this why I was asking for some help tweeks zips, I add recovery and xposed and everything working so well .I'm using Ethernet but WiFi even give me 3 time more speed than my last I68G !
[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
Originally posted by Philoumalin View PostExcuse me but when you talk about rom stock I thought you were talking about the rom that we have when buying apparently you are talking about another rom
Of what rom is it and know you or I little found it?
With this ROM, sometimes, apps that i had installed before, disappear.
It happened to me more than once.
When I started the box, I noticed that these apps disappeared.
Anyone else with this problem?
EDIT: I restarted box, and apps are back again :OLast edited by pedrovitorino; 12 April 2017, 22:51.
I was debating about getting GT1 Ultimate or H96 pro+, and eventually went with GT1 Ultimate because at least it's from the same company, unlike some many clones for H96 pro+ (I was eyeing the brand Alfawise). Got the package two days ago, and saw this https://youtu.be/ACKyDseVIFw and https://youtu.be/yXth_qmUutk
Looks like between the reviewer's testing units, H96 pro+ gets the best performance scoring compared to Beelink. And apparently he was using a clone H96 pro as well. Mixed feeling.
Hello everyone
I installed the rom and have a couple of inquiries that u might see as stupid questions but im new to this so pls be patient
1- cannot root the device via super su it gives a message about some binary problem
2- in the description of this firmware they wrote there is TWRP but i couldnt find it to install the wifi support so if anyone can explan this to me i will be grateful
Hi zamakhshary ,
1 . the binarys must be updated , what is the exact message ???
( if there stands normal or TWRP choose normal , wait till ready , reboot)
2. TWRP is a Recovery , u must Reboot to it . Does your Shutdown Menu
not have this Option ???
3.What about your "can not turn Wifi on" Thread , already fixed ???
please answer
nice Day
gefattern
Hello geffatern
Super su says no su binary installed
I found the TWRP
No solution for wifi issue i even contacted beelink but still no response but i found some interesting thread for another device for the same issue
If you recently updated your Nexus phone to Android 7.0 Nougat, but somehow you can't use your phone's Wi-Fi network, and you might have tried factory rese
The problem is i cannot find the files they named in the box system
Thx
Experts, I just got this beelink ultimate and noticed that the bluetooth function is pretty spotty on this one. For example, all my regular TaoTronics bt ear studs and Nyko Playpad Pro could not be seen on this box, let alone pairing. But both equipments have been paired problem free to multiple devices running different version of Android, from jb all the way to mashmallow. Is this the known problem for this machine due to bt chips or it's because of the stock ROM? I'm on Stock rom btw. Thanks a lot
Update: Answer my own question and reference for future user, looks like this machine use a wifi/bt all in one chip? I turned on wifi and was able to pair the Nyko playpad pro and played a round of space marshal 2.Last edited by GentDiors; 16 April 2017, 17:19.
Want to ask a box related question, looks like the Android MM added this function to format SD card as internal storage. I put in a Toshiba Class10 Micro SD and formatted as internal storage, however, I feel that the running speed of several apps is slowing down (tested Kodi). In the olden days, we use Link2SD to do the same (more or less), is this something we should always do on a box? Thanks.
There are currently 2224 users online. 0 members and 2224 guests.
