kodi 17
Originally posted by Ichijoe View Post
Originally posted by feelulive View Post
i updated from play store, still no dts no subs settings plus darker video
so back to 16.1 again its already ok for me
That is a Krypton build that has the old PCM hack that allows DTS to work in 16.1. I have this loaded on my X-Player and I have flawless DTS playback.
HD digital audio isn't in Marshmellow (its only in Nougat) so unless you get a custom Marshmellow firmware with backported Nougat audio API you won't get it.
Originally posted by vanginger View PostHi
I know this is an old thread but I have installed shitty and it works great for DTS but Dolby Digital has the problem that DTS had. I can't find anything but DTs mentioned online.tho. any ideas?
Sent from my LG-H850 using Tapatalk
https://www.dropbox.com/s/efgeiiv6jiw3x9j/kdmc-armeabi-v174-debug.apk?dl=0
I have DTS and Dolby Digital running fine on my S912 with this but firmware can play a big part in the success or failure too.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk
See how this does
Do other people have Dolby digital working on shitty Kodi 17 ?
You may have to uninstall a previous version in order for it to install.
May also be worth posting the question on the Kodi forums, where the devs that create these shitty builds are made.
https://forum.kodi.tv/forumdisplay.php?fid=164R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thanks a lot. Yep an uninstall worked. Although DD still didn't work!
Ended up trying spmc and it's worked brilliantly (touch wood). Tried v16 first and that was great but obviously based on Jarvis. Then tried a 17.4 build with iec passthru and again working great.
There are currently 1792 users online. 1 members and 1791 guests.
