Tutorial: Enable RK3368 True Octa-Core Processor - Part 1 of 2
Shomari I just flashed the stock geekbox kernel (built without any modifications) and I get the same errors about dvfs not being enabled. I get it for core b and core l which is to be expected. Something in their sources (the same source that I'm using) is disabling dvfs. I am looking for new kernel sources now.
I found why this was spamming the log.
Code:[ 37.649728] [1: cfinteractive: 79] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error
Code:[ 30.818006] [2: sh: 615] -------------DVFS TREE----------- [ 30.818006] [2: sh: 615] [ 30.818006] [2: sh: 615] [ 30.818089] [2: sh: 615] DVFS TREE: [ 30.818115] [2: sh: 615] | [ 30.818115] [2: sh: 615] |- voltage domain:vd_logic [ 30.818159] [2: sh: 615] |- current voltage:0 [ 30.818184] [2: sh: 615] |- current regu_mode:UNKNOWN [ 30.818213] [2: sh: 615] | | [ 30.818213] [2: sh: 615] | |- power domain:pd_gpu, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 30.818263] [2: sh: 615] | | | [ 30.818263] [2: sh: 615] | | |- clock: clk_gpu current: rate 0, volt = 0, enable_dvfs = DISABLE [ 30.818313] [2: sh: 615] | | |- clk limit(disable):[0, 0]; last set rate = 200000 [ 30.818341] [2: sh: 615] | | | |- freq = 200000, volt = 1200000 [ 30.818368] [2: sh: 615] | | | |- freq = 300000, volt = 1200000 [ 30.818395] [2: sh: 615] | | | |- freq = 400000, volt = 1200000 [ 30.818421] [2: sh: 615] | | | |- freq = 600000, volt = 1200000 [ 30.818450] [2: sh: 615] | | |- clock: clk_gpu current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 30.818481] [2: sh: 615] | | [ 30.818481] [2: sh: 615] | |- power domain:pd_ddr, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 30.818531] [2: sh: 615] | | | [ 30.818531] [2: sh: 615] | | |- clock: clk_ddr current: rate 0, volt = 0, enable_dvfs = DISABLE [ 30.818582] [2: sh: 615] | | |- clk limit(disable):[0, 0]; last set rate = 600000 [ 30.818877] [2: sh: 615] | | | |- freq = 200000, volt = 1200000 [ 30.818917] [2: sh: 615] | | | |- freq = 300000, volt = 1200000 [ 30.818944] [2: sh: 615] | | | |- freq = 400000, volt = 1200000 [ 30.818972] [2: sh: 615] | | | |- freq = 533000, volt = 1150000 [ 30.818999] [2: sh: 615] | | | |- freq = 800000, volt = 1200000 [ 30.819027] [2: sh: 615] | | |- clock: clk_ddr current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 30.819057] [2: sh: 615] | [ 30.819057] [2: sh: 615] |- voltage domain:vd_arm [ 30.819103] [2: sh: 615] |- current voltage:0 [ 30.819128] [2: sh: 615] |- current regu_mode:UNKNOWN [ 30.819158] [2: sh: 615] | | [ 30.819158] [2: sh: 615] | |- power domain:pd_core, status = OFF, current volt = 0, current regu_mode = UNKNOWN [ 30.819208] [2: sh: 615] | | | [ 30.819208] [2: sh: 615] | | |- clock: clk_core_b current: rate 0, volt = 0, enable_dvfs = DISABLE [ 30.819259] [2: sh: 615] | | |- clk limit(enable):[216000000, 1608000000]; last set rate = 1512000 [ 30.819288] [2: sh: 615] | | | |- freq = 216000, volt = 950000 [ 30.819317] [2: sh: 615] | | | |- freq = 312000, volt = 950000 [ 30.819344] [2: sh: 615] | | | |- freq = 408000, volt = 950000 [ 30.819370] [2: sh: 615] | | | |- freq = 600000, volt = 975000 [ 30.819396] [2: sh: 615] | | | |- freq = 696000, volt = 975000 [ 30.819423] [2: sh: 615] | | | |- freq = 816000, volt = 1000000 [ 30.819450] [2: sh: 615] | | | |- freq = 1008000, volt = 1100000 [ 30.819477] [2: sh: 615] | | | |- freq = 1200000, volt = 1175000 [ 30.819504] [2: sh: 615] | | | |- freq = 1416000, volt = 1300000 [ 30.819531] [2: sh: 615] | | | |- freq = 1488000, volt = 1325000 [ 30.819558] [2: sh: 615] | | | |- freq = 1512000, volt = 1350000 [ 30.819585] [2: sh: 615] | | | |- freq = 1608000, volt = 1390000 [ 30.819613] [2: sh: 615] | | |- clock: clk_core_b current: rate 0, regu_mode = UNKNOWN, regu_mode_en = 0 [ 30.819641] [2: sh: 615] -------------DVFS TREE END------------
EDIT:
Current errors:
Code:[ 2.799884] [0: swapper/0: 1] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 2.799917] [0: swapper/0: 1] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 2.799950] [0: swapper/0: 1] DVFS ERR: clk_enable_dvfs: vd(vd_arm) can't get regulator(vdd_arm)! [ 2.799979] [0: swapper/0: 1] rockchip_big_little: cluster_cpus_freq_dvfs_init:cluster_id=1,get dvfs err [ 2.800987] [0: swapper/0: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 2.801019] [0: swapper/0: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 2.968106] [1: swapper/0: 1] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)! [ 2.968810] [0: ddrfreqd: 137] DVFS ERR: dvfs_target: clk_ddr is disable, set rate error [ 3.337357] [7: init: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 3.337600] [7: init: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 5.163547] [1: pvrsrvctl: 183] rgx_dvfs_infotbl[0].clock=200,min_threshold=0,max_threshold=40,coef=100 [ 5.163584] [1: pvrsrvctl: 183] rgx_dvfs_infotbl[1].clock=300,min_threshold=50,max_threshold=60,coef=95 [ 5.163617] [1: pvrsrvctl: 183] rgx_dvfs_infotbl[2].clock=400,min_threshold=70,max_threshold=80,coef=90 [ 5.163651] [1: pvrsrvctl: 183] rgx_dvfs_infotbl[3].clock=600,min_threshold=86,max_threshold=100,coef=85 [ 5.163854] [1: pvrsrvctl: 183] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 5.189547] [4: pvrsrvctl: 183] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 16.597631] [3: system_server: 605] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 36.782223] [3: init: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error [ 36.783799] [3: init: 1] DVFS ERR: dvfs_target: clk_core_b is disable, set rate error
Originally posted by l33tlinuxh4x0r View PostI found why this was spamming the log.
EDIT:
Current errors:
Originally posted by l33tlinuxh4x0r View PostShomari I just flashed the stock geekbox kernel (built without any modifications) and I get the same errors about dvfs not being enabled. I get it for core b and core l which is to be expected. Something in their sources (the same source that I'm using) is disabling dvfs. I am looking for new kernel sources now.
Eventually, once you get it right, the fun part begins when you get to play with the hmp tunables. There's probably even more performance to squeeze from the cpu itself if hmp is carefully tuned. I've stopped experimenting with that part until I eliminate the bug that causes the system to be unable to reboot/power down properly
I am wondering... You got the linux source code from kernel.org and you built it? What version of the kernel did you use (4.9-r8)? If so what did you so to do so. Obviously you cross compiled it but other than that what commands did you use?
I have been usingCode:make geekbox_defconfig make geekbox.img -j8 ./upgrade_tool DI kernel kernel.img ./upgrade_tool DI resource resource.img ./upgrade_tool RD
Ok, I got it working! Here is how I did it...
I unpacked the stock update.img and then unpacked the stock resource.img from that. That gave me a dtb file and the logo.bmp for the kernel. I then de-compiled the dtb to a dts file. I made the modifications in the OP and compiled it. I will post my modified files for the geekbox sources in a couple of hours.
Code:make geekbox_defconfig make rk-kernel-oc.img -j8 ./upgrade_tool DI kernel kernel.img ./upgrade_tool DI resource resource.img ./upgrade_tool RD
EDIT: Very unstablehave to iron out the kinks. I'll report back when I get it working stable.
OK how I did it. Stable at 1416Mhz all 8 cores!
First I had to download the source code. It contains all of the source for android 6.0 as well if you are interested.
Code:cd ~/project/ wget https://raw.githubusercontent.com/geekboxzone/mmallow/geekbox/repoinit.sh chmod +x repoinit.sh ./repoinit.sh
Back to the kernel you can either extract your resource.img and your *.dtb to make a *.dts or you can just use mine and edit it as needed for your device. You also need a kernel config. I have included both. Just drop them in ~/project/geekbox/mmallow/kernel/arch/arm64/
Then you can build the kernel with the following commands...
Code:make overclock_defconfig make rk-kernel-oc.img -j8
Code:./upgrade_tool DI kernel kernel.img && ./upgrade_tool DI resource resource.img && ./upgrade_tool RD
Just extract my kernel.zip into your source folder and it should put the files in the correct places.
Here is a dmesg from what I'm currently running.Code:[ 114.734217] [7: sh: 1434] -------------DVFS TREE----------- [ 114.734217] [7: sh: 1434] [ 114.734217] [7: sh: 1434] [ 114.734261] [7: sh: 1434] DVFS TREE: [ 114.734272] [7: sh: 1434] | [ 114.734272] [7: sh: 1434] |- voltage domain:vd_logic [ 114.734290] [7: sh: 1434] |- current voltage:1000000 [ 114.734300] [7: sh: 1434] |- current regu_mode:UNKNOWN [ 114.734312] [7: sh: 1434] | | [ 114.734312] [7: sh: 1434] | |- power domain:pd_gpu, status = OFF, current volt = 950000, current regu_mode = UNKNOWN [ 114.734333] [7: sh: 1434] | | | [ 114.734333] [7: sh: 1434] | | |- clock: clk_gpu current: rate 288000, volt = 950000, enable_dvfs = ENABLE [ 114.734353] [7: sh: 1434] | | |- clk limit(enable):[288000000, 576000000]; last set rate = 288000 [ 114.734365] [7: sh: 1434] | | | |- freq = 288000, volt = 950000 [ 114.734376] [7: sh: 1434] | | | |- freq = 400000, volt = 950000 [ 114.734387] [7: sh: 1434] | | | |- freq = 576000, volt = 975000 [ 114.734398] [7: sh: 1434] | | |- clock: clk_gpu current: rate 288000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 114.734412] [7: sh: 1434] | | [ 114.734412] [7: sh: 1434] | |- power domain:pd_ddr, status = OFF, current volt = 1000000, current regu_mode = UNKNOWN [ 114.734433] [7: sh: 1434] | | | [ 114.734433] [7: sh: 1434] | | |- clock: clk_ddr current: rate 792000, volt = 1000000, enable_dvfs = ENABLE [ 114.734453] [7: sh: 1434] | | |- clk limit(enable):[200000000, 800000000]; last set rate = 792000 [ 114.734465] [7: sh: 1434] | | | |- freq = 200000, volt = 950000 [ 114.734475] [7: sh: 1434] | | | |- freq = 300000, volt = 950000 [ 114.734486] [7: sh: 1434] | | | |- freq = 400000, volt = 950000 [ 114.734497] [7: sh: 1434] | | | |- freq = 600000, volt = 975000 [ 114.734533] [7: sh: 1434] | | | |- freq = 800000, volt = 1000000 [ 114.734546] [7: sh: 1434] | | |- clock: clk_ddr current: rate 792000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 114.734558] [7: sh: 1434] | [ 114.734558] [7: sh: 1434] |- voltage domain:vd_arm [ 114.734577] [7: sh: 1434] |- current voltage:1300000 [ 114.734654] [7: sh: 1434] |- current regu_mode:UNKNOWN [ 114.734707] [7: sh: 1434] | | [ 114.734707] [7: sh: 1434] | |- power domain:pd_core, status = OFF, current volt = 1300000, current regu_mode = UNKNOWN [ 114.734768] [7: sh: 1434] | | | [ 114.734768] [7: sh: 1434] | | |- clock: clk_core_b current: rate 1512000, volt = 1300000, enable_dvfs = ENABLE [ 114.734818] [7: sh: 1434] | | |- clk limit(enable):[216000000, 1512000000]; last set rate = 1512000 [ 114.734881] [7: sh: 1434] | | | |- freq = 216000, volt = 950000 [ 114.734922] [7: sh: 1434] | | | |- freq = 312000, volt = 950000 [ 114.734964] [7: sh: 1434] | | | |- freq = 408000, volt = 950000 [ 114.735015] [7: sh: 1434] | | | |- freq = 600000, volt = 975000 [ 114.735077] [7: sh: 1434] | | | |- freq = 696000, volt = 975000 [ 114.735118] [7: sh: 1434] | | | |- freq = 816000, volt = 1000000 [ 114.735159] [7: sh: 1434] | | | |- freq = 1008000, volt = 1125000 [ 114.735182] [7: sh: 1434] | | | |- freq = 1200000, volt = 1200000 [ 114.735192] [7: sh: 1434] | | | |- freq = 1416000, volt = 1225000 [ 114.735204] [7: sh: 1434] | | | |- freq = 1488000, volt = 1250000 [ 114.735215] [7: sh: 1434] | | | |- freq = 1512000, volt = 1300000 [ 114.735227] [7: sh: 1434] | | |- clock: clk_core_b current: rate 1512000, regu_mode = UNKNOWN, regu_mode_en = 0 [ 114.735238] [7: sh: 1434] -------------DVFS TREE END------------
Still working on increasing the clock speed. So far I have reached 1560Mhz or 1.56GhzAttached FilesLast edited by l33tlinuxh4x0r; 10 December 2016, 16:16.
I am currently trying to disable big LITTLE cpufreq in favor of the stock rockchip cpufreq to see if that helps with scaling.
If I knew how to adjust the dvfs tables to work with the other cpufreq it might help. For now I'm going back to what worksLast edited by l33tlinuxh4x0r; 10 December 2016, 22:13.
I have achieved 43726 in antutu and I have everything else working too! 1.56Ghz with the stock power supply! Big thanks to Shomari for this tutorial and to followmsi1 over at the geekbox forums for TWRP!
EDIT: I'm uploading my current configs if you want to build the kernel too!Attached FilesLast edited by l33tlinuxh4x0r; 12 December 2016, 02:47.
Originally posted by l33tlinuxh4x0r View PostI have achieved 43726 in antutu and I have everything else working too! 1.56Ghz with the stock power supply! Big thanks to Shomari for this tutorial and to followmsi1 over at the geekbox forums for TWRP!
Disable throttling in boot.img, init.rc
set the following parameter to '0' (off) from the default '1' (on):
write /sys/module/rockchip_pm/parameters/policy 0
EDIT: found it in another init file.
Also I am changing cpu mem alignment to 0.Last edited by l33tlinuxh4x0r; 13 December 2016, 19:33.
There are currently 2081 users online. 0 members and 2081 guests.
