockchip,rk-nandc"; reg = <0x0 0xff400000 0x0 0x4000>; interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; nandc_id = <0>; clocks = <&clk_nandc0>, <&clk_gates20 9>, <&clk_gates20 11>; clock-names = "clk_nandc", "g_clk_nandc", "hclk_nandc"; }; nandc0reg: nandc0@ff400000 { compatible = "rockchip,rk-nandc"; reg = <0x0 0xff400000 0x0 0x4000>; }; emmc: rksdmmc@ff0f0000 { compatible = "rockchip,rk_mmc", "rockchip,rk3368-sdmmc"; reg = <0x0 0xff0f0000 0x0 0x4000>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; clocks = <&clk_emmc>, <&clk_gates21 2>, <&clk_gates20 10>; clock-names = "clk_mmc", "hclk_mmc", "hpclk_mmc"; rockchip,grf = <&grf>; rockchip,cru = <&cru>; num-slots = <1>; fifo-depth = <0x100>; bus-width = <8>; tune_regsbase = <0x418>; resets = <&reset RK3368_SRST_EMMC>; reset-names = "mmc_ahb_reset"; }; sdmmc: rksdmmc@ff0c0000 { compatible = "rockchip,rk_mmc", "rockchip,rk3368-sdmmc"; reg = <0x0 0xff0c0000 0x0 0x4000>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "idle"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_dectn &sdmmc_bus4>; pinctrl-1 = <&sdmmc_gpio>; cd-gpios = <&gpio2 GPIO_B3 GPIO_ACTIVE_HIGH>;/*CD GPIO*/ clocks = <&clk_sdmmc0>, <&clk_gates21 0>, <&clk_gates20 10>; clock-names = "clk_mmc", "hclk_mmc", "hpclk_mmc"; rockchip,grf = <&grf>; rockchip,cru = <&cru>; num-slots = <1>; fifo-depth = <0x100>; bus-width = <4>; tune_regsbase = <0x400>; resets = <&reset RK3368_SRST_MMC0>; reset-names = "mmc_ahb_reset"; }; sdio: rksdmmc@ff0d0000 { compatible = "rockchip,rk_mmc", "rockchip,rk3368-sdmmc"; reg = <0x0 0xff0d0000 0x0 0x4000>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default","idle"; pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_wrprt &sdio0_pwren &sdio0_bkpwr &sdio0_int &sdio0_bus4>; pinctrl-1 = <&sdio0_gpio>; clocks = <&clk_sdio0>, <&clk_gates21 1>, <&clk_gates20 10>; clock-names = "clk_mmc", "hclk_mmc", "hpclk_mmc"; rockchip,grf = <&grf>; rockchip,cru = <&cru>; num-slots = <1>; fifo-depth = <0x100>; bus-width = <4>; tune_regsbase = <0x408>; resets = <&reset RK3368_SRST_SDIO0>; reset-names = "mmc_ahb_reset"; }; spi0: spi@ff110000 { compatible = "rockchip,rockchip-spi"; reg = <0x0 0xff110000 0x0 0x1000>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0 &spi0_cs1>; rockchip,spi-src-clk = <0>; num-cs = <2>; clocks =<&clk_spi0>, <&clk_gates19 4>; clock-names = "spi", "pclk_spi0"; //dmas = <&pdma1 11>, <&pdma1 12>; //#dma-cells = <2>; //dma-names = "tx", "rx"; status = "disabled"; }; spi1: spi@ff120000 { compatible = "rockchip,rockchip-spi"; reg = <0x0 0xff120000 0x0 0x1000>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0 &spi1_cs1>; rockchip,spi-src-clk = <1>; num-cs = <2>; clocks = <&clk_spi1>, <&clk_gates19 5>; clock-names = "spi", "pclk_spi1"; //dmas = <&pdma1 13>, <&pdma1 14>; //#dma-cells = <2>; //dma-names = "tx", "rx"; status = "disabled"; }; spi2: spi@ff130000 { compatible = "rockchip,rockchip-spi"; reg = <0x0 0xff130000 0x0 0x1000>; interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; rockchip,spi-src-clk = <2>; num-cs = <1>; clocks = <&clk_spi2>, <&clk_gates19 6>; clock-names = "spi", "pclk_spi2"; //dmas = <&pdma1 15>, <&pdma1 16>; //#dma-cells = <2>; //dma-names = "tx", "rx"; status = "disabled"; }; uart_bt: serial@ff180000 { compatible = "rockchip,serial"; reg = <0x0 0xff180000 0x0 0x100>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart0>, <&clk_gates19 7>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; //dmas = <&pdma1 1>, <&pdma1 2>; //#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; status = "disabled"; }; uart_bb: serial@ff190000 { compatible = "rockchip,serial"; reg = <0x0 0xff190000 0x0 0x100>; interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart1>, <&clk_gates19 8>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; //dmas = <&pdma1 3>, <&pdma1 4>; //#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>; status = "disabled"; }; uart_dbg: serial@ff690000 { compatible = "rockchip,serial"; reg = <0x0 0xff690000 0x0 0x100>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart2>, <&clk_gates13 5>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; //dmas = <&pdma0 4>, <&pdma0 5>; //#dma-cells = <2>; //pinctrl-names = "default"; //pinctrl-0 = <&uart2_xfer>; status = "disabled"; }; uart_gps: serial@ff1b0000 { compatible = "rockchip,serial"; reg = <0x0 0xff1b0000 0x0 0x100>; interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart3>, <&clk_gates19 9>; clock-names = "sclk_uart", "pclk_uart"; current-speed = <115200>; reg-shift = <2>; reg-io-width = <4>; //dmas = <&pdma1 7>, <&pdma1 8>; //#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer &uart3_cts &uart3_rts>; status = "disabled"; }; uart_exp: serial@ff1c0000 { compatible = "rockchip,serial"; reg = <0x0 0xff1c0000 0x0 0x100>; interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; clock-frequency = <24000000>; clocks = <&clk_uart4>, <&clk_gates19 10>; clock-names = "sclk_uart", "pclk_uart"; reg-shift = <2>; reg-io-width = <4>; //dmas = <&pdma1 9>, <&pdma1 10>; //#dma-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer &uart4_cts &uart4_rts>; status = "disabled"; }; fiq-debugger { compatible = "rockchip,fiq-debugger"; rockchip,serial-id = <2>; rockchip,signal-irq = <186>; rockchip,wake-irq = <0>; rockchip,irq-mode-enable = <0>; /* If enable uart uses irq instead of fiq */ rockchip,baudrate = <115200>; /* Only 115200 and 1500000 */ status = "disabled"; }; mbox: mbox@ff6b0000 { compatible = "rockchip,rk3368-mailbox"; reg = <0x0 0xff6b0000 0x0 0x1000>, <0x0 0xff8cf000 0x0 0x1000>; /* the end 4k of sram */ interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 147 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates12 1>; clock-names = "pclk_mailbox"; #mbox-cells = <1>; }; mbox_scpi: mbox-scpi { compatible = "rockchip,mbox-scpi"; mboxes = <&mbox 0 &mbox 1 &mbox 2>; chan-nums = <3>; }; ddr: ddr { compatible = "rockchip,rk3368-ddr"; status = "okay"; rockchip,ddrpctl = <&ddrpctl>; rockchip,grf = <&grf>; rockchip,msch = <&msch>; rockchip,ddr_timing = <&ddr_timing>; }; rockchip_clocks_init: clocks-init{ compatible = "rockchip,clocks-init"; rockchip,clocks-init-parent = <&i2s_pll &clk_gpll>, <&spdif_8ch_pll &clk_gpll>, <&i2s_2ch_pll &clk_gpll>, <&usbphy_480m &usbotg_480m_out>, <&clk_uart_pll &clk_gpll>, <&aclk_gpu &clk_cpll>, <&clk_cs &clk_gpll>, <&clk_32k_mux &xin32k>; rockchip,clocks-init-rate = <&clk_gpll 576000000>, <&clk_core_b 1008000000>, /*&clk_core_l 600000000>,*/ <&clk_cpll 400000000>, /*<&clk_npll 500000000>,*/ <&aclk_bus 300000000>, <&hclk_bus 150000000>, <&pclk_bus 75000000>, <&clk_crypto 150000000>, <&aclk_peri 300000000>, <&hclk_peri 150000000>, <&pclk_peri 75000000>, <&pclk_alive_pre 100000000>, <&pclk_pmu_pre 100000000>, <&clk_cs 300000000>, <&clkin_trace 300000000>, <&aclk_cci 600000000>, <&clk_mac 125000000>, <&aclk_vio0 400000000>, <&hclk_vio 100000000>, <&aclk_rga_pre 400000000>, <&clk_rga 400000000>, <&clk_isp 400000000>, <&clk_edp 200000000>, <&clk_gpu_core 600000000>, <&aclk_gpu_mem 600000000>, <&aclk_gpu_cfg 600000000>, <&aclk_vepu 400000000>, <&aclk_vdpu 400000000>, <&clk_hevc_core 300000000>, <&clk_hevc_cabac 300000000>; /* rockchip,clocks-uboot-has-init = <&aclk_vio0>; */ }; rockchip_clocks_enable: clocks-enable { compatible = "rockchip,clocks-enable"; clocks = /*PLL*/ <&clk_apllb>, <&clk_aplll>, <&clk_dpll>, <&clk_gpll>, <&clk_cpll>, /*PD_CORE*/ <&clk_cs>, <&clkin_trace>, <&aclk_cci>, /*PD_BUS*/ <&aclk_bus>, <&hclk_bus>, <&pclk_bus>, <&clk_gates12 12>,/*aclk_strc_sys*/ <&clk_gates12 6>,/*aclk_intmem1*/ <&clk_gates12 5>,/*aclk_intmem0*/ <&clk_gates12 4>,/*aclk_intmem*/ <&clk_gates13 9>,/*aclk_gic400*/ <&clk_gates12 9>,/*hclk_rom*/ /*PD_ALIVE*/ <&clk_gates22 12>,/*pclk_timer0*/ <&clk_gates22 9>,/*pclk_alive_niu*/ <&clk_gates22 8>,/*pclk_grf*/ /*PD_PMU*/ <&clk_gates23 5>,/*pclk_pmugrf*/ <&clk_gates23 3>,/*pclk_sgrf*/ <&clk_gates23 2>,/*pclk_pmu_noc*/ <&clk_gates23 1>,/*pclk_intmem1*/ <&clk_gates23 0>,/*pclk_pmu*/ /*PD_PERI*/ <&clk_gates19 2>,/*aclk_peri_axi_matrix*/ <&clk_gates20 8>,/*aclk_peri_niu*/ <&clk_gates21 4>,/*aclk_peri_mmu*/ <&clk_gates19 0>,/*hclk_peri_axi_matrix*/ <&clk_gates20 7>,/*hclk_peri_ahb_arbi*/ <&clk_gates19 1>,/*pclk_peri_axi_matrix*/ <&clk_gates24 0>, /* g_clk_timer0 */ <&clk_gates24 1>, /* g_clk_timer1 */ <&fclk_mcu>, <&stclk_mcu>, <&clk_gates7 0>;/*clk_jtag*/ }; /* I2C_PMU */ i2c0: i2c@ff650000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff650000 0x0 0x1000>; interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c0_xfer>; pinctrl-1 = <&i2c0_gpio>; pinctrl-2 = <&i2c0_sleep>; gpios = <&gpio0 GPIO_A6 GPIO_ACTIVE_LOW>, <&gpio0 GPIO_A7 GPIO_ACTIVE_LOW>; clocks = <&clk_gates12 2>; rockchip,check-idle = <1>; status = "disabled"; }; /* I2C_AUDIO */ i2c1: i2c@ff660000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff660000 0x0 0x1000>; interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c1_xfer>; pinctrl-1 = <&i2c1_gpio>; pinctrl-2 = <&i2c1_sleep>; gpios = <&gpio2 GPIO_C5 GPIO_ACTIVE_LOW>, <&gpio2 GPIO_C6 GPIO_ACTIVE_LOW>; clocks = <&clk_gates12 3>; rockchip,check-idle = <1>; status = "disabled"; }; /* I2C_SENSOR */ i2c2: i2c@ff140000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff140000 0x0 0x1000>; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c2_xfer>; pinctrl-1 = <&i2c2_gpio>; pinctrl-2 = <&i2c2_sleep>; gpios = <&gpio3 GPIO_D7 GPIO_ACTIVE_LOW>, <&gpio0 GPIO_B1 GPIO_ACTIVE_LOW>; clocks = <&clk_gates19 11>; rockchip,check-idle = <1>; status = "disabled"; }; /* I2C_CAM */ i2c3: i2c@ff150000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff150000 0x0 0x1000>; interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c3_xfer>; pinctrl-1 = <&i2c3_gpio>; pinctrl-2 = <&i2c3_sleep>; gpios = <&gpio1 GPIO_C1 GPIO_ACTIVE_LOW>, <&gpio1 GPIO_C0 GPIO_ACTIVE_LOW>; clocks = <&clk_gates19 12>; rockchip,check-idle = <1>; status = "disabled"; }; /* I2C_TP */ i2c4: i2c@ff160000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff160000 0x0 0x1000>; interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c4_xfer>; pinctrl-1 = <&i2c4_gpio>; pinctrl-2 = <&i2c4_sleep>; gpios = <&gpio3 GPIO_D0 GPIO_ACTIVE_LOW>, <&gpio3 GPIO_D1 GPIO_ACTIVE_LOW>; clocks = <&clk_gates19 13>; rockchip,check-idle = <1>; status = "disabled"; }; /* I2C_HDMI */ i2c5: i2c@ff170000 { compatible = "rockchip,rk30-i2c"; reg = <0x0 0xff170000 0x0 0x1000>; interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default", "gpio", "sleep"; pinctrl-0 = <&i2c5_xfer>; pinctrl-1 = <&i2c5_gpio>; pinctrl-2 = <&i2c5_sleep>; gpios = <&gpio3 GPIO_D2 GPIO_ACTIVE_LOW>, <&gpio3 GPIO_D3 GPIO_ACTIVE_LOW>; clocks = <&clk_gates19 14>; rockchip,check-idle = <1>; status = "disabled"; }; fb: fb { compatible = "rockchip,rk-fb"; rockchip,disp-mode = <NO_DUAL>; }; rk_screen: rk_screen { compatible = "rockchip,screen"; }; dsihost0: mipi@ff960000{ compatible = "rockchip,rk3368-dsi"; rockchip,prop = <0>; reg = <0x0 0xff960000 0x0 0x4000>, <0x0 0xff968000 0x0 0x4000>; reg-names = "mipi_dsi_host" ,"mipi_dsi_phy"; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates4 14>, <&clk_gates22 10>, <&clk_gates17 3>, <&pd_mipidsi>; clock-names = "clk_mipi_24m", "pclk_mipi_dsi", "pclk_mipi_dsi_host", "pd_mipi_dsi"; status = "disabled"; }; lvds: lvds@ff968000 { compatible = "rockchip,rk3368-lvds"; rockchip,grf = <&grf>; reg = <0x0 0xff968000 0x0 0x4000>, <0x0 0xff9600a0 0x0 0x20>; reg-names = "mipi_lvds_phy", "mipi_lvds_ctl"; clocks = <&clk_gates22 10>, <&clk_gates17 3>, <&pd_lvds>; clock-names = "pclk_lvds", "pclk_lvds_ctl", "pd_lvds"; status = "disabled"; }; edp: edp@ff970000 { compatible = "rockchip,rk32-edp"; reg = <0x0 0xff970000 0x0 0x4000>; rockchip,grf = <&grf>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_edp>, <&clk_edp_24m>, <&clk_gates17 9>; clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; resets = <&reset RK3368_SRST_EDP_24M>, <&reset RK3368_SRST_EDP_P>; reset-names = "edp_24m", "edp_apb"; }; hdmi: hdmi@ff980000 { compatible = "rockchip,rk3368-hdmi"; reg = <0x0 0xff980000 0x0 0x20000>; resets = <&reset RK3368_SRST_HDMI>; reset-names = "hdmi"; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default", "gpio"; pinctrl-0 = <&hdmii2c_xfer &hdmi_cec>; pinctrl-1 = <&i2c5_gpio>; clocks = <&clk_gates17 6>, <&clk_gates4 13>, <&clk_gates4 12>; clock-names = "pclk_hdmi", "hdcp_clk_hdmi", "cec_clk_hdmi"; status = "disabled"; }; hdmi_hdcp2: hdmi_hdcp2@ff978000 { compatible = "rockchip,rk3368-hdmi-hdcp2"; reg = <0x0 0xff978000 0x0 0x2000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates17 10>, <&clk_gates17 12>, <&clk_gates17 11>, <&clk_hdcp>; clock-names ="aclk_hdcp2", "hclk_hdcp2_mmu", "pclk_hdcp2", "hdcp2_clk_hdmi"; status = "disabled"; }; lcdc: lcdc@ff930000 { compatible = "rockchip,rk3368-lcdc"; rockchip,grf = <&grf>; rockchip,pmugrf = <&pmugrf>; rockchip,cru = <&cru>; rockchip,prop = <PRMRY>; rockchip,pwr18 = <0>; rockchip,iommu-enabled = <1>; reg = <0x0 0xff930000 0x0 0x10000>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; /*pinctrl-names = "default", "gpio"; *pinctrl-0 = <&lcdc_lcdc>; *pinctrl-1 = <&lcdc_gpio>; */ status = "disabled"; clocks = <&clk_gates16 5>, <&dclk_vop0>, <&clk_gates16 6>, <&clk_npll>, <&pd_vop>; clock-names = "aclk_lcdc", "dclk_lcdc", "hclk_lcdc", "sclk_pll", "pd_lcdc"; }; adc: adc@ff100000 { compatible = "rockchip,saradc"; reg = <0x0 0xff100000 0x0 0x100>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; #io-channel-cells = <1>; io-channel-ranges; rockchip,adc-vref = <1800>; clock-frequency = <1000000>; clocks = <&clk_saradc>, <&clk_gates19 15>; clock-names = "saradc", "pclk_saradc"; status = "disabled"; }; rga@ff920000 { compatible = "rockchip,rga2"; dev_mode = <1>; reg = <0x0 0xff920000 0x0 0x1000>; interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates16 1>, <&clk_gates16 0>, <&clk_rga>; clock-names = "hclk_rga", "aclk_rga", "clk_rga"; }; i2s0: i2s0@ff898000 { compatible = "rockchip-i2s"; reg = <0x0 0xff898000 0x0 0x1000>; i2s-id = <0>; clocks = <&clk_i2s>, <&i2s_out>, <&clk_gates12 7>; clock-names = "i2s_clk", "i2s_mclk", "i2s_hclk"; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; dmas = <&pdma0 0>, <&pdma0 1>; #dma-cells = <2>; dma-names = "tx", "rx"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2s_mclk &i2s_sclk &i2s_lrckrx &i2s_lrcktx &i2s_sdi &i2s_sdo0 &i2s_sdo1 &i2s_sdo2 &i2s_sdo3>; pinctrl-1 = <&i2s_gpio>; }; i2s1: i2s1@ff890000 { compatible = "rockchip-i2s"; reg = <0x0 0xff890000 0x0 0x1000>; i2s-id = <1>; clocks = <&clk_i2s_2ch>, <&clk_gates12 8>; clock-names = "i2s_clk", "i2s_hclk"; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; dmas = <&pdma0 6>, <&pdma0 7>; #dma-cells = <2>; dma-names = "tx", "rx"; }; spdif: spdif@ff880000 { compatible = "rockchip-spdif"; reg = <0x0 0xff880000 0x0 0x1000>; clocks = <&clk_spidf_8ch>, <&clk_gates12 10>; clock-names = "spdif_mclk", "spdif_hclk"; interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; dmas = <&pdma0 3>; #dma-cells = <1>; dma-names = "tx"; pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; }; pwm0: pwm@ff680000 { compatible = "rockchip,rk-pwm"; reg = <0x0 0xff680000 0x0 0x10>; #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; clocks = <&clk_gates13 6>; clock-names = "pclk_pwm"; status = "disabled"; }; pwm1: pwm@ff680010 { compatible = "rockchip,rk-pwm"; reg = <0x0 0xff680010 0x0 0x10>; #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; clocks = <&clk_gates13 6>; clock-names = "pclk_pwm"; status = "disabled"; }; pwm2: pwm@ff680020 { compatible = "rockchip,rk-pwm"; reg = <0x0 0xff680020 0x0 0x10>; #pwm-cells = <2>; //pinctrl-names = "default"; //pinctrl-0 = <&pwm1_pin>; clocks = <&clk_gates13 6>; clock-names = "pclk_pwm"; status = "disabled"; }; pwm3: pwm@ff680030 { compatible = "rockchip,rk-pwm"; reg = <0x0 0xff680030 0x0 0x10>; #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; clocks = <&clk_gates13 6>; clock-names = "pclk_pwm"; status = "disabled"; }; remotectl: pwm@ff680030 { compatible = "rockchip,remotectl-pwm"; reg = <0x0 0xff680030 0x0 0x50>; #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; clocks = <&clk_gates13 6>; clock-names = "pclk_pwm"; dmas = <&pdma0 2>; #dma-cells = <2>; dma-names = "rx"; remote_pwm_id = <3>; interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; }; voppwm: pwm@ff9301a0 { compatible = "rockchip,vop-pwm"; reg = <0x0 0xff9301a0 0x0 0x10>; #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&vop_pwm_pin>; clocks = <&clk_gates4 2>, <&clk_gates16 5>, <&clk_gates16 6>; clock-names = "pclk_pwm", "aclk_lcdc", "hclk_lcdc"; status = "disabled"; }; pvtm { compatible = "rockchip,rk3368-pvtm"; rockchip,grf = <&grf>; rockchip,pmugrf = <&pmugrf>; rockchip,pvtm-clk-out = <0>; }; cpufreq { compatible = "rockchip,rk3368-cpufreq"; safe_freq_b = <1296000>; /* KHz */ safe_freq_l = <1008000>; /* KHz */ }; dvfs { vd_arm: vd_arm { regulator_name = "vdd_arm"; suspend_volt = <1000>; //mV pd_core { clk_core_b_dvfs_table: clk_core_b { operating-points = < /* KHz uV */ //216000 950000 312000 950000 408000 950000 600000 975000 696000 975000 816000 1000000 1008000 1100000 1200000 1175000 1416000 1300000 1488000 1325000 1512000 1350000 1608000 1390000 >; status = "okay"; cluster = <0>; channel = <1>; high_performance = <1>; dev_mode = <0>; }; }; }; vd_logic: vd_logic { regulator_name = "vdd_logic"; suspend_volt = <1000>; //mV pd_ddr { clk_ddr_dvfs_table: clk_ddr { operating-points = < /* KHz uV */ 200000 1200000 300000 1200000 400000 1200000 >; bd-freq-table = < /* bandwidth freq */ 2700 792000 2600 600000 2280 456000 1560 396000 1020 324000 720 240000 >; high_load = <70>; low_load = <60>; auto_freq_interval = <20>; /* ms */ down_rate_delay = <500>; /* ms */ channel = <2>; status = "disabled"; }; }; pd_gpu { clk_gpu_dvfs_table: clk_gpu { operating-points = < /* KHz uV */ 200000 1200000 300000 1200000 400000 1200000 >; channel = <1>; status = "okay"; regu-mode-table = < /*freq mode*/ 200000 4 0 3 >; regu-mode-en = <0>; }; }; }; }; ion { compatible = "rockchip,ion"; #address-cells = <1>; #size-cells = <0>; ion_cma: rockchip,ion-heap@4 { /* CMA HEAP */ compatible = "rockchip,ion-heap"; rockchip,ion_heap = <4>; reg = <0x00000000 0x00000000>; /* 0MB */ }; rockchip,ion-heap@0 { /* VMALLOC HEAP */ compatible = "rockchip,ion-heap"; rockchip,ion_heap = <0>; }; }; vpu: vpu_service { compatible = "rockchip,vpu_sub"; iommu_enabled = <1>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "irq_enc", "irq_dec"; dev_mode = <0>; name = "vpu_service"; }; hevc: hevc_service { compatible = "rockchip,hevc_sub"; iommu_enabled = <1>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "irq_dec"; dev_mode = <1>; name = "hevc_service"; }; vpu_combo: vpu_combo@ff9a0000 { compatible = "rockchip,vpu_combo"; reg = <0x0 0xff9a0000 0x0 0x800>; rockchip,grf = <&grf>; subcnt = <2>; rockchip,sub = <&vpu>, <&hevc>; clocks = <&aclk_vdpu>, <&hclk_vdpu>, <&clk_hevc_core>, <&clk_hevc_cabac>; clock-names = "aclk_vcodec", "hclk_vcodec", "clk_core", "clk_cabac"; resets = <&reset RK3368_SRST_VIDEO_H>, <&reset RK3368_SRST_VIDEO_A>, <&reset RK3368_SRST_VIDEO>; reset-names = "video_h", "video_a", "video"; mode_bit = <12>; mode_ctrl = <0x418>; name = "vpu_combo"; status = "okay"; }; iep: iep@ff900000 { compatible = "rockchip,iep"; iommu_enabled = <1>; reg = <0x0 0xff900000 0x0 0x800>; interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates16 2>, <&clk_gates16 3>; clock-names = "aclk_iep", "hclk_iep"; version = <2>; status = "okay"; }; gmac: eth@ff290000 { compatible = "rockchip,rk3368-gmac"; reg = <0x0 0xff290000 0x0 0x10000>; rockchip,grf = <&grf>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; /*irq=59*/ interrupt-names = "macirq"; clocks = <&clk_mac>, <&clk_gates7 4>, <&clk_gates7 5>, <&clk_gates7 6>, <&clk_gates7 7>, <&clk_gates20 13>, <&clk_gates20 14>; clock-names = "clk_mac", "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac"; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; status = "disabled"; }; gpu { compatible = "arm,rogue-G6110", "arm,rk3368-gpu"; reg = <0x0 0xffa30000 0x0 0x10000>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "GPU"; }; iep_mmu { dbgname = "iep"; compatible = "rockchip,iep_mmu"; reg = <0x0 0xff900800 0x0 0x100>; interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "iep_mmu"; }; vip_mmu { dbgname = "vip"; compatible = "rockchip,vip_mmu"; reg = <0x0 0xff950800 0x0 0x100>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vip_mmu"; }; vop_mmu { dbgname = "vop"; compatible = "rockchip,vopb_mmu"; reg = <0x0 0xff930300 0x0 0x100>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vop_mmu"; }; isp_mmu { dbgname = "isp_mmu"; compatible = "rockchip,isp_mmu"; reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "isp_mmu"; }; hdcp_mmu { dbgname = "hdcp_mmu"; compatible = "rockchip,hdcp_mmu"; reg = <0x0 0xff940000 0x0 0x100>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "hdcp_mmu"; }; hevc_mmu { dbgname = "hevc"; compatible = "rockchip,hevc_mmu"; reg = <0x0 0xff9a0440 0x0 0x40>, /*need to fix*/ <0x0 0xff9a0480 0x0 0x40>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; /*need to fix*/ interrupt-names = "hevc_mmu"; }; vpu_mmu { dbgname = "vpu"; compatible = "rockchip,vpu_mmu"; reg = <0x0 0xff9a0800 0x0 0x100>; /*need to fix*/ interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, /*need to fix*/ <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vepu_mmu", "vdpu_mmu"; }; rockchip_suspend: rockchip_suspend { rockchip,ctrbits = < (0 | RKPM_SLP_ARMOFF | RKPM_SLP_PMU_PLLS_PWRDN /*| RKPM_SLP_PMU_PMUALIVE_32K | RKPM_SLP_SFT_PLLS_DEEP | RKPM_SLP_PMU_DIS_OSC */ | RKPM_SLP_SFT_PD_NBSCUS ) >; }; isp: isp@ff910000{ compatible = "rockchip,isp"; reg = <0x0 0xff910000 0x0 0x10000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates16 0>, <&clk_gates16 14>, <&clk_isp>, <&clk_isp>, <&pclk_isp>, <&clk_vip>, <&clk_vip_pll>, <&clk_gates17 4>, <&clk_gates22 11>, <&pd_isp>, <&clk_gates16 9>; clock-names = "aclk_isp", "hclk_isp", "clk_isp", "clk_isp_jpe", "pclkin_isp", "clk_cif_out", "clk_cif_pll", "hclk_mipiphy1", "pclk_dphyrx", "pd_isp", "clk_vio0_noc"; pinctrl-names = "default", "isp_dvp8bit2", "isp_dvp10bit", "isp_dvp12bit", "isp_dvp8bit0", "isp_dvp8bit4", "isp_mipi_fl", "isp_mipi_fl_prefl","isp_flash_as_gpio","isp_flash_as_trigger_out"; pinctrl-0 = <&cif_clkout>; pinctrl-1 = <&cif_clkout &isp_dvp_d2d9>; pinctrl-2 = <&cif_clkout &isp_dvp_d2d9 &isp_dvp_d0d1>; pinctrl-3 = <&cif_clkout &isp_dvp_d2d9 &isp_dvp_d0d1 &isp_dvp_d10d11>; pinctrl-4 = <&cif_clkout &isp_dvp_d0d7>; pinctrl-5 = <&cif_clkout &isp_dvp_d4d11>; pinctrl-6 = <&cif_clkout>; pinctrl-7 = <&cif_clkout &isp_prelight>; pinctrl-8 = <&isp_flash_trigger_as_gpio>; pinctrl-9 = <&isp_flash_trigger>; rockchip,isp,mipiphy = <2>; rockchip,isp,cifphy = <1>; rockchip,isp,mipiphy1,reg = <0xff964000 0x4000>; rockchip,isp,csiphy,reg = <0xff96C000 0x4000>; rockchip,grf = <&grf>; rockchip,cru = <&cru>; rockchip,isp,iommu_enable = <1>; status = "okay"; }; cif: cif@ff950000 { compatible = "rockchip,cif"; reg = <0x0 0xff950000 0x0 0x10000>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; clocks = <&pclk_vip>,<&clk_gates16 11>,<&clk_gates16 12>,<&pclkin_vip>,<&clk_vip>; clock-names = "pclk_cif","aclk_cif0","hclk_cif0","cif0_in","cif0_out"; pinctrl-names = "cif_pin_all"; pinctrl-0 = <&cif_clkout &isp_dvp_d2d9 &isp_dvp_d10d11>; rockchip,grf = <&grf>; rockchip,cru = <&cru>; status = "okay"; }; /* thermal-zones { #include "rk3368-thermal.dtsi" }; */ tsadc: tsadc@ff280000 { compatible = "rockchip,rk3368-tsadc"; reg = <0x0 0xff280000 0x0 0x100>; interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_tsadc>, <&clk_gates20 0>; rockchip,grf = <&grf>; rockchip,cru = <&cru>; rockchip,pmu = <&pmu>; clock-names = "tsadc", "apb_pclk"; clock-frequency = <32000>; resets = <&reset RK3368_SRST_TSADC_P>; reset-names = "tsadc-apb"; //pinctrl-names = "default"; //pinctrl-0 = <&tsadc_int>; #thermal-sensor-cells = <1>; hw-shut-temp = <120000>; status = "disabled"; }; tsp: tsp@FF8B0000 { compatible = "rockchip,rk3368-tsp"; reg = <0x0 0xFF8B0000 0x0 0x10000>; clocks = <&clk_tsp>, <&clk_gates13 10>, <&clk_gates13 7>; clock-names = "clk_tsp", "hclk_tsp", "clk_hsadc0_tsp"; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "irq_tsp"; // pinctrl-names = "default"; // pinctrl-0 = <&isp_hsadc>; status = "okay"; }; crypto: crypto@FF8A0000{ compatible = "rockchip,rk3368-crypto"; reg = <0x0 0xFF8A0000 0x0 0x10000>; interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "irq_crypto"; clocks = <&clk_crypto>, <&clk_gates13 4>, <&clk_gates13 3>; clock-names = "clk_crypto", "hclk_crypto", "aclk_crypto"; status = "disabled"; }; dwc_control_usb: dwc-control-usb { compatible = "rockchip,rk3368-dwc-control-usb"; rockchip,grf = <&grf>; interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "otg_id", "otg_bvalid", "otg_linestate", "host0_linestate"; clocks = <&clk_gates20 6>, <&usbphy_480m>; clock-names = "hclk_usb_peri", "usbphy_480m"; //resets = <&reset RK3128_RST_USBPOR>; //reset-names = "usbphy_por"; usb_bc{ compatible = "inno,phy"; regbase = &dwc_control_usb; rk_usb,bvalid = <0x4bc 23 1>; rk_usb,iddig = <0x4bc 26 1>; rk_usb,vdmsrcen = <0x718 12 1>; rk_usb,vdpsrcen = <0x718 11 1>; rk_usb,rdmpden = <0x718 10 1>; rk_usb,idpsrcen = <0x718 9 1>; rk_usb,idmsinken = <0x718 8 1>; rk_usb,idpsinken = <0x718 7 1>; rk_usb,dpattach = <0x4b8 31 1>; rk_usb,cpdet = <0x4b8 30 1>; rk_usb,dcpattach = <0x4b8 29 1>; }; }; usbphy: phy { compatible = "rockchip,rk3368-usb-phy"; rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>; usbphy0: usb-phy0 { #phy-cells = <0>; reg = <0x700>; }; usbphy1: usb-phy1 { #phy-cells = <0>; reg = <0x728>; }; }; usb0: usb@ff580000 { compatible = "rockchip,rk3368_usb20_otg"; reg = <0x0 0xff580000 0x0 0x40000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates8 1>, <&clk_gates20 1>; clock-names = "clk_usbphy0", "hclk_otg"; resets = <&reset RK3368_SRST_USBOTG0_H>, <&reset RK3368_SRST_USBOTGPHY0>, <&reset RK3368_SRST_USBOTGC0>; reset-names = "otg_ahb", "otg_phy", "otg_controller"; /*0 - Normal, 1 - Force Host, 2 - Force Device*/ rockchip,usb-mode = <0>; }; usb_ehci: usb@ff500000 { compatible = "generic-ehci"; reg = <0x0 0xff500000 0x0 0x20000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates8 1>, <&clk_gates20 3>; clock-names = "clk_usbphy0", "hclk_ehci"; phys = <&usbphy1>; phy-names = "usb"; //resets = <&reset RK3288_SOFT_RST_USBHOST0_H>, <&reset RK3288_SOFT_RST_USBHOST0PHY>, // <&reset RK3288_SOFT_RST_USBHOST0C>, <&reset RK3288_SOFT_RST_USB_HOST0>; //reset-names = "ehci_ahb", "ehci_phy", "ehci_controller", "ehci"; }; usb_ohci: usb@ff520000 { compatible = "generic-ohci"; reg = <0x0 0xff520000 0x0 0x20000>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates8 1>, <&clk_gates20 3>; clock-names = "clk_usbphy0", "hclk_ohci"; }; usb_ehci1: usb@ff5c0000 { compatible = "rockchip,rk3288_rk_ehci1_host"; reg = <0x0 0xff5c0000 0x0 0x40000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; /* clocks = <&ehci1phy_480m>, <&clk_gates7 8>, <&ehci1phy_12m>, <&usbphy_480m>, <&otgphy1_480m>, <&otgphy2_480m>; clock-names = "ehci1phy_480m", "hclk_ehci1", "ehci1phy_12m", "usbphy_480m", "ehci1_usbphy1", "ehci1_usbphy2"; resets = <&reset RK3368_SRST_EHCI1>, <&reset RK3368_SRST_EHCI1_AUX>, <&reset RK3368_SRST_EHCI1PHY>; reset-names = "ehci1_ahb", "ehci1_aux", "ehci1_phy"; */ status = "disabled"; }; pinctrl: pinctrl { compatible = "rockchip,rk3368-pinctrl"; rockchip,grf = <&grf>; rockchip,pmugrf = <&pmugrf>; #address-cells = <2>; #size-cells = <2>; ranges; gpio0: gpio0@ff750000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff750000 0x0 0x100>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates23 4>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; }; gpio1: gpio1@ff780000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff780000 0x0 0x100>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates22 1>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; }; gpio2: gpio2@ff790000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff790000 0x0 0x100>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates22 2>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; }; gpio3: gpio3@ff7a0000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff7a0000 0x0 0x100>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk_gates22 3>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; }; pcfg_pull_up: pcfg-pull-up { bias-pull-up; }; pcfg_pull_down: pcfg-pull-down { bias-pull-down; }; pcfg_pull_none: pcfg-pull-none { bias-disable; }; pcfg_pull_none_drv_8ma: pcfg-pull-none-drv-8ma { drive-strength = <8>; }; pcfg_pull_none_drv_12ma: pcfg-pull-none-drv-12ma { drive-strength = <12>; }; pcfg_pull_up_drv_8ma: pcfg-pull-up-drv-8ma { bias-pull-up; drive-strength = <8>; }; pcfg_pull_none_drv_4ma: pcfg-pull-none-drv-4ma { drive-strength = <4>; }; pcfg_pull_up_drv_4ma: pcfg-pull-up-drv-4ma { bias-pull-up; drive-strength = <4>; }; pcfg_output_high: pcfg-output-high { output-high; }; pcfg_output_low: pcfg-output-low { output-low; }; pcfg_input_high: pcfg-input-high { bias-pull-up; input-enable; }; i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = <0 GPIO_A6 RK_FUNC_1 &pcfg_pull_none>, <0 GPIO_A7 RK_FUNC_1 &pcfg_pull_none>; }; i2c0_gpio: i2c0-gpio { rockchip,pins = <0 GPIO_A6 RK_FUNC_GPIO &pcfg_pull_none>, <0 GPIO_A7 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c0_sleep: i2c0-sleep { rockchip,pins = <0 GPIO_A6 RK_FUNC_GPIO &pcfg_input_high>, <0 GPIO_A7 RK_FUNC_GPIO &pcfg_input_high>; }; }; i2c1 { i2c1_xfer: i2c1-xfer { rockchip,pins = <2 GPIO_C5 RK_FUNC_1 &pcfg_pull_none>, <2 GPIO_C6 RK_FUNC_1 &pcfg_pull_none>; }; i2c1_gpio: i2c1-gpio { rockchip,pins = <2 GPIO_C5 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_C6 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c1_sleep: i2c1-sleep { rockchip,pins = <2 GPIO_C5 RK_FUNC_GPIO &pcfg_input_high>, <2 GPIO_C6 RK_FUNC_GPIO &pcfg_input_high>; }; }; i2c2 { i2c2_xfer: i2c2-xfer { rockchip,pins = <3 GPIO_D7 RK_FUNC_2 &pcfg_pull_none>, <0 GPIO_B1 RK_FUNC_2 &pcfg_pull_none>; }; i2c2_gpio: i2c2-gpio { rockchip,pins = <3 GPIO_D7 RK_FUNC_GPIO &pcfg_pull_none>, <0 GPIO_B1 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c2_sleep: i2c2-sleep { rockchip,pins = <3 GPIO_D7 RK_FUNC_GPIO &pcfg_input_high>, <0 GPIO_B1 RK_FUNC_GPIO &pcfg_input_high>; }; }; i2c3 { i2c3_xfer: i2c3-xfer { rockchip,pins = <1 GPIO_C0 RK_FUNC_1 &pcfg_pull_none>, <1 GPIO_C1 RK_FUNC_1 &pcfg_pull_none>; }; i2c3_gpio: i2c3-gpio { rockchip,pins = <1 GPIO_C0 RK_FUNC_GPIO &pcfg_pull_none>, <1 GPIO_C1 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c3_sleep: i2c3-sleep { rockchip,pins = <1 GPIO_C0 RK_FUNC_GPIO &pcfg_input_high>, <1 GPIO_C1 RK_FUNC_GPIO &pcfg_input_high>; }; }; i2c4 { i2c4_xfer: i2c4-xfer { rockchip,pins = <3 GPIO_D0 RK_FUNC_2 &pcfg_pull_none>, <3 GPIO_D1 RK_FUNC_2 &pcfg_pull_none>; }; i2c4_gpio: i2c4-gpio { rockchip,pins = <3 GPIO_D0 RK_FUNC_GPIO &pcfg_pull_none>, <3 GPIO_D1 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c4_sleep: i2c4-sleep { rockchip,pins = <3 GPIO_D0 RK_FUNC_GPIO &pcfg_input_high>, <3 GPIO_D1 RK_FUNC_GPIO &pcfg_input_high>; }; }; i2c5 { i2c5_xfer: i2c5-xfer { rockchip,pins = <3 GPIO_D2 RK_FUNC_2 &pcfg_pull_none>, <3 GPIO_D3 RK_FUNC_2 &pcfg_pull_none>; }; i2c5_gpio: i2c5-gpio { rockchip,pins = <3 GPIO_D2 RK_FUNC_GPIO &pcfg_pull_none>, <3 GPIO_D3 RK_FUNC_GPIO &pcfg_pull_none>; }; i2c5_sleep: i2c5-sleep { rockchip,pins = <3 GPIO_D2 RK_FUNC_GPIO &pcfg_input_high>, <3 GPIO_D3 RK_FUNC_GPIO &pcfg_input_high>; }; }; uart0 { uart0_xfer: uart0-xfer { rockchip,pins = <2 GPIO_D0 RK_FUNC_1 &pcfg_pull_up>, <2 GPIO_D1 RK_FUNC_1 &pcfg_pull_none>; }; uart0_cts: uart0-cts { rockchip,pins = <2 GPIO_D2 RK_FUNC_1 &pcfg_pull_none>; }; uart0_rts: uart0-rts { rockchip,pins = <2 GPIO_D3 RK_FUNC_1 &pcfg_pull_none>; }; uart0_rts_gpio: uart0-rts-gpio { rockchip,pins = <2 GPIO_D3 RK_FUNC_GPIO &pcfg_pull_none>; }; }; uart1 { uart1_xfer: uart1-xfer { rockchip,pins = <0 GPIO_C4 RK_FUNC_3 &pcfg_pull_up>, <0 GPIO_C5 RK_FUNC_3 &pcfg_pull_none>; }; uart1_cts: uart1-cts { rockchip,pins = <0 GPIO_C6 RK_FUNC_3 &pcfg_pull_none>; }; uart1_rts: uart1-rts { rockchip,pins = <0 GPIO_C7 RK_FUNC_3 &pcfg_pull_none>; }; }; uart2 { uart2_xfer: uart2-xfer { rockchip,pins = <2 GPIO_A6 RK_FUNC_2 &pcfg_pull_up>, <2 GPIO_A5 RK_FUNC_2 &pcfg_pull_none>; }; }; uart3 { uart3_xfer: uart3-xfer { rockchip,pins = <3 GPIO_D5 RK_FUNC_2 &pcfg_pull_up>, <3 GPIO_D6 RK_FUNC_2 &pcfg_pull_none>; }; uart3_cts: uart3-cts { rockchip,pins = <3 GPIO_C0 RK_FUNC_2 &pcfg_pull_none>; }; uart3_rts: uart3-rts { rockchip,pins = <3 GPIO_C1 RK_FUNC_2 &pcfg_pull_none>; }; }; uart4 { uart4_xfer: uart4-xfer { rockchip,pins = <0 GPIO_D3 RK_FUNC_3 &pcfg_pull_up>, <0 GPIO_D2 RK_FUNC_3 &pcfg_pull_none>; }; uart4_cts: uart4-cts { rockchip,pins = <0 GPIO_D0 RK_FUNC_3 &pcfg_pull_none>; }; uart4_rts: uart4-rts { rockchip,pins = <0 GPIO_D1 RK_FUNC_3 &pcfg_pull_none>; }; }; spi0 { spi0_clk: spi0-clk { rockchip,pins = <1 GPIO_D5 RK_FUNC_2 &pcfg_pull_up>; }; spi0_cs0: spi0-cs0 { rockchip,pins = <1 GPIO_D0 RK_FUNC_3 &pcfg_pull_up>; }; spi0_tx: spi0-tx { rockchip,pins = <1 GPIO_C7 RK_FUNC_3 &pcfg_pull_up>; }; spi0_rx: spi0-rx { rockchip,pins = <1 GPIO_C6 RK_FUNC_3 &pcfg_pull_up>; }; spi0_cs1: spi0-cs1 { rockchip,pins = <1 GPIO_D1 RK_FUNC_3 &pcfg_pull_up>; }; }; spi1 { spi1_clk: spi1-clk { rockchip,pins = <1 GPIO_B6 RK_FUNC_2 &pcfg_pull_up>; }; spi1_cs0: spi1-cs0 { rockchip,pins = <1 GPIO_B7 RK_FUNC_2 &pcfg_pull_up>; }; spi1_rx: spi1-rx { rockchip,pins = <1 GPIO_C0 RK_FUNC_2 &pcfg_pull_up>; }; spi1_tx: spi1-tx { rockchip,pins = <1 GPIO_C1 RK_FUNC_2 &pcfg_pull_up>; }; spi1_cs1: spi1-cs1 { rockchip,pins = <3 GPIO_D4 RK_FUNC_2 &pcfg_pull_up>; }; }; spi2 { spi2_clk: spi2-clk { rockchip,pins = <0 GPIO_B4 RK_FUNC_2 &pcfg_pull_up>; }; spi2_cs0: spi2-cs0 { rockchip,pins = <0 GPIO_B5 RK_FUNC_2 &pcfg_pull_up>; }; spi2_rx: spi2-rx { rockchip,pins = <0 GPIO_B2 RK_FUNC_2 &pcfg_pull_up>; }; spi2_tx: spi2-tx { rockchip,pins = <0 GPIO_B3 RK_FUNC_2 &pcfg_pull_up>; }; }; i2s { i2s_mclk: i2s-mclk { rockchip,pins = <2 GPIO_C4 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sclk:i2s-sclk { rockchip,pins = <2 GPIO_B4 RK_FUNC_1 &pcfg_pull_none>; }; i2s_lrckrx:i2s-lrckrx { rockchip,pins = <2 GPIO_B5 RK_FUNC_1 &pcfg_pull_none>; }; i2s_lrcktx:i2s-lrcktx { rockchip,pins = <2 GPIO_B6 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sdi:i2s-sdi { rockchip,pins = <2 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sdo0:i2s-sdo0 { rockchip,pins = <2 GPIO_C0 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sdo1:i2s-sdo1 { rockchip,pins = <2 GPIO_C1 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sdo2:i2s-sdo2 { rockchip,pins = <2 GPIO_C2 RK_FUNC_1 &pcfg_pull_none>; }; i2s_sdo3:i2s-sdo3 { rockchip,pins = <2 GPIO_C3 RK_FUNC_1 &pcfg_pull_none>; }; i2s_gpio: i2s-gpio { rockchip,pins = <2 GPIO_C4 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_B4 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_B5 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_B6 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_B7 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_C0 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_C1 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_C2 RK_FUNC_GPIO &pcfg_pull_none>, <2 GPIO_C3 RK_FUNC_GPIO &pcfg_pull_none>; }; }; spdif { spdif_tx: spdif-tx { rockchip,pins = <2 GPIO_C7 RK_FUNC_1 &pcfg_pull_none>; }; }; sdmmc { sdmmc_clk: sdmmc-clk { rockchip,pins = <2 GPIO_B1 RK_FUNC_1 &pcfg_pull_none_drv_4ma>; }; sdmmc_cmd: sdmmc-cmd { rockchip,pins = <2 GPIO_B2 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdmmc_dectn: sdmmc-dectn { rockchip,pins = <2 GPIO_B3 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdmmc_bus1: sdmmc-bus1 { rockchip,pins = <2 GPIO_A5 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdmmc_bus4: sdmmc-bus4 { rockchip,pins = <2 GPIO_A5 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_A6 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_A7 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_B0 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdmmc_gpio: sdmmc-gpio { rockchip,pins = <2 GPIO_B1 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//CLK <2 GPIO_B2 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//CMD <2 GPIO_B3 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//DET <2 GPIO_A5 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//DO <2 GPIO_A6 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//D1 <2 GPIO_A7 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//D2 <2 GPIO_B0 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>;//D3 }; }; sdio0 { sdio0_bus1: sdio0-bus1 { rockchip,pins = <2 GPIO_D4 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdio0_bus4: sdio0-bus4 { rockchip,pins = <2 GPIO_D4 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_D5 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_D6 RK_FUNC_1 &pcfg_pull_up_drv_4ma>, <2 GPIO_D7 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdio0_cmd: sdio0-cmd { rockchip,pins = <3 GPIO_A0 RK_FUNC_1 &pcfg_pull_up_drv_4ma>; }; sdio0_clk: sdio0-clk { rockchip,pins = <3 GPIO_A1 RK_FUNC_1 &pcfg_pull_none_drv_4ma>; }; sdio0_dectn: sdio0-dectn { rockchip,pins = <3 GPIO_A2 RK_FUNC_1 &pcfg_pull_up>; }; sdio0_wrprt: sdio0-wrprt { rockchip,pins = <3 GPIO_A3 RK_FUNC_1 &pcfg_pull_up>; }; sdio0_pwren: sdio0-pwren { rockchip,pins = <3 GPIO_A4 RK_FUNC_1 &pcfg_pull_up>; }; sdio0_bkpwr: sdio0-bkpwr { rockchip,pins = <3 GPIO_A5 RK_FUNC_1 &pcfg_pull_up>; }; sdio0_int: sdio0-int { rockchip,pins = <3 GPIO_A6 RK_FUNC_1 &pcfg_pull_up>; }; sdio0_gpio: sdio0-gpio { rockchip,pins = <3 GPIO_A0 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//CMD <3 GPIO_A1 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//CLK <3 GPIO_A2 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//DET <3 GPIO_A3 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//wrprt <3 GPIO_A4 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//PWREN <3 GPIO_A5 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//BKPWR <3 GPIO_A6 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//INTN <2 GPIO_D4 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//DO <2 GPIO_D5 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//D1 <2 GPIO_D6 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>,//D2 <2 GPIO_D7 RK_FUNC_GPIO &pcfg_pull_up_drv_4ma>;//D3 }; }; emmc { emmc_clk: emmc-clk { rockchip,pins = <2 GPIO_A4 RK_FUNC_2 &pcfg_pull_none_drv_8ma>; }; emmc_cmd: emmc-cmd { rockchip,pins = <1 GPIO_D2 RK_FUNC_2 &pcfg_pull_up_drv_8ma>; }; emmc_pwren: emmc-pwren { rockchip,pins = <1 GPIO_D3 RK_FUNC_2 &pcfg_pull_none>; }; emmc_rstnout: emmc_rstnout { rockchip,pins = <2 GPIO_A3 RK_FUNC_2 &pcfg_pull_none>; }; emmc_bus1: emmc-bus1 { rockchip,pins = <1 GPIO_C2 RK_FUNC_2 &pcfg_pull_up_drv_8ma>;//DO }; emmc_bus4: emmc-bus4 { rockchip,pins = <1 GPIO_C2 RK_FUNC_2 &pcfg_pull_up_drv_8ma>,//DO <1 GPIO_C3 RK_FUNC_2 &pcfg_pull_up_drv_8ma>,//D1 <1 GPIO_C4 RK_FUNC_2 &pcfg_pull_up_drv_8ma>,//D2 <1 GPIO_C5 RK_FUNC_2 &pcfg_pull_up_drv_8ma>;//D3 }; }; pwm0 { pwm0_pin: pwm0-pin { rockchip,pins = <3 GPIO_B0 RK_FUNC_2 &pcfg_pull_none>; }; vop_pwm_pin:vop-pwm { rockchip,pins = <3 GPIO_B0 RK_FUNC_3 &pcfg_pull_none>; }; }; pwm1 { pwm1_pin: pwm1-pin { rockchip,pins = <0 GPIO_B0 RK_FUNC_2 &pcfg_pull_none>; }; }; pwm3 { pwm3_pin: pwm3-pin { rockchip,pins = <3 GPIO_D6 RK_FUNC_3 &pcfg_pull_none>; }; }; lcdc { lcdc_lcdc: lcdc-lcdc { rockchip,pins = <0 GPIO_B6 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D10 <0 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D11 <0 GPIO_C0 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D12 <0 GPIO_C1 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D13 <0 GPIO_C2 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D14 <0 GPIO_C3 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D15 <0 GPIO_C4 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D16 <0 GPIO_C5 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D17 <0 GPIO_C6 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D18 <0 GPIO_C7 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D19 <0 GPIO_D0 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D20 <0 GPIO_D1 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D21 <0 GPIO_D2 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D22 <0 GPIO_D3 RK_FUNC_1 &pcfg_pull_none>,//LCDC_D23 <0 GPIO_D7 RK_FUNC_1 &pcfg_pull_none>,//DCLK <0 GPIO_D6 RK_FUNC_1 &pcfg_pull_none>,//DEN <0 GPIO_D4 RK_FUNC_1 &pcfg_pull_none>,//HSYNC <0 GPIO_D5 RK_FUNC_1 &pcfg_pull_none>;//VSYN }; lcdc_gpio: lcdc-gpio { rockchip,pins = <0 GPIO_B6 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D10 <0 GPIO_B7 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D11 <0 GPIO_C0 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D12 <0 GPIO_C1 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D13 <0 GPIO_C2 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D14 <0 GPIO_C3 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D15 <0 GPIO_C4 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D16 <0 GPIO_C5 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D17 <0 GPIO_C6 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D18 <0 GPIO_C7 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D19 <0 GPIO_D0 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D20 <0 GPIO_D1 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D21 <0 GPIO_D2 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D22 <0 GPIO_D3 RK_FUNC_GPIO &pcfg_pull_none>,//LCDC_D23 <0 GPIO_D7 RK_FUNC_GPIO &pcfg_pull_none>,//DCLK <0 GPIO_D6 RK_FUNC_GPIO &pcfg_pull_none>,//DEN <0 GPIO_D4 RK_FUNC_GPIO &pcfg_pull_none>,//HSYNC <0 GPIO_D5 RK_FUNC_GPIO &pcfg_pull_none>;//VSYN }; }; isp { cif_clkout: cif-clkout { rockchip,pins = <1 GPIO_B3 RK_FUNC_1 &pcfg_pull_none>;//cif_clkout }; isp_dvp_d2d9: isp-dvp-d2d9 { rockchip,pins = <1 GPIO_A0 RK_FUNC_1 &pcfg_pull_none>,//cif_data2 <1 GPIO_A1 RK_FUNC_1 &pcfg_pull_none>,//cif_data3 <1 GPIO_A2 RK_FUNC_1 &pcfg_pull_none>,//cif_data4 <1 GPIO_A3 RK_FUNC_1 &pcfg_pull_none>,//cif_data5 <1 GPIO_A4 RK_FUNC_1 &pcfg_pull_none>,//cif_data6 <1 GPIO_A5 RK_FUNC_1 &pcfg_pull_none>,//cif_data7 <1 GPIO_A6 RK_FUNC_1 &pcfg_pull_none>,//cif_data8 <1 GPIO_A7 RK_FUNC_1 &pcfg_pull_none>,//cif_data9 <1 GPIO_B0 RK_FUNC_1 &pcfg_pull_none>,//cif_sync <1 GPIO_B1 RK_FUNC_1 &pcfg_pull_none>,//cif_href <1 GPIO_B2 RK_FUNC_1 &pcfg_pull_none>,//cif_clkin <1 GPIO_B3 RK_FUNC_1 &pcfg_pull_none>;//cif_clkout }; isp_dvp_d0d1: isp-dvp-d0d1 { rockchip,pins = <1 GPIO_B4 RK_FUNC_1 &pcfg_pull_none>,//cif_data0 <1 GPIO_B5 RK_FUNC_1 &pcfg_pull_none>;//cif_data1 }; isp_dvp_d10d11:isp_d10d11 { rockchip,pins = <1 GPIO_B6 RK_FUNC_1 &pcfg_pull_none>,//cif_data10 <1 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>;//cif_data11 }; isp_dvp_d0d7: isp-dvp-d0d7 { rockchip,pins = <1 GPIO_B4 RK_FUNC_1 &pcfg_pull_none>,//cif_data0 <1 GPIO_B5 RK_FUNC_1 &pcfg_pull_none>,//cif_data1 <1 GPIO_A0 RK_FUNC_1 &pcfg_pull_none>,//cif_data2 <1 GPIO_A1 RK_FUNC_1 &pcfg_pull_none>,//cif_data3 <1 GPIO_A2 RK_FUNC_1 &pcfg_pull_none>,//cif_data4 <1 GPIO_A3 RK_FUNC_1 &pcfg_pull_none>,//cif_data5 <1 GPIO_A4 RK_FUNC_1 &pcfg_pull_none>,//cif_data6 <1 GPIO_A5 RK_FUNC_1 &pcfg_pull_none>;//cif_data7 }; isp_dvp_d4d11: isp-dvp-d4d11 { rockchip,pins = <1 GPIO_A2 RK_FUNC_1 &pcfg_pull_none>,//cif_data4 <1 GPIO_A3 RK_FUNC_1 &pcfg_pull_none>,//cif_data5 <1 GPIO_A4 RK_FUNC_1 &pcfg_pull_none>,//cif_data6 <1 GPIO_A5 RK_FUNC_1 &pcfg_pull_none>,//cif_data7 <1 GPIO_A6 RK_FUNC_1 &pcfg_pull_none>,//cif_data8 <1 GPIO_A7 RK_FUNC_1 &pcfg_pull_none>,//cif_data9 <1 GPIO_B6 RK_FUNC_1 &pcfg_pull_none>,//cif_data10 <1 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>;//cif_data11 }; isp_shutter: isp-shutter { rockchip,pins = <3 GPIO_C3 RK_FUNC_2 &pcfg_pull_none>, //SHUTTEREN <3 GPIO_C6 RK_FUNC_2 &pcfg_pull_none>;//SHUTTERTRIG }; isp_flash_trigger: isp-flash-trigger { rockchip,pins = <3 GPIO_C4 RK_FUNC_2 &pcfg_pull_none>; //ISP_FLASHTRIGOU }; isp_prelight: isp-prelight { rockchip,pins = <3 GPIO_C5 RK_FUNC_2 &pcfg_pull_none>;//ISP_PRELIGHTTRIG }; isp_flash_trigger_as_gpio: isp_flash_trigger_as_gpio { rockchip,pins = <3 GPIO_C4 RK_FUNC_GPIO &pcfg_pull_none>;//ISP_FLASHTRIGOU }; }; gps { gps_mag: gps-mag { rockchip,pins = <3 GPIO_B6 RK_FUNC_2 &pcfg_pull_none>; }; gps_sig: gps-sig { rockchip,pins = <3 GPIO_B7 RK_FUNC_2 &pcfg_pull_none>; }; gps_rfclk: gps-rfclk { rockchip,pins = <3 GPIO_C0 RK_FUNC_3 &pcfg_pull_none>; }; }; gmac { rgmii_pins: rgmii-pins { rockchip,pins = <3 GPIO_C6 RK_FUNC_1 &pcfg_pull_none>,//MAC_CLK <3 GPIO_D0 RK_FUNC_1 &pcfg_pull_none>,//MDIO <3 GPIO_C3 RK_FUNC_1 &pcfg_pull_none>,//MDC <3 GPIO_B0 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD0 <3 GPIO_B1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD1 <3 GPIO_B2 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD2 <3 GPIO_B6 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD3 <3 GPIO_D4 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXCLK <3 GPIO_B5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXEN <3 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>,//RXD0 <3 GPIO_C0 RK_FUNC_1 &pcfg_pull_none>,//RXD1 <3 GPIO_C1 RK_FUNC_1 &pcfg_pull_none>,//RXD2 <3 GPIO_C2 RK_FUNC_1 &pcfg_pull_none>,//RXD3 <3 GPIO_D1 RK_FUNC_1 &pcfg_pull_none>,//RXCLK <3 GPIO_C4 RK_FUNC_1 &pcfg_pull_none>;//RXDV }; rmii_pins: rmii-pins { rockchip,pins = <3 GPIO_C6 RK_FUNC_1 &pcfg_pull_none>,//MAC_CLK <3 GPIO_D0 RK_FUNC_1 &pcfg_pull_none>,//MDIO <3 GPIO_C3 RK_FUNC_1 &pcfg_pull_none>,//MDC <3 GPIO_B0 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD0 <3 GPIO_B1 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXD1 <3 GPIO_B5 RK_FUNC_1 &pcfg_pull_none_drv_12ma>,//TXEN <3 GPIO_B7 RK_FUNC_1 &pcfg_pull_none>,//RXD0 <3 GPIO_C0 RK_FUNC_1 &pcfg_pull_none>,//RXD1 <3 GPIO_C4 RK_FUNC_1 &pcfg_pull_none>,//RXDV <3 GPIO_C5 RK_FUNC_1 &pcfg_pull_none>;//RXER }; }; tsadc_pin { tsadc_int: tsadc-int { rockchip,pins = <0 GPIO_A3 RK_FUNC_1 &pcfg_pull_none>; }; tsadc_gpio: tsadc-gpio { rockchip,pins = <0 GPIO_A3 RK_FUNC_GPIO &pcfg_pull_none>; }; }; hdmi_pin { hdmi_cec: hdmi-cec { rockchip,pins = <3 GPIO_C7 RK_FUNC_1 &pcfg_pull_none>; }; }; hdmi_i2c { hdmii2c_xfer: hdmii2c-xfer { rockchip,pins = <3 GPIO_D2 RK_FUNC_1 &pcfg_pull_none>, <3 GPIO_D3 RK_FUNC_1 &pcfg_pull_none>; }; }; cpu_jtag { cpu_jtag: cpu-jtag { rockchip,pins = <2 GPIO_A7 RK_FUNC_2 &pcfg_pull_up>, <2 GPIO_B0 RK_FUNC_2 &pcfg_pull_up>; }; }; mcu_jtag { mcu_jtag: mcu-jtag { rockchip,pins = <2 GPIO_B2 RK_FUNC_2 &pcfg_pull_up>, <2 GPIO_B1 RK_FUNC_2 &pcfg_pull_up>; }; }; }; reboot { compatible = "rockchip,rk3368-reboot"; rockchip,cru = <&cru>; rockchip,pmugrf = <&pmugrf>; }; };
Also from what I have read we should be able to overclock without dvfs. Dvfs is just for automatically adjusting clock speeds. If we want 1608 all of the time then we don't even need dvfs. That is if I understand correctly.
So what I need to do is either edit the voltages without dvfs or enable dvfs. I would prefer to enable dvfs. Please help me enable dvfs.Last edited by l33tlinuxh4x0r; 05 December 2016, 20:10.
There are currently 5906 users online. 1 members and 5905 guests.
