[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
do a factory reset, go to "Settings -> Storage & reset -> Factory data reset -> Factory data reset -> Erase everything" and wait...
Originally posted by Ducati_996sps View Post
Geting the same thing install pending after factory reset i have a g912 model whit samsung chip thx for helping me
Try cable if you dint or try wifi if you dint... dunno what else can be (besides emmc)
Well im out of ideias i also have the G model but kingston emmc, and everything its working great here my tester have the S model and working great also... and also kingston emmc!
Im very confuse....the V1 says AP6255, but not 9377....but there is a update 9377 over AP6255?
My Ultimate:
S/N Outside box - G912
Inside box: GT-F-L S912.........TM8830
Inside: ......V10_20161015
Inside chip: LTM8830
Kodi reference it as 9377....
Couldn`t check memories or open GPU/SOC...
Can i flash mine?
Sorry, but WHERE is Bug Section???
Thank you!
Originally posted by Mordor View PostIm very confuse....the V1 says AP6255, but not 9377....but there is a update 9377 over AP6255?
My Ultimate:
Can i flash mine?
Thank you!
You flash V1 even if it is for 6225 and then after boot (dont do nothing) just long press the power in remote and boot to recovery and then since you are installing from new you can do a factory reset and after that you install the 9377 zip since its the one for you box.
Bugs section... is in front of your eye's just scroll down...
Originally posted by lilobzh View PostHum
I have a problem of Brightness in KODI since update V2
or its better use FTMC avec SC Rom ?Last edited by lilobzh; 12 June 2017, 07:36.Beelink GT1 Ultimate (Chip 9377) - Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by smellofsky View Postthanks very much~^^ I am using it very well because of you.
but Google korean keyboard doesn't work in this rom.. T T So I can only write English not korean.
Can you help me, Please? Thanks a lot
I'm alone with this problem ? :s
Originally posted by pyc View PostCan this SCV2 update be applied to Android Normal version?
Use the included tool that have a little devil face, you need to have enable root!
I enable Root
i change brightness to test but it's same thing. In dark scene, screen est very dark.
It's a problem with GT1 ultimate and with V1 version, i had no problem.Beelink GT1 Ultimate (Chip 9377) - Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Well i dint change nothing that will make it darker!
In here is just fine!
We are talking about same problem ? (like that : http://www.bee-link.com/forum.php?mo...thread&tid=993 )
You have kodi too ? or FTMC ?Beelink GT1 Ultimate (Chip 9377) - Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
hum.
There is a workaround, that is explained in that topic.
And i only use FTMC!
There are currently 2262 users online. 2 members and 2260 guests.
