NexBox A95x JRF Custom ROMS - Frankenstein and Xanny´s Based
    [QUOTE=joao.feijo;n625546]
    Raja, wich rom are you trying ? Mine box is same as yours, the first boot may take some time.[/QUOTE
    in installation menu system hangs again reset box through switch of elextricity then system wake up and optimezed 18 apps in boot menu and splash into xannys custom rom piwer on button works...
    but one strange thing in installation menu system hangs
      i m using xanny rom which u modified for nezbox users...all things are working fine without complete installion because box is stuck in ibstalltion menu but i powered off elextricity and switch on box then box power on in normal manner after 2 or 3 reboots system optimization starts and now bix working fine system power on normally as compare to default firmware of nexbox...
        Nice. If you have some time also try rhe other rom. Its lighter for system with only 1gb and i intend to improove her
          in ur opinion;/recommandation which rom is best????i m watching movies just thats why i purchased this box i install also libreelec in sd card run both system succesfully..
            In my opinion just for kodi go with lireelec.
            for netflix and box with 1gb go with the frank rom.
              first of all thanks for ur efforts...
              i m using both system (andriod rom and librerlec through sd class 10) successfully...i will install also other rom afternoon and report back to u...
              thanks once again...
                I tested both NexBox A95x JRF Custom ROMS - Frankenstein and Xanny´s Based and Bluetooth did not work in any. Now I can flash a ROM from USB Tools direct from Xanny Mod ROM, situation in Original Xanny ROM I can't.
                  I m testing rom it is working amazing fast and smooth i will check x265 10 bit format in evening bexause i dnt have any movie or test file in this time....only one minor issue is tick sound or noise in backgroud when playing videos youtube and kodi(in every 2 and 3 minute there is tick sound)
                    How do you update Google play store?
                      Sadly there is no support to play x265 10 bit in Frankenstein Rom when I play the x265 10 bit file in this Rom screen becomes green...kindly customized the latest Rom based nexbox/any other Rom because 806 based Rom have many errors like tick sound noise not supports x265 10bit formats etc
                        1st fw is Super fast but BIG BUG; you can't boot out of recovery back into system.
                        I have the 2g/16gb A95x just to warn others.
                          Open terminal emulator type reboot update....
                            Joao can you please give step by step on how to make only uboot change to make our remote work in other fw. i.e customize tool etc.
                              Just copy remote file in ect
                                How do you do that in Recovery or Twrp?
