[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
    Originally posted by leotzian View Post
    Has anyone managed to install TeamViewer Quick Support in this rom to control the box from the PC? I had installed the app from the Playstore but I don't have the Remote Control Tab so I cannot remote control it, I only see the statistics battery CPU etc.
    Thanks in adnsnce.
    hi - there is a Quick Support add on for TeamViewer in the Playstore, can't remember which one but works well.
      I found it. TeamViewer Host
      Sent from my U65GT using Tapatalk
        Hello, I have a question, do you know if I can use some "keymapper" app that working good with that rom, and if any good FPS games the I can play with that rom ??
          superceleron I'm gonna flash this rom to a Vorke Z6.
          I notice in your OP that you say uncheck erase bootloader, but then see several posts afterwards from people saying the check erase bootloader, so what should I do in my case?
          Another question, is it safe the flash a rom designed for DDR3 to a DDR4 device?
            i cant really tell if this rom will work on that box
            I do tell to not check erase bootloader when you are trying in a different box than the one that the rom was intended.... so like that if it wont work you can go back to stock.
            And this rom is designed to DDR4 since the GT1 Ultimate is DDR4, DDR3 is the older GT1.
              Thanks for the response.
              The Vorke is DDR4 and I'm aware this firmware is as well, but my question was because I'm experimenting with this device and I'm not sure if flashing a DDR3 firmware will brick the device.
              If I erase bootloader, does that mean I can not flash a stock rom any more, or with bootloader not erased I can simply press factory reset to return to stock?
                Well you can try a ddr3 rom but is not going to work ok...
                Erase Bootloader is only for you if the flash goes wrong you can always flash again the stock rom so yes you press the reset button to put the box again in "write" mode so you can flash again the stock rom.
                If you erase it and flash one that is not working with that box the only way you have to go back is put the emmc in mask mode..
                  Found it out the hard way already.
                  I flashed a Tanix T9Pro rom in the hope it would work, as it also has that LCD display, and however the flash was successful the box didn't boot up.
                  Usb burning tool also didn't recognize my device any more, however I had flashed the rom without erasing bootloader.
                  The only way to get it going again was by opening the box and short 2 pins on the memory chip.
                  I flashed your Gt1 Ultimate scv1 to another Vorke Z6 and it works perfectly right out of the box, it has also runs cooler and solved my problem with the distorted picture I have with the stock rom, but unfortunately the LCD display doesn't work.
                  I have sent you a PM in that regard
                    @superceleron
                    Hi! Could you explain me, how to flash this ROM on my GT1 Ultimate? I'm trying with USB Burning Tool, as you say, but getting this message: (look at the attachment)
                    Can you please help me?
                      Originally posted by Opontios View Post
                      @superceleron
                      Is your box in android 7?
                        Yes. Currently I'm on 707NO. But I have an issue with my box. After flashing any ROM of Android 7, every 3-rd or 4-th boot the screen starts to blink from normal to black screen, and then to pink and green. I don't no if it is a software issue or hardware. In the beginning, when I was on Android 6, the firmware with wich I received the box, there was no such a problem. Then I tried every ROM that exist in this board, except for yours, because it couldn't flash.
                          If you don't check erase bootloader during flashing you will get an error. 100% checked this I tell you. I can speak only for GT1 ULTIMATE 3/32 DDR4
                            The reason I unchecked it is because of superceleron's instructions:
                            "Install instructions:
                            • On Usb Burning Tool disable "Erase Bootloader" before flashing..."
                            You suggest to check it? Ok, I'll try.
                              If you read the whole thread you will get all your answers. The superceleron instructions are in case you try to flash a model that it is NOT a GT1 ULTIMATE DDR4.At least 4 members of the forum are indicating the the erase bootloader MUST be checked to flash successful.
                                superceleron your ROM is working properly, thanks for the work you do.
                                I had problems booting with a USB HDD. I removed it and it started. if it can help you improve it.
                                And a question:
                                how to replace / add app on the homescreen (Netflix slots, youtube) I only found how to delete .
                                thanks.
                                Beelink GT1 Ultimate AX12
                                Edit : I found
