Z28 Android 7.1 RK3328 4K HDR TV BOX 1/8 or 2/16GB ROM WIFI LAN USB3.0 KODI H.265 DLNA Miracast"
Originally posted by r1kaomsk View PostCheck this - https://www.dropbox.com/s/g60z8ht583...28_1a.rar?dl=0 this is my port of http://freaktab.com/forum/tv-player-...1-beta-version (A95X-R2 ROM by SuperCeleron) for Z28
New person here.
New to Android and new to TV Boxes !!!!!!
Just got a Z28 ..... Have installed your Beta FW and must say it is a nice improvement - Thanks to all involved.
Big Thanks
Only issue so far is that the LED on the box is now reversed - Bright Blue when in Standby !
Might have to do a HW hack .....
Cut the blue leg on the LED but the red also stops so no Power-LED at all now - Strange ??
Ah well
Loving this Beta - Thanks for porting.
Any update to fix the USB KB dongle having to be pulled and re-inserted after power down and can you switch the LEDs back so it is back to dim purple when in Standby.
Thanks again,
Pete
Newer firmware k3328_box-userdebug 7.1.2 NHG47K eng.qinzhendong.20170712.200152 test-reys , dowload link https://drive.google.com/file/d/0B0v...VuYnNJdVU/view
New person here.
Big Thanks
Ah well
Re-attached the Blue leg on LED
- Stuck a piece of black vinyl tape over status LED and now just have a dim blue glow in standby
- Nothing shows from the front when ON (purple too dim) but I am using the box on TV then so I know it is on.
Noticed the IR receiver was folded down and pointing at the ground - No wonder the IR Remote was very directional !
Bent it back up (carefully) and now the remote works much, much better.
Any news on ETA of the superceleron Rom ? or the ATV and Nano Nexus versions from Magendanz ?
Thanks,
Pete
Thanks trebor - the r1kaomsk-SC port is great anyway, just wanted to try the ATV and Nano really.
I got the M8SPro+ to try them out on but my ADSL hates this box : (
I take it there is no way to get "screen" resolution to be 1920x1080 ?
My r1kaomsk Beta install is set to 1280x672 (I think the original was too?) so everything is a little fuzzy ! My display is set to 1080p
EDIT:
Thanks Megendanz - Super news
As you can no doubt tell I am a novice,
Pete
The SC port is the only firmware I have found that provides what I consider a usable Android User Interface. Thank you for the port r1kaomsk.
Unfortunately Netflix seems to have an issue. Choppy video and poorly sync'ed audio (both the same problem, I think). Are others finding this as well? Anyone have a fix?
I'm thinking this is not a serious problem, since other ports run Netflix just fine. But I have run out of ideas on how to fix it.
First good night everyone!
Staff, have a box android, very similar to what my colleague has posted a little, The Pendoo Mini. She carries a Rockchip RK3328 chip but of network and wifi is a SV6051P the manufacturer Iottech.. Could you help me with a functional firmware with android 7 for my box? She unfortunately stuck in boot screen when i open the root, asked to update, it was woe that after restarting the box, she froze and was eternally in the boot screen...
I put the firmware of the Z28 but the network does not work, I believe that in this firmware, drivers are of realtek. Follow some photos of my open box that I took today..You may only view thumbnails in this gallery. This gallery has 8 photos.8 Photos
Point I turn my box in a brick of door!Red LED does not start more... I was trying to flash the firmware of Pendoo (http://chinagadgetsreviews.com/downl...-tv-box-2.html), and I became evil... In the process of reboot the appliance not started more... Is the red LED. Any tips on how to retrieve it? Doing some short circuit at some component?
I recently bought this box and it came prerooted with Supersu and version 7.1.2 NHG47K 20170715.114001. As others noted the GUI resolution sends a signal of 4K but it is not "real" as everything looks kind of fuzzy and Kodi displays 720p.
Is there any version to date that outputs 4K or 1080p?
Will 4K videos play and only the GUI shows lower resolution or is it everything?
That's actually a little newer firmware than the latest version posted here. Do you have a link?
Or if not, could you run this utility to dump all the partitions? https://forum.xda-developers.com/gen...mware-t2915363
There are currently 3027 users online. 0 members and 3027 guests.
