K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
wow. thats nice packageEverything is possible if we work together!
Originally posted by lewy20041 View Postwow. thats nice package
jeje any brabe that test my kernel?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by tico View PostWell. the specs are the same except for Bluetooth v4.0.Thanks
If you install this ROM on a T-R42, the wifi/bt will not work without some file modification.
But im sure the ROM developers will turn this ROM into T-R42 compatible in no time.Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
Originally posted by leolas View PostI give you my first try with kernel for this device. Remember is a test kernel, so be sure that you have a custom rom with boot.im without kernel, be sure that you know how flash it.
If yoou flash it I suppose you know whay are you doing,I have not this device so I cant test it, flash it under your own responsibility.
Also, is flashing the kernel a wipe or non wipe procedure?
Last question, does anyone know if the stock kernel is available as an img file so I can flash it back if there are problems?
thanks
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
do not flash it (you need to use finnles tool to flash just the kernel). i checked and device wont power up.
even if it work there is a drm like thing in firmware so it will reboot constantly.
i fixed reboot thing and flashed leolas qx1 oc 1080p kernel.
on 1080p it gets 17000 in antutu, its more then stock 720p wich gets only 15000.
but ui isnt as fluid as in 720p.
leo i dont think you need to compile the new kernels i can use your qx1 one but it will be great if you compile modules for the ethernet and other chips to get them working as of now only wifi work.Everything is possible if we work together!
Originally posted by lewy20041 View Postdo not flash it (you need to use finnles tool to flash just the kernel). i checked and device wont power up.
thanks, and keep it up!_________________________________________
Re: K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Lewy, I dont suggest you use qx1 kernel, the pmu is configured to give 3.3 V instead 1.8V of stock kernel. After some time it will damage your wifi chip, and Ethernet is inserted in stock kernel not like a module. So please don't use qx1 kernel. I am from my mobile so I can't use moderation.
IS NOT A GOOD IDEA USE QX1 IN KR42.
The fail in my kernel before is in video subsystem, this afternoon when I arrive home I will make a new kernel for you test.
Lewy, if you have some time this afternoon about 15:00 gtm can be good idea if we meet at same time.
i wont make it im afraid.
family reunion:"
my wife would have kill me;p
thx for info i didnt know about pmu.
i maby will have some time today but it will be about 10pmEverything is possible if we work together!
Originally posted by lewy20041 View Posti wont make it im afraid.
family reunion:"
ethernet kernel module should work to if insmoded at boot.Everything is possible if we work together!
Originally posted by lewy20041 View Postethernet kernel module should work to if insmoded at boot.
Fonts and internet browser are a way better in 1080p kernels than 720p and I didn't notice skipping frame problem in video.
Testing kernels, those kernels are in development state, I HAVE NOT THE DEVICE AND I CANT TEST THEM, THEY ARE ONLY FOR TESTING PURPOSE.
In this zip there are 3 kernels, if someone want to test them. ONLY FOR ADVANCES USERS WHO KNOW HOW SOFT UNBRICK THE DEVICE. THE KERNELS CAN NO BOOT.
Thanks.
In kernel3 is the same config that my qx1 but with the voltages corrected and safe for use in this device. But only ethernet will work, not spdif, not av out.
Waiting your feedbackREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by fredphoesh View PostLeolas, brave or stupid, I don't know... but I can give it a try... though I am GUESSING I need to flash this using the same RKBatchTool I used to flash v1.1 of lewy20041's rom?
thanks
Mark.
Originally posted by leolas View PostTesting kernels, those kernels are in development state, I HAVE NOT THE DEVICE AND I CANT TEST THEM, THEY ARE ONLY FOR TESTING PURPOSE.
Thanks.
the other two just show penguins and restart to penguins again dont boot even to boot animation.
cant you test the kernels on qx1 they shoud work if qx1 kernels are working in k-r42.
its nice that you helping me with this so muchEverything is possible if we work together!
Originally posted by lewy20041 View Posti tested the kernels and only the first boots but there was artefacts like things on screen and it was not scaled properly.
There are currently 2077 users online. 1 members and 2076 guests.
