Z28 Android 7.1 RK3328 4K HDR TV BOX 1/8 or 2/16GB ROM WIFI LAN USB3.0 KODI H.265 DLNA Miracast"
    Android 7.1 + 4 Core RK3328
    Click image for larger version  Name:	20170314172604_11657.jpg Views:	1 Size:	104.6 KB ID:	636289
    Model: Z28
    Type: TV Box
    System: Android
    Processor: RK3328
    CPU: Cortex A53
    Core: Quad Core
    GPU: Mali450MP2
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: 64G
    Color: Black
    Decoder Format: H.264,H.265
    Video format: ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,RM,RMVB,TS,WMV
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    Bluetooth: Unsupport
    Power Supply: Charge Adapter
    Antenna: No
    Camera: Without
    Language: English,Multi-language
    DVD Support: No
    HDMI Version: 2.0
    External Subtitle Supported: No
    Power Comsumption: 3 - 7W
    RJ45 Port Speed: 10 / 100M
    System Bit: 64Bit
    WiFi Chip: 8188etv
    KODI Pre-installed: Yes
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.2500 kg
    Package weight: 0.4300 kg
    Product size (L x W x H): 11.00 x 11.00 x 2.50 cm / 4.33 x 4.33 x 0.98 inches
    Package size (L x W x H): 14.00 x 12.00 x 7.00 cm / 5.51 x 4.72 x 2.76 inches
    Package Contents: 1 x TV Box, 1 x Power Charger, 1 x Remote Control, 1 x English User Manual, 1 x HDMI Cable
    Click image for larger version  Name:	20170314172604_86861.jpg Views:	1 Size:	126.3 KB ID:	636290
    Click image for larger version  Name:	20170314172604_70962.jpg Views:	1 Size:	95.9 KB ID:	636291
    Gearbest
    Gearbest
    Code GBZ28 will save you about 8 bucks and a few cents
    Enjoy
      Lets have a look this day at the Z28 Android 7.1 RK3328 4K HDR TV BOX 1/8 or 2/16GB ROM WIFI LAN USB3.0 KODI H.265 DLNA Miracast
      Thanks Gearbest and DHL.
      First the usual tour of Box and bits, very simple and basic design/shape
      Box and what's in the box
      Ports
      Ports
      Underside
      Underside Inside
      Inside Topside
      Bits that make it happen
      Samsung eMMC
      WiFi
      CPU Rockchip 3328
      Gearbest
      Enjoy
        Here we have the Z28 Android 7.1 RK3328 4K HDR TV BOX 1/8 or 2/16GB ROM WIFI LAN USB3.0 KODI H.265 DLNA Miracast
        Running Android 7.1.1....
        A few issues with Google Playstore and a few Apps not Compatible this will get sorted in due time.
        Launcher installed cannot add Apps to Favorites Home screen, only those that were preinstalled so nothing major.
        Apps that I could not install Via Google Play Installed OK thru Aptoide.
        3Dmark not happy would often crash
        But as always early days for this unit and a bit of updating etc should bring it in to line.
        UI, cant add apps to the + at present.
        Android 7 Settings
        Memory
        Top left of Home Screen Person reading the Product Manual
        CPU-Z
        Ram and Storage Truth
        DRM Info
        A1 SDBench
        Click image for larger version  Name:	2gtclrr.jpg Views:	1 Size:	19.2 KB ID:	640897
        Geekbench CPU
        Full Detail > http://browser.geekbench.com/v4/cpu/2511578
        GeekBench Compute
        Full Details > http://browser.geekbench.com/v4/compute/647411
        Antutu Could Not get a Screen Capture for what ever reason
        Gearbest
          Hi ,
          Specs say Mali400MP2 , but Screenshots Mali450MP2 ,
          why not using a better GPU , Gaming not really possible
          with this Device !!!
          I never shall buy something like that , but let others choose
          self .
          nice Day to all
          gefattern
            Thanks for pointing that out in Specs, fixed and advised.
            Looks like a general Typo on a few of these 3328 models
            Will say it does Play Videos very well as I found late last night most I threw at worked well using RKMC that was installed
            So more for media than games I feel
            Cheers
              hi trebor, issues with rikomagic and kodi still not resolved ? as RKMC is installed and not normal kodi
                New firmware today
                Z28 1+8 model
                Z28 2+16 model
                Use Batch Tool to install
                Has fixed the Google Playstore problem, still cannot add newly installed apps to Home Screen Favorites
                Installed with RKMC.
                  Yes missed that device hope its in soon.... Doh. Thought 3288... ,
                    Released 21st
                    http://pan.baidu.com/s/1eSKeZ3k Z28 1+8
                    http://pan.baidu.com/s/1cH5tb4 Z28 2+16
                    Newly installed apps to Home Screen Favorites has been fixed
                      Looks interesting and also firmwares available.
                      Anyone know how Android 7 on RK3328 compares to Android 7 on Amlogic S905X devices/firmwares I saw on freaktab?
                      Probably better.
                      I saw it still uses a 3.10 kernel, maybe only RK3399 uses a 4.4 kernel(even Marshmallow) or all Nougat firmware will in future, don't know?
                      But in Rockchip's Github, the 4.4 kernel code also has support for RK3328 so it might be possible to upgrade it in the future.
                        It's a pitty that device able to play 4k video but has hd (1280x720) internal resolution
                          Are there any links to the OEM firmware that don't involve installing BaiduNetdisk? That app is riddled with malware, and it takes forever for me to set up a sacrificial VM just to download one file.
                          Also, has anyone tried to root this box? And is there a TWRP build available for it?
                            Normally starts there..and moves around.
                            Should make yo feel safer I hope
                            Z28 2+16 model
                            http://freaktab.org/51cf3c16f1b8b1d7
                              Thanks, Rob!
                              BTW, have you noticed that the stock recovery on this can't read from the SD card slot? If you attempt to apply an update from the SD card, it reports "-- Couldn't mount /sdcard . Installation aborted."
