[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
    Hi superceleron!
    Finally my box arrived!! I flash this great rom!
    Thanks and good work
    Only 1 problem: wifi switch don't turn on, I use Lan cable now.
    ... And...
    I have only 1 questions :
    Is possible to modify the state of hdmi to get work skygo and some other stuff?
    Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk
      Originally posted by screech View Post
      Hi superceleron!
      ... And...
      ??? wifi wont turn on? lol i bet they changed the wifi chip again..........
      And no its not possible sorry!
        And now? For the wifi you can resolve in some mode or I have to use Lan cable only? 'cause I can't use Google remote without WiFi...
          Well you need to find out what wifi chip that box have!!!
            so is this rom for 6255 chip or the 9377 chip?
            and Thanks for your info & work here at FreakTab
              So, how I can find what chip I have? Serial start with G912...
                u have stock rom ? i dont have it yet !
                  tested for 6255 stock and its not this one !
                  gona test 9377
                    Looks like they started to ship diferent wifi chips on the ultimate's boxes... and still no stock rom available... you guys need to ask for it on the beelink forum!
                    The serial of mine is the A912 (ap6225 wifi chip) so the G912 should be the 9377 wifi chips!
                      I have to try with stock rom... maybe tomorrow... No time tonight
                      Thanks for help and info superceleron.
                        I found a stock rom that have WiFi working...
                        Is possible to insert wifi driver in your great rom superceleron?
                        Thanks!!! Sorry for disturbing you....
                        Thanks to beelink for giving me this fw GT1_311M0, use Amlogic USB Burning Tool S/N A912 (AP6255 wifi chip) https://mega.nz/#!4lVVyQyD!VdGLl5DAt...rEuIUdrdLr0Y8c
                          http://freaktab.com/forum/tv-player-...35130-firmware
                          K thks, i will do a zip to flash by twrp this weekend
                            Great! Thanks! You are my hero!!!
                              Hi First of all thank you for great ROM,
                              I have question ,because you stated that the ROM is custom ,what could go wrong with YouTube ?
                              It some how become stuck on loading circle ,no matter what i did - cleared,uninstalled , wiped cash and dalvik ,installed from PlayMarket .... No difference ...
                              One thing I did related to YouYube was Xposed YouTube Addaway module installation more than a week ago,but after that videos where playing fine till it suddenly stuck .
                              Of course I've first of all disabled /uninstalled the module, moreover I've disabled the Xposed ,no change .
                              Is there any log related that i can provide ?
                              Thanks in advance .
                                Try flashing this by recovery http://freak-tab.de/luis/Beelink/ult...ock_Kernel.zip to see if it works!
                                If it wont work... reflash the rom and stay away from that module!
