NexBox A95x JRF Custom ROMS - Frankenstein and Xanny´s Based
    Hi folks,
    Here i will post 2 roms :
    One followed the Krisshin idea, based in prahjister's frankenstein firmware.
    Link
    https://mega.nz/#!X1xFgZzB!eMLw7SGSP...bcvloDbVelvlow
    Removed Calendar
    Removed Contacts
    Removed Chinese Keyboard
    Removed PPOE
    Remove some background services
    Changed default Launcher do Square2 (Xannys idea)
    Fixed home key button not working (Krisshin)
    Fixed Enter bug in usb keyboard (Xannys)
    Added script to set afterboot to 0 to fix netflix issues (Xannys)
    Added script to copy advancedsettings to kodi
    Added script tp fix right issues in : \system\etc\init.d (Xannys)
    Changed Wallpaper to Xanny´s one
    Added some apps :
    Es File Explorer 3.5
    youtube tv
    adaway
    terminal
    appkiller
    universal init.d
    passthrough fix
    More some small stuff
    Know bugs :
    After first boot you will need to enter ini.t app, enable it and edit the bright fix line and save. (it´s probally cause i did that in windows, i will fix later)
    The second rom is Xanny's Rom only with uboot changed to A95x
    https://mega.nz/#!b4wB3K6C!3Gf2YCqPK...dF77kSFrXbgXJQ
    New Xannys Version
    4.5 Fixed Link
    https://mega.nz/#!20ZhySAD!UGl85KSsk...-U4L57tFECdYeo
    Really Fast, amazing work
    Couldn´t make recovery work
    My children´s favorite game Lego Star Wars Complete Saga Force closes
    if you wanna keeps yours settings do a backup first
    https://play.google.com/store/apps/d...TitaniumBackup
    Originally posted by joao.feijo
    Hi folks,
    Link
    Removed Calendar
    Removed Contacts
    Removed PPOE
    Added some apps :
    youtube tv
    adaway
    terminal
    appkiller
    universal init.d
    passthrough fix
    Know bugs :
    The second rom i will post later, still uploading, but it will be a Xanny only with uboot changed to A95x
    Thanks for this great work , can I upgrade to my existing xanny rom so that I can keep all data and apps already configured ?
      Make a backup first https://play.google.com/store/apps/d...TitaniumBackup
        Making user apps backup now , can I restore on top of your xanny customized rom ?
          Thanks for this rom a lot of us a95x users will be pleased. Cheers.
            Hi how do you edit brightness fix line? Thanks.
              Yes you can
                Look for init.d application in app drawer. Click in the script and choose edit in the top right of the screen.
                the bigger the value after echo tge brighrest the screen becames.increase in steps of 10
                choose run after edit to test
                  We welcome
                    Yes you can
                    Thanks a lot for this rom , fixed my power button problem as well as very fast. Appreciate the effort
                      can i install this rom through USB_Burning_Tool or any other method?
                        I'd assume the sd card toothpick method should work too as long as your recovery is working properly.
                        "HANDS ARE NATURES FORKS" -Rigby
                          my system hangs on startup screen i have nexbox s905x 1g 8g
                            Raja, wich rom are you trying ? Mine box is same as yours, the first boot may take some time.
                              Anyone can confirm is bluetooth is ENABLED and WORKING on any ROM for Nexbox 2G/8G PLEASE.
