Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
THIS ROM IS FOR THE 1º VERSION OF THIS BOX THAT CAME OUT A FEW MONTHS A GO...
ALSO READ THE INSTALL INSTRUCTION SECTION!
NO WIFI OR BT READ BUGS SECTION!
Changelog V2:
- Fixed install from playstore.
- Updated Gapps.
- True 8 Core, all Cores at 1.5Ghz
- Enabled multi-user support.
- Added Leanback UI sounds.
- Google webview is now default instead of AOSP webview.
- Added Dragonrise USB HID game controller and many USB Bluetooth dongles (btusb.ko).
- Updated pre-defined apps ( A factory reset is needed to access them, this is totally optional )
- Added App Drawer.
- Updated SU to 2.81
- Other little stuff to make it more "true" AndroidTV
- YOU GUYS NEED TO BE ON SCV1 TO APPLY THIS UPDATE!
- Same as V1....
Changelog V1:
- Brand new rom.
- TWRP
- Remove Google Cast since it wont work and never will and was there only wasting resources(Ram)
- New Boot Logo, many thks to tattman65 for the great work
- Android TV Version
- Spoofed as MIBOX3 International
- Leanback Launcher (it may take some minutes to show the recommendations... be patient)
- Live Channels (if you update it, it will not show up in leanback launcher until you add a source, like usb tv dongle, hdhomerun, pluto, haystack etc..)
- ATV Remote control ( download the app from playstore to your phone )
- Voice Search
- 2 On Screen Keyboards, Default on English language is Leanback one and on other lang's is the "normal" one... You can choose the default one in the settings.
- Live Wallpapers, you can control it in Settings -> Display -> Daydream.
- And All the other mambo jambo from ATV....
- Ported the new added stuff from ugoos AM3 1.0.0 rom(Thks ugoos for the nice work) that includes:
- - USB OTG-HOST Switcher (SC settings -> Hardware -> USB switch)
- - Gamepad Settings (SC settings -> System -> Gamepad Settings)
- - NTP Server setting (Date and time -> NTP Server)
- - Fixed ext4 support
- - Added choice of actions for sleep timer and power key on RC (Display -> Daydream -> Power key action)
- - Added ability of disabling wake up from motions (Display -> Daydream -> Wake up from motion)
- - Added Debug Settings (SC settings -> System -> Debug Settings)
- - Temperature, Ram etc monitor.
- - Samba Server
- - Root / Unroot
- Netflix, youtube, playstore...etc... fully working ( Youtube 4k only on 4k tv's ) ( No Netflix HD, so dont ask! )
- initd.d support.
- PS3/PS4 gamepad support ( only with cable... )
- Fixed Xbox360 gamepad that showed power menu on dpad left, so no need for the xposed fix!
- New App that controls Brightness and contrast on the fly, and also apply's the rgb fix(not working, read bugs), cec fix and the saved brightness value on boot! IT NEEDS ROOT TO WORK.. (Many thanks to catharsys for the app
- Gapps updated!
- Long Press Menu button hide/show upper/bottom bar
- R remote cogwheel brings the app switcher ( to close all open apps in one go simple press the menu button )
- Updated supersu app so no need to be updated from playstore to update "su" binary. ( Read bugs section )
- Permissions fixed.
- Gapps Updated!
- Kodi Brightness fix (videos...)
- Added Xposed Framework
- FTMC Build 24
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.6.0, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Some other stuff i cant really remember anymore.... lol
- DEFAULT UNROOTED( Enable root in the settings)
- NO WIF/BT? SIMPLE FLASH THIS FILE (SCV1ATV 9377 WIFI/BT SUPPORT) BY TWRP AND IT WILL FIX IT!
- Sorry due to need stock custom kernel for VP9 to work, i cant use my Kernel.. so NO PROPER RGB FIX... it uses the one from stock.
- On 1º boot when you setup in english language the on screen keyboard may not show when you going to put you wifi password, to fix it go back and change to another language and then go right back again to english and the on screen keyboard should be working now(you need to click it): YOU ONLY NEED TO DO THIS ONCE AND ONLY IN ENGLISH!
- Only update "su" if you are going to to stay at root if are not going to stay at root and you are going to be doing a lot of changes between the two dont update it! Or you will get a boot animation loop...
- Ugoos Firefly it needs ugoos kernel so dont turn it on because it wont work...
- Google cast dont work and removed(missing Widevine L1).
- Possible more!
- DOWNLOAD HERE SCV2-ATV OTA for the Beelink GT1 Ultimate AP6255
- MD5: 3C3AEC0DD111898EE3CA8F2FE26D0228
- DOWNLOAD HERE SCV2-ATV OTA for the Beelink GT1 Ultimate 9377
- MD5: 199D80BF4F0C766A697B332448FAC9D3
Download V1 IMG:
- DOWNLOAD HERE SCV1-ATV for the Beelink GT1 Ultimate AP6255
- MD5: 20AB2975F2A6C81EEBDAB63105DE9838
- On Usb Burning Tool disable "Erase Bootloader" before flashing...
- In this box the format takes long time, if it times out when formatting simple press STOP and then START again ( DONT REMOVE THE USB CABLE )
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
