[ROM] Beelink GT1 Ultimate SCV1 ("Normal" Android) (DDR4)
Originally posted by leotzian View PostSo superceleron it is better not to try to flash those roms in Ax12 serial boxes?
Some posts before someone had successfully flashed it with no problems.
I like your rom very much.
Sent from my U65GT using Tapatalk
Originally posted by leotzian View PostPlease make the tests to understand what is going on with Ax12 serial boxes
Originally posted by BrandoR View Post
Soooooo..... I did 3 AnTuTu tests on 2 boxes, G912 and AX12 with this ROM, and both boxes scored the same, 39xxx points. Keep in mind, the AX12 had the stock kernel flashed because YouTube wouldn't load videos properly, it would just circle animation load and never play. The G912 had the kernel implemented in the ROM. Of course, this isn't with all 8 cores at 1.5ghz, so a kernel update would be so sweet!
Originally posted by superceleron View PostWell is a updated hw revision that ax12 box... so this roms do not work ok on it!Last edited by BrandoR; 03 October 2017, 15:16.
i cant really tell m8, some seem like it flashed ok other dont so dunno now...!Last edited by BrandoR; 03 October 2017, 15:15.
[QUOTE = BrandoR; n675257]
Soooooo ..... Bu ROM ile 2 kutu, G912 ve AX12'de 3 AnTuTu testi yaptım ve her iki kutu da aynı 39xxx puanı attı. YouTube'un videoları düzgün şekilde yüklememesi nedeniyle AX12'nin stok çekirdeği patlamıştı, sadece animasyon yükü çevirecek ve asla oynatılmayacaktı. G912 çekirdeği ROM'da çalıştırdı. Elbette, bu, 8 çekirdekten 1.5 gz'de değil, bu nedenle bir çekirdek güncellemesi çok tatlı olacak! [/ QUOTE] Ã… "
AnTuTu 3d working in a series of mu ax12
Originally posted by BPENL View PostTxs for your post, used your Burn_Card_Maker methode and installed the rom one a AX12 version, runs smooth, just till now do'nt get my gamesir working yet,did no't do any 3 d games yet.
superceleron I know you are very busy supporting other devices with ROMS (MECOOL, Sunvell, Alfawise...) and I'm feeling adventurous... do you think any of these ROMS might work on GT1U? Or is it a brick just waiting to happen? I NEVER BRICK haha
About gamesir i think i dint add the driver to this rom...
I think i read in my alfawise rom thread some ppl are using that rom on GT1U (9377)
There are currently 2738 users online. 0 members and 2738 guests.
