But in whole this story I think V88 is better...
A95X R1 TV Box 1/8gb RK3229 :-)
I tried many.., many..., many FW from comatible TV Boxes (a lot of sleepless nights)..., and none is working well - same problems in different package, so I have to use some other approach to solve the problem...
Anyway - anyone have problems with this A95X R1... solution is this:
If you already put some or lots of stuff on this Box - just do the factory reset...., and after that on fresh condition... - do not put google account on this Box - and for God's sake do not update Google services...because it will turn this TV Box to a lagging monster...
Download Youtube application from the link from the TV store application it is working just fine on 720p...
Uninstall TVMC and K-addons application.
Often use a memory cleaner...
As you will no longer use the Google Play Store, through the Box Browser download the Aptoide TV application or just Aptoide for any aplication you want (except Google aplications which will need update of Google services)....
And at the end install ZDMC of fresh Kodi Jarvis or Krypton from some Store or download through Web Browser...and adjust it according to your needs...
This is it.., - NOW YOU HAVE A FULLY (far from great) WORKING A95X R1..., and it is enough fast, and tolerable "good" - but only for Kodi, Youtube, - and Media player...
...cheersLast edited by sappy; 22 May 2017, 12:32.
sappy
Recent RK3229 boxes have come down in quality to say the least,
Got a lot of RK3229 boxes, after many days and nights trying to fix things had to send them back.
They were so slow, it was ridiculous.
Not sure but think it has to be the eMMC chips, previous boxes used much better memory.
Only thing that seemed help things a bit was this app.
https://play.google.com/store/apps/d...dr.boost&hl=en
Every install and uninstall, is painfully slow...
After uninstall large applications (with addons like the Kodi) Tv box freeze for the next 2-3 minutes ...
This is the same Youtube experience like on NexBox A95X R1 - (with fresh installed from Play Store and updated Google services) but if you install "default" Youtube apk from "The Box TV Store" it will work actually decent...
Do not update Google services and do not put Google account so apks will not update..., use only what was installed with the Box FW...
I did so.., and use ZDMC as I described with only a few addons or some very light build... and performace will be tolerable, but not for those with thiny nerves or patience...
I do not have patience..., I did make a complaint to Banggood and they refund me 100% without need to send Boxes back..., so a big plus for refund and big minus for selling this shit NexBox A95X R1 TV Boxes...., and I'm totally surprised by the comments of the buyers, as if they bought some other Tv Box from some other planet...weird...Last edited by sappy; 22 May 2017, 10:13.
This NexBox A95X R1 has 4 types of internal flash memory: (as I know till now)- SanDisk (good one)
- Baron - good...
- Toshiba (tolerable)
- Micron technology - (worst)
Last edited by sappy; 06 July 2017, 21:15. Reason: Heard about Baron a few day ago..., and friend said me that A95X R1 works good with this memory...
Originally posted by Daromik View PostI think Android 4 firmware works faster. Please share your Android 4 firmware
Only solution can be, but for now it is imposible, to use some kind of LibreElec or OpenElec on external sd card to override the usage of internal flash memory...
mo123 thanks for the heads up, did not know you could check that way.
sappy tried 4.4 had the same issues. Shit Chip shit performance.
They run a stress test before shipping, with this last lot , no one, not even the supplier sat down and run a F^&%^^$ video or used playstore to see if it works.
There are currently 3167 users online. 0 members and 3167 guests.
