i have to say that this box in my opinion is best choice of tv boxes and sticks for now.
Its have analog tv out, hdmi, 2Xfull size usb, 1xmicro usb otg, spdif, audio jack, rj45 and micro sd slot.
You can buy it here:
GeekBuying.com
My website:
http://www.apkfreak.com
Changelog:
Beta
(some bugs may be present)
v3.2
-fix black screen on some devices
-fixed remote mapping
-fixed nfs
-fixed some stability bugs
-flash custom kernel under setting-miscllaneous
(place your kernel into /sdcard/HFW/ and rename it to kernel.img)
!(make sure you flashing 1080p kernel in 1080p mode and 720p kernel in 720p mode)!
-melef10 keymap
-better xbox wirless gamepad keymap
-rooted
-init.d support
-debloated
-cwm recovery (backup-restore your firmware)
-swich between 1080p kernel and 720p kernel with simple press of a button from your tv
(Settings-Advanced-Switch Resolution)
-new CM like menu under Settings
-pached libmedia for xbmc passtrougt
-new folders in /mnt/ out of the box fro mounting nfs or smb shares
NFS_1 ; Samba_1
NFS_2 ; Samba_2
-mount smb, nfs scripts in /etc/init.d/ for mounting shares (edit to mach your shares and
change permisions to "755" "rwx r-x r-x")
-new shutdown menu
-fixed setting/firmwork-res strings
-new modules
*md4.ko
*Virtual Touch
*Tun
-gamepad button on systembar
-removed volume buttons from systembar
-youtube for gtv 1.7.3
-better webcam support
-wirless tweeks in build.prop
-spoofed as Galaxy S3
-new mouse pointer (LG Google TV)
-new bootanimation
And probably other things i forgot to mention;p
Stable
(last ver based on stock k-r42 rom)
v1.2.0 Final
-K-R42 720p/1080p
-root
-spoofed as Galaxy SIII
-gamepad button on statusbar opens "Tincore Key Mapper" (you can play games like bad pieggies with mouse)
-build.prop tweaks
-gameloft fix
-2gb app space
-changed bootanimation
-deleted usles apps
-better webcam support (logitech webcams like c525 wasnt working before, now it works like a charm
-bootsound suport (put any .mp3 into system/media and rename it to android_audio.mp3 it will be played at bootanimation screen.)
-auto install advancedsettings.xml for smooth 1080p videa playback in XBMC
-Default launcher option under HFW settings>Special (Chouse which launcher you want to use as default)
-nfs support
-init.d support
-added HFW version under settings>about device
-added some nice apps:
*ES Explorer (ver. before layaut change)
*Wallbase
*Youtube for GTV 1.6 (due to login problems on 1.7.1)
-new settings (HFW Settings)
*Special
*Performance (you can change CPU clocks)
*Equalizer (need some testing)
*SuperSU (now it wil show here insted of app drawer)
*Terminal (//-//-//-)
*Xbmc Installer (//-//-//-)
-unlocked hiden options:
*Bluetooth
*Accessibility
-new modules:
*ntfs.ko added
*md4.ko
*pl2303.ko
*crc-itu-t.ko
*isofs.ko
*cdrom.ko
*udf.ko
*isofs.ko
*btusb.ko
*tun.ko
*virtual touchscreen.ko (720p)
-some visual changes
-modules package [provided with the rom package]
-disabled hdmi check for apps like "Xfinity, HBO GO"
-new visual (system bar etc.)
-power button on system bar
-clean home screen from usles shourtcats and widgets
-new wallpaper
-ic_sysbar_highlight changed to cyan
-ic_sysbar_lights_out_dot changed to transparent (no dots on status bar when waching movie on mx player etc.)
-deleted search bar from home
Beta:
V3.2
Download 720p/1080
V2.0.4
Download 720p/1080
Stable:
v1.2.0 Final
Devhost 720p
Devhost 1080p
Regards
Lewy20041
Thanks go to:
leolas (for his help whenever i need)
phjanderson (kernels for t428)
hoabycsr (kernels for mk908)
FinlessBob (kernel pach for K-R42)
Wasser (kernels for K-R42)
