NexBox A95x JRF Custom ROMS - Frankenstein and Xanny´s Based
Originally posted by joao.feijoHi folks,
Here i will post 2 roms :
One followed the Krisshin idea, based in prahjister's frankenstein firmware.
Link
https://mega.nz/#!X1xFgZzB!eMLw7SGSP...bcvloDbVelvlow
Removed Calendar
Removed Contacts
Removed Chinese Keyboard
Removed PPOE
Remove some background services
Changed default Launcher do Square2 (Xannys idea)
Fixed home key button not working (Krisshin)
Fixed Enter bug in usb keyboard (Xannys)
Added script to set afterboot to 0 to fix netflix issues (Xannys)
Added script to copy advancedsettings to kodi
Added script tp fix right issues in : \system\etc\init.d (Xannys)
Changed Wallpaper to Xanny´s one
Added some apps :
Es File Explorer 3.5
youtube tv
adaway
terminal
appkiller
universal init.d
passthrough fix
More some small stuff
Know bugs :
After first boot you will need to enter ini.t app, enable it and edit the bright fix line and save. (it´s probally cause i did that in windows, i will fix later)
The second rom is Xanny's Rom only with uboot changed to A95x
https://mega.nz/#!b4wB3K6C!3Gf2YCqPK...dF77kSFrXbgXJQ
New Xannys Version
4.5 Fixed Link
https://mega.nz/#!20ZhySAD!UGl85KSsk...-U4L57tFECdYeo
Really Fast, amazing work
Couldn´t make recovery work
My children´s favorite game Lego Star Wars Complete Saga Force closes
if you wanna keeps yours settings do a backup first
https://play.google.com/store/apps/d...TitaniumBackup
Originally posted by joao.feijo View PostThey are the same. Check the link, same name and place.
at night i will try a diferent method to let recovery working.
As always great effort by you and Xanny, thanks much for this build.
I installed the A95-JRF-Frankstein.img on my NexBox A95X (S905X, 2G, 16G) and it seems to be working fine. Excellent job, joao.feijo! I have two issues / questions...- the setting for "Power key definition" does not seem to have any effect (always "shutdown", never "suspend and resume"). Is that expected? Any workaround?
- I do not understand this from the original post instructions, "After first boot you will need to enter ini.t app, enable it and edit the bright fix line and save."
- "Enter ini.t app, enable it" probably means to run "Universal init.d" and move its switch to "on".
- But, what does "edit the bright fix line and save" mean? I assume it means to edit the "05videobrightness" init.d script, but how it to be corrected?
BTW, it would be nice if custom ROMs replaced Kodi with FTMC ... that is what I do to get PVR support and more.
re: "I´ve noticed that titan is not working with kodi, i will try to figure out how to fix that"- is that a matter of (before the backup), in Backup Settings / Backup settings, select "Backup app cache". It says you often don't need it, but I get nothing from Kodi/FMTC w/o setting that.
There are currently 1996 users online. 0 members and 1996 guests.
