A95X R1 TV Box 1/8gb RK3229 :-)
    Armcortex A7 Quad Core 32-bit CPU Android 6.0 OS Media Player Click image for larger version  Name:	20170309174336_21863.jpg Views:	1 Size:	310.3 KB ID:	635027
    Model: A95X R1
    Type: TV Box
    System: Android 6.0
    CPU: Armcortex A7
    Core: 1.5GHz,Quad Core
    GPU: Mali-400 MP
    RAM: 1G
    RAM Type: DDR2
    ROM: 8G
    Max. Extended Capacity: 32G
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: ASF,AVI,ISO,MKV,MPEG,RM,RMVB,VOB,WMV
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    Bluetooth: Unsupport
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI,LAN,SPDIF,TF card,USB2.0
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: Yes
    HDMI Function: CEC
    System Bit: 32Bit
    WiFi Chip: RTL8189
    KODI Version: 16.1
    Power Type: External Power Adapter Mode
    Power Input Vol: 12V,5V
    Product weight: 0.1200 kg
    Package weight: 0.3700 kg
    Product size (L x W x H): 9.30 x 9.30 x 1.50 cm / 3.66 x 3.66 x 0.59 inches
    Package size (L x W x H): 18.50 x 12.50 x 4.80 cm / 7.28 x 4.92 x 1.89 inches
    Package Contents: 1 x A95X R1 TV Box, 1 x Power Adapter, 1 x User Manual
    Click image for larger version  Name:	20170309174336_25804.jpg Views:	1 Size:	292.2 KB ID:	635028
    Gearbest
    This is one Tiny little Unit....
    More to Come
    A mouse to scale (runout of bananas)
    Gearbest
      Well lets see what this Little bundle of joy may offer.
      The Box plain and Simple.
      What's in the Box
      Lots of Ports
      More Ports
      Top View Heatsink stuck good
      Not much under here
      Ports again
      and again
      WiFi Chip
      Ram
      eMMC
        Now that we have it sorted in the right area
        Lets have a look at the UI some Information, Bench Test.
        A95X R1, Android 6.0, Armcortex A7, 1.5GHz,Quad Core, Mali-400 MP
        1/8GB, 2.4GHZ WiFi and Fast Lan
        Unit working well, Upper and Lower taskbar, has root, and working as expected.
        Netflix looks OK, as with Plex, so could be a nice little Budget unit to tinker with.
        Look around the Coulourful UI
        DRM info
        More Settings
        CPU-Z information
        Ram Test little sluggish
        Geekbench CPU
        Geekbench Compute
        Vellamo
        Ram & Stroage Truth
        Few bucks off with Coupon GB9%
        http://www.gearbest.com/tv-box-mini-pc/pp_616703.html
          Cant upgrade at all... I had an MQX box before was easier and better. It has that TVMC (Kodi) on it. It dont let me use any PVR service. I try to upgrade it a day ago whitout luck...
            Uninstall TVMC and it install another Kodi/FTMC may help ?
              Hi Trebor,
              I 'm waiting for my box from Gearbest.
              I downloaded the original firmware, remove and add APKs and transformt it to Android TV rom.
              I will test and upload when box will arrive.
                Originally posted by manu_manu4 View Post
                Hi Trebor,
                Hi. Can you upload rom?? So i can test it?
                And after open the box, the wifi chip inside is 6051p not like the review above rtl8189...
                  V88 have same Wifi chip
                    Ok. The A95X R1 is fully compatibile with V88 rom, witch has wifi chip 6051p.
                    So we have working Android 4.4 rom - rk3229_4.4.4_G5_SSV6051p_landi_LDG5_20161219_v005
                    Mini MX9 fully working Android 5.1 rom - update_rk3229_ssv6051_minimx9_20170405
                    And V88 Android 6.0.1 rom - rk3229_6.0_MX4N_SSV6051p_zhongx_20170405_v009_Spec tek
                    Also Ugoos UT6 is working, and V88_Android_6.0.1___DRM rom. with patch patchssv6051p.zip
                    and many more with Boot 2.31/2.32 working ok...
                    Official 5.1 A95X_R1 SSV6051p rom - A95X_R1_SSV6051P_complex_tvmc_change_100_RK3229_5. 0.1_20170502
                      I'm waiting for few of this A95X R1 devices. Can you tell me have you managed to install one of the ROMs you named in your post? Is everything working? USB, WIFI, Remote...?
                        yeah... i confirm that everything working, like USB, TF Card, WiFi, Lan, Remote (Ugoos UT6 and V88 DRM rom not test with remote). But only if you have 6051p wifi chip inside, not like in the review above (RTL Chip)
                          Same problems after flashing V88 6.01 ROM...
                          Youtube is disaster... Google play pain in ass... Ultra slow KODI...
                          Some function on remote is not working...mouse key, home key...
                            Update from Banggood - New FW for NexBox A95X R1 with 6051p wifi chip - A95X_R1_SSV6051P_complex_tvmc_change_100_RK3229_5. 0.1_20170502 - Android 5.0.1 but I do not se the visual difference compared to original one came with the Box... - but performance is a little bit better... -
                            - download: https://mega.nz/#!pCoX3BAA!XF6f6mMlU...hbr1qu-VclKcOY
                            Do not install Youtube from GPlay, and do not update Google services and do not put your google account..(do not use Google play store). - install version from TV store aplication...
                            Remove TVMC and install ZDMC (so much better than TVMC)
                            Source Zidoo (http://forum.zidoo.tv/index.php?threads/zdmc-release-base-on-kodi16-1.1744/) http://apidl.zidoo.tv/zidoo_x6%2Fzdmc.apk Hi all: now, we release
                              The question is, this one or the v88? What is the best?
