Does anyone has the latest marshmallow rom in zip format so i can try flash it using the same procedure?
Tanix TX2 firmware needed
Originally posted by Dami View Postdescription here how something will be known to write it.
https://www.facebook.com/tanix.box/
I managed to create my own usb cable from two old (usb to mini usb cables), and flashed latest marshmallow, i will stick with that.
I was planning to by the newer tanix tx3 mini, but now I will not.
Originally posted by mariosm1cy View PostIndeed waste of time, I do not have usb cable either and no updater app,I thought of going from recovery and flashing rom. It fails and aborts and now box stuck at android logo.
this is the response i got form tanix via skype regarding failed nougat rom flash:
[01:14:02 PM] Tanix Box: Some TX2 are OEM
[01:14:15 PM] Tanix Box: traders can change components if they buy certain quantity
I replied the following, they did not reply after that
[02:07:47 PM] : well the marshmallow firmware was flashed successfully right after the failed nougat rom
Originally posted by mariosm1cy View Postthis is the response i got form tanix via skype regarding failed nougat rom flash:
I successfully flashed the firmware
1. flash the image using erase flash first in the burning tool
2. create the SD card with usb creator and boot from the SD to flash a second time.
Almost all benchmarks are the same as with stock 6.0. the only issue is that kodi is slower than on 6.0 and I dont know why.
can someone post here the latest android 6.0 for this box? I want to downlgrade to do more testing.
never mind its here:
thanks.
regards.
Originally posted by arioch View PostThank you. how do i boot from sd card? does it has widevine l3 or there is a way to enable it as for 6.0?
remember you first have to flash it using the Tanix burning tool. then flash from the SD card.
I dont know anything about the widevine. sorry.
if you succeed can you please report back if FTMC or RKMC interface navigation is slower than on 6.0, I have the same issue in 3 units. regards
I need your help , i have the Tanix TX2 and last week it decided to crash , since then i have been trying to get it working again obviously with no luck . The TX2 is not picked up by the PC when connecting via USB to USB . It will boot to recovery but attempting to install Firmware 7.1 ends in a Error status 7 ( or something similar ) i have tried the "fix" but the update does not have any "assert" commands to change. I cannot find anywhere a previous firmware version in a .zip format so that recovery can be used and any attempts to create my own have thus far ended with efooter errors or signature errors ( of course )
Attempting to make a bootable SDCard just ends with a BEX error no matter what software i use.
Unless i can find a previous version of the firmware in .ZIP format to be able to boot from within recovery i think the only other option is via UART ? i have a UART cable but my experience is with flight controllers not TV Boxes so if any body could point me in the right direction of flashing firmware via Uart or by providing me with a flashable vers 6 firmware.ZIP i would be grateful.
Thanks for any help you can provide
scouse
There are currently 4301 users online. 1 members and 4300 guests.
