[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
Hello guys, with this rom on my GT1 Ultimate the original you tube app from playstore don't work. It loads the thumbnails/preview but stock always on loading.
The YouTube app that came with this rom works perfectly but i don't like the "skin or look" from this version.
Anyone knows how to solve this issue?
Hi, i got my new GT1 Ultimate today and tried to update the box with this rom, used the SD Card method as i don't have a male to male USB cable. So i put in my Micro SD card, held down the pin/reset button and put the power in, the android dude popped up and it was updating, after that it just went black so i left it for 10 minutes then un-plugged it and plugged it back in, now it won't boot, just a black screen, also tried other roms but nothing happens when i try to update/flash the box, just black. Any help would be much appreciated! My box S/N: A706DBDF etc 32GB
Originally posted by BuckShottq View PostHi, i got my new GT1 Ultimate today and tried to update the box with this rom, used the SD Card method as i don't have a male to male USB cable. So i put in my Micro SD card, held down the pin/reset button and put the power in, the android dude popped up and it was updating, after that it just went black so i left it for 10 minutes then un-plugged it and plugged it back in, now it won't boot, just a black screen, also tried other roms but nothing happens when i try to update/flash the box, just black. Any help would be much appreciated! My box S/N: A706DBDF etc 32GB
If you read carefully, you will realise that this thread is 1 year old.
The OP should be more clear shot l about this on original post as I have said before.
Hope you don't have a permanently bricked box...
good luck with that m8
Originally posted by Djuganight View Post
This Rom is for the first generations of gt1 ultimate.
No, it's a really big fruit salad
No, it's a really big fruit saladPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Hi superceleron I use the normal Android TV version with my Beelink with no problems, please I ask you a question. I use the Beelink with lan cable and it declares as 1 Gps.
I need and use Samba server to transfer big files to the TV box. The max speed in my wired 1GBs network is 10-12 Mb/sec. Is it normal? because I have the same speed transfering files to and from my sattelite recievers having 10/100 network cards ( max speed 10mb/sec ) which is normal.
So I tried to disable your server, and install Landrive from Playstore to test it, and the speed with the same big file was 2-3 mb/sec.
So your server is 3 times better, and my question is there a way to install your file server app in my other mobile devices since it is much better than Landrive?
Thanks in advance and for your time spending.
There are currently 6302 users online. 2 members and 6300 guests.
