Z28 Android 7.1 RK3328 4K HDR TV BOX 1/8 or 2/16GB ROM WIFI LAN USB3.0 KODI H.265 DLNA Miracast"
Originally posted by DaMeZ View Posthttp://www.geekbuying.com/item/R-TV-...ox-377453.html hope this helps
https://forum.armbian.com/index.php?...z28-rk3328-18/ - working solution to install UBUNTU LINUX on Z28
Originally posted by trebor View PostNot tested or downloaded as yet
Thanks Gearbest
Firmware for 1/8, 2/8 and 2/16Gb units...
Check link before you download or you will/may get all three at once:
https://mega.nz/#F!PB9UnCgL!Cf9ayThAtVu8hgp-7XrL0g
Originally posted by r1kaomsk View Post
it is for z28 pro not for original topic one
Yes I should have looked harded at folder name
No, i saw this. can you dissaseble your tv box and make a high resolution photo of both PCB sides?
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Sorry this is the best i could take.. The chip that cant be read in the pic is RK805-1 CAADP7735 if you need anything else please let me know
Guest
BTW, that latest Z28 firmware is still far inferior to the latest for the MX9 Pro Mini, which is pre-rooted and 1080p native. Note that the recovery .zip for SuperSU v2.82 still won't root this z28 OEM ROM, because of the unconventional way they've packaged the kernel in its own partition. I built a custom firmware with the new TWRP recovery just to test this, and it couldn't perform the systemless root during install. I haven't yet tried Magisk, though.
UPDATE: Magisk also was unsuccessful at rooting this new z28 ROM. Best to stick with the Mini MX9 ProLast edited by Guest; 21 July 2017, 21:07.
hi Magendanz, can i ask you if the mini MX9 Pro supports Amazon Prime video ? (www.primevideo.com) ? Can you test it please ?
In the meanwhile, i was asking for support to gearbest and they answered me with a new firmware . Here's the link (didn't install it though) :
http://download.appinthestore.com.s3...ool%205.27.rar <--- real link
Guest
That's actually the same Z28 ROM that was just posted. As for Amazon Prime, that seems like something anyone can test. I really should be coding. :-)
Originally posted by Magendanz View Post... far inferior to the latest for the Mini MX9 Pro, which is pre-rooted and 1080p native...
Guest
Both the MX9 Pro Mini and MX9 Pro seem to use the same Rockchip RK3328 chipset, so it's likely they use the same reference board and have compatible firmware. You'd really have to try it to be sure.
Originally posted by Magendanz View PostBoth the MX9 Pro Mini and MX9 Pro seem to use the same Rockchip RK3328 chipset, so it's likely they use the same reference board and have compatible firmware. You'd really have to try it to be sure.
#75.1Guest commented03 August 2017, 00:26Editing a commentYes, but I ran into some incompatibilities with OpenGApps. I wasted the Sunday before last trying to track down the cause, then decided to set it aside to focus on Android TV releases for the Amlogic boxes (which weren't affected by the issue).
There are currently 1934 users online. 0 members and 1934 guests.
