A95X R1 TV Box 1/8gb RK3229 :-)
Hello, I have this Android Box, I´m using Kodi 17.4, on Kodi is not working auto change refresh rate (I have settings to always) so I choose manual 24Hz on android box. But problem is on 23.976 fps, on 24hz is sometines (5 minutes, 3 minutes 3) starting stuffering, I know is a problem with Hz, I need 23.976hz but I cant setup theese, what can I do? Thank you.
Originally posted by martin5504 View PostHello, I have this Android Box, I´m using Kodi 17.4, on Kodi is not working auto change refresh rate (I have settings to always) so I choose manual 24Hz on android box. But problem is on 23.976 fps, on 24hz is sometines (5 minutes, 3 minutes 3) starting stuffering, I know is a problem with Hz, I need 23.976hz but I cant setup theese, what can I do? Thank you.
Or if your firmware is not extremely buggy(which might be the case) then you can try RKMC or FTMC 16.1 with working auto frame-rate switching.
I tried on original TVMC but not working, okey I try FTMC 16.1, thank you.
EDIT: FTMC working perfectly, thank you so much.Last edited by martin5504; 22 September 2017, 18:55.
Originally posted by DrDroid View PostAnyone know where I can get the A95X_R1 RK3229 SVS6051p Firmware from please?
please look here too :
http://freaktab.com/forum/tv-player-...x-1-8gb-rk3229
good luck / gefattern
Hi ,
Thanks for the response unfortunately there are no link on page 1 and couldn’t find it anywhere I looked for the Firmware I need which is Android 6.0.1 for (Alfawise or A95X R1 - Processor : RK3229 - Wifi Chip: SVS6051p) most of the link on that page has no file download as they have been deleted it seems. I have a V88 Firmware which always crashes if the mains is switched off so would like to try the A95X R1 ROM as the hardware is exactly the same.
i tested and you are right User "kolankobulka" his Links are dead , but you of i can ask for new upload , okay .
nice Day / greetings / gefattern
Originally posted by kolankobulka View Post
Ok. The A95X R1 is fully compatibile with V88 rom, witch has wifi chip 6051p.
So we have working Android 4.4 rom - rk3229_4.4.4_G5_SSV6051p_landi_LDG5_20161219_v005
Mini MX9 fully working Android 5.1 rom - update_rk3229_ssv6051_minimx9_20170405
And V88 Android 6.0.1 rom - rk3229_6.0_MX4N_SSV6051p_zhongx_20170405_v009_Spec tek
Also Ugoos UT6 is working, and V88_Android_6.0.1___DRM rom. with patch patchssv6051p.zip
and many more with Boot 2.31/2.32 working ok...
Official 5.1 A95X_R1 SSV6051p rom - A95X_R1_SSV6051P_complex_tvmc_change_100_RK3229_5. 0.1_20170502
can you please upload your Roms from Page1 once more , another User "DrDroid" wants to test them , thanks ,
Guest
does anyone have a working custom recovery for this box? I would like to flash magisk on the box, thank you
Guest
Originally posted by martin5504 View PostHi guys, please I need a help, the ac adapter stop working, I want to buy a new one but I dont know which one I must to choose? Can you help me with that? Thank you.
There are currently 3015 users online. 0 members and 3015 guests.
