T95Z Plus disassembled & Wifi issue. Warning: Wifi chip is not AP6330, but LTM8830
    Guys i have a issue too
    guess what ? Wifi . .
    This number KM63351011 IT-A1 says something to anyone ?
    When i turn on the Sunvell T95Z Plus for the first time, she got like 5 or 6 wifi of my neighbors and nothing from my router . .
    She cant find it and its like 8 meters away . .
      Hi ReisYT ,
      does your Router shows the SSID or is it deactivated , maybe a Reset of the Router will help ???
      good luck
      gefattern
        Hi ReisYT ,
        good luck
        gefattern
        Already reset the router like 3 times and nothing.
        Now i dont know what firmware i have to install at keast to have the wifi back again even just finding 4 neighbors networks
          Hi ReisYT ,
          what kind of Android Version do u use ??? ,
          is it a external Antenna ???
          really strange , ever made a FW Reset , of course
          Backup before your Data , you know how ???
          nice Day
          gefattern
            Hi ReisYT ,
            nice Day
            gefattern
            I dont know the android version, how can i know ?
            I dont have external antenna just the stock chip as i post the link on the first post.
            I tough that if i go on "restaure" the box reset to fabric version but no . .
            Any help ?
              Hi
              I don't know whether I should start a new post being a noob (is that 1 o or 2, probably both) anyway, I have bought the T95Z Plus Amlogic S912 2gb 16gb android box and my
              problem is that I get 35mbps on my laptop and yet in the same room, I can only get 7mbps on the T95Z box. Is the box faulty and do I return it, or is there anything I can do to up the speed?
                Originally posted by Johnf89 View Post
                Hi
                Hello, WIFI on those box is not the best, you pc will always get better speed.
                but, depending of you hardware version upgrade firmware and have better performance look at other post here you will find latest firmware
