[ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
    nop you cant do that!
    The only way i see is you doing the old way... add the recovery.img to the fat32 formated sdcard and the zip + factory_update_param.aml (you need to edit it to change the name of the zip)
    good luck!
    Can you please explain me how to do this way ?
      sorry m8 search the forum, i cant be explaining the same thing all the time!
        /sbin/postrecoveryboot.sh process ended with error : 127
        Updater process ended with error: 7
        Assert failed ​​​​​​: file_getprop ("/system/build.prop", "ro
        Vendor.sw.version")== " SCV1-ATV"
        Error installing zip file '/data/media/0/doSCV2-ATV-GT1_Ultimate-OTA-9377.zip'
        I had the same error. You need to make sure you are on the correct rom. You must be on the one called "SCV1-ATV" and not "SCV1-(Normal Android)" The correct one can be downloaded from the first post in this thread.
          cheers mate I downloaded and flashed SCV1-(Normal Android) now try to flash SCV2-ATV. what is the different is that 2 different roms for 2 different models ?
            No, they are both made for the gt1 ultimate, but it's two different types of android. "normal android" is the same as on your phone or tablet, and ATV is made especially for TV's
              oh ok do u get the same error ? what did you do to fix ?
                You need to download and flash the SCV1-ATV rom, using the same method as with the SCV1-(Normal Android).
                Afterwards you should have no problem installing SCV2-ATV
                  Thanks for ur help and support mate I will try this tomorrow
                    You spot on mate it works thanks for your advice and support...
                      Thanks. This worked for me too!!
                        No problem. I'm glad I can help
                          The NFS is not working, is there a way to fix this?
                            rukmal12 Mate if you still have a problem with flash write to me on my Skype: wojciech6799
                            I have Beelink GT1 Ultimate (S/N: G912) WiFi chipset 9377and I flashed all sucessfull.
                            1. Flash "SCV1-ATV-GT1_Ultimate.img" via "Burn Card Maker".
                            2. Flash "SCV2-ATV-GT1_Ultimate-OTA-9377.zip" via TWRP (you need a mouse).
                            Via Skype I can explain exactly step by step. Maybe something you do wrong. Greetings
                              Hi, good afternoon,
                              Does anybody can tell me why I can't search in the play store with the keyboard? The only available method is speach mode...
                                louvadeus I can search in the play store with the keyboard. If you cant' you must use a mouse and then keyboard.
