[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
    hi can i watch netflix HD with this rom?
      You cant... netflix hd only on wetek, xiaomi mibox, nvidia shield and i think amazon one!
        I see.. im using your ATV version and its working great.
        Thanks for your hard work!
          Hello guys,
          I'm trying to flash the fix for the wifi problem with twrp, but recovery doesn't recognize my sd. Anyone with this issue?
          Nevermind, solved it. Wrong file format... duhhhh
            Thanks for this great rom! I have 2 weeks using it and working great. Only a couple of issues, sometimes wifi disconnect (5ghz), maybe it's a router problem? second, i couldn't set ftmc or kodi to change display hz to match movie. Resolved the dark screen issue by setting a video as boot screen (no rgb fix needed if you do it this way)
            Keep up the awesome job!
            PD: any plans for a V2 or how set all cores to 1.5?
              Yes i do plan to do a big update for this one and the "normal" GT1.
                Beelink release 7.1 to gt 1 ultimate,any plan update this ROM also to 7.1?
                  Yes i do plan to rls a GT1 Ultimate A7.1 rom, but not this one since this one is 6 and it wont be as feature rich as this one...
                    Hello to everyone .. I installed the rom scv1 ultimate in my box h96pro + ddr4. Can anyone help me how to install wifi fix? Thanks for this great rom
                      You must enter recovery, and there, install option from SD card the zip file...
                      Superceleron:
                      Yesterday night i did watch a movie with 17G and very high bitrate....
                      It did freeze and i had to reboot....
                      Software or hardware termal limitations?
                      Format : Matroska
                      Format version : Version 4 / Version 2
                      File size : 17.4 GiB
                      Duration : 2 h 9 min
                      Overall bit rate mode : Variable
                      Overall bit rate : 19.3 Mb/s
                      Encoded date : UTC 2017-05-24 06:52:13
                      Writing application : mkvmerge v12.0.0 ('Trust / Lust') 32bit
                      Writing library : libebml v1.3.4 + libmatroska v1.4.5
                      Video
                      Format : AVC
                      Format/Info : Advanced Video Codec
                      Format profile : [email protected]
                      Format settings, CABAC : Yes
                      Format settings, ReFrames : 4 frames
                      Format settings, GOP : M=1, N=23
                      Codec ID : V_MPEG4/ISO/AVC
                      Bit rate mode : Variable
                      Bit rate : 14.0 Mb/s
                      Maximum bit rate : 30.0 Mb/s
                      Width : 1 920 pixels
                      Height : 1 080 pixels
                      Display aspect ratio : 16:9
                      Frame rate mode : Constant
                      Frame rate : 23.976 (23976/1000) FPS
                      Color space : YUV
                      Chroma subsampling : 4:2:0
                      Bit depth : 8 bits
                      Scan type : Progressive
                      Bits/(Pixel*Frame) : 0.282
                      Stream size : 12.6 GiB (73%)
                      Writing library : x264 core 148 r2665 a01e339
                      Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=14020 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=30000 / vbv_bufsize=30000 / nal_hrd=vbr / filler=0 / ip_ratio=1.10 / aq=1:1.00
                      P-S Did run from external HD....
                        hmm that is a big bitrate but it should be ok even on USB 2.0 i think.
                        The problem m8 be really the thermal you need to check the temp when you play the movie.
                          Watch a movie last night and immediately went hardware defenitions on Kodi, and read 62ยบ....
                          Seems i must tune it!
                            It took me a while to find this one while using my phone, but are the two options, this SCV1 "normal", and then SCV2 "ATV"? Which is the newest one, and since I don't know what "ATV" is, are you still able to use normal apps and kodi? Replies welcome! Thanks in advance!
                              I use this one as "normal"...
                              Don`t like or dont understand the other version...and yes i use Kodi!
                                Is the rom update is the same one from release? I realy need bluetooth and wifi with my set up. Are they working now ok gt1 ultimate?
