Maybe one one the admins could put the modded img in the pinned post - save everyone the wifi/BT issue?
[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
Originally posted by scooter2014 View PostMake sure its on a sd card or usb stick
You may have to change directory in recovery to see it as well.
most times SC firmware once it reboots from upgrade tool it just loads so find it funny it doesnt.
pretty sure his new Alf pro plus work on same with 9377 already in it too. Bit faster as well.
CD
Thanks superceleron for this ROM. I like it a lot!
I got my Beelink GT1 Ultimate with 703 NO (Android 7.1.2) ROM, but I fount it laggy and with some errors I couldn't live with, like vertical orientation. Then I tried this ROM. I succeded flashing it with the tick "Erase bootloader" marked.
I'll expose here my experience... after several attempts, after flashing I could only see the splash screen. I realized that this ROM won't boot if any USB is plugged. In my case, I always have a USB memory and the adapter for my Logitech wireless keyboard. I must keep them unplugged to boot, and then plug them. And when switching off TV Box, unplug them again for the next boot.
Any workaround for this?
Thanks in advance
Which one are you suggesting? I am normally streaming video so I am thinking to stay at Android 6.
Thanks,
CD
Superceleron, do you know if this ROM (or your other android tv ROM) work with the new GT! ultimate boxes with serial # AX12? I just purchased my second GT1 ultimate box and want to apply your custom rom to it. Your rom works flawlessly with my my previous box serial G912! Your efforts really are appreciated!
Originally posted by BrandoR View PostSuperceleron, do you know if this ROM (or your other android tv ROM) work with the new GT! ultimate boxes with serial # AX12? I just purchased my second GT1 ultimate box and want to apply your custom rom to it. Your rom works flawlessly with my my previous box serial G912! Your efforts really are appreciated!
Is all in the 1º topic, read it all!
yes it work.. you need to apply the patch in the 1º post after you flash it.
Forgive me, I did read the complete post (and thread) and I've seen G912, S912 and A912 mentioned but did not see AX12... presumably because it has just been released? If AX12 has AP9377 WiFi chip, I wonder if Beelink changed anything with this new serial#?
I will flash this tonight and confirm!
Might be a typo... should be 9 instead of X!
Hopefully this AX12 uses existing 6255 or 9377 WiFi chip and hasn't changed much to interfere with a smooth Superceleron ROM experience!
A quick look over at the Beelink official forum suggests this is a new edition, and has firmware issues.... (surprise surprise)....
There are currently 1682 users online. 1 members and 1681 guests.
