[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
1º navigation bar =long press the menu button on the remote!
2º dunno i dont have a iphone m8 :/
well i just tried again in here and is working just fine, post a pic of the error!
Updater process ended with error: 7
Assert failed : file_getprop ("/system/build.prop", "ro
Vendor.sw.version")== " SCV1-ATV"
Error installing zip file '/data/media/0/doSCV2-ATV-GT1_Ultimate-OTA-9377.zip'
Originally posted by rukmal12 View Post
/sbin/postrecoveryboot.sh process ended with error : 127
are you using a usb stick? is TWRP working ok? you can factory reset on it etc..?
Originally posted by rukmal12 View PostI got Beelink ultimate q201 9377 is this compatible? Yes I can reset and I am using sd card to flash this
Dunno look like only you have that problem so i really cant tell where is!
I also have ultimate 9377 and works 100% here the update!
hmm and you are on scv1-atv?
Originally posted by rukmal12 View PostFlash "SCV2-ATV-GT1_Ultimate-OTA-9377.zip" via "Burn Card Maker". ?
The only way i see is you doing the old way... add the recovery.img to the fat32 formated sdcard and the zip + factory_update_param.aml (you need to edit it to change the name of the zip)
good luck!
Hello superceleron
Is it possible to flash your GT1 Ultimate SCV2-ATV to my regular GT1 with AP6255 WIFI chip?
For that box i have another roms just for it!
superceleron hi is it posible to add ftmc in recommendation home screen section in android tv Scv2-atv thx
Originally posted by Ducati_996sps View Postsuperceleron hi is it posible to add ftmc in recommendation home screen section in android tv Scv2-atv thx
I am new to this and I want to make sure I understand what I'm doing before I end up bricking my box. My box is the Beelink GT1 Ultimate s/n starting G912. I just updated the OTA rom from Beelink to GT1_313MO and everything is working fine, however after the downfall of Kodi I wanted to use my Netflix again. The problem is the Beelink is rooted and has an unlocked bootloader from factory. In my research Magisk looks like it would allow me to use Netflix on my box (let me know if I'm wrong) but requires that I use TWRP. After installing TWRP it did not have an image for the Beelink GT1 Ultimate box so if I install the SCV2-ATV-GT1 Rom as per the instructions listed below.
1. Flash "SCV1-ATV-GT1_Ultimate.img" via Burn Card Maker or USB Burning Tool
2. Flash via OTA "SCV2-ATV-GT1_Ultimate-OTA-9377.zip"
Will this also give me TWRP image or is that something else I would still need?
Thank you in advance for any help that can be provided. (please remember that I'm a Noob at this)
There are currently 2741 users online. 1 members and 2740 guests.
